Drives: GT86 GTS
2017 Stock Header
Hi
Anyone got any photos of the 2017 stock headers and diameters of the new piping? Thanks for help. Bob |
#2 |
Drives: BRZ Limited 6MT, 02 AW, 03PSM WRX
My PDF that can be found with a google search states:
Upper branch diameter with 4 callouts 42.7mm to 45mm Upper branch diameter with 2 callsouts 45mm to 48.6mm |
#3 |
Drives: GT86 GTS
#4 |
Drives: 2017 manual BRZ
I have a almost completely stock system on my 2017. Only difference in a catless unresonated front pipe. It sounds really nice in the cabin and is still quiet outside.
Sent from my Pixel XL using Tapatalk |
#5 |
Drives: FT86
#6 |
Drives: 2017 Subaru BRZ
#7 | |
Drives: '14 981CS, '99 NB1
It's not wise to leave a close coupled cat in place with a supercharger. Just swap that out and leave the overpipe, front pipe, catback stock. I have my 2017 with a Tomei and Harrop SC and aside from the cold start, it sounds almost as quiet as stock - even with the blower. |
| The Following User Says Thank You to johan For This Useful Post: | BRZ FTW (02-22-2017) |
#8 |
Drives: GT86 GTS
I have an Invidia R400 that I want to keep, maybe try stock FP
#9 |
CAR-AHOLIC
Drives: 2018 BRZ Ts - CWP
however, if you do want a 17 header from my recent PP BRZ let me know. It has just at 500 miles on it, and its sitting on my workbench. I just installed an ACE 350 header this weekend. So OEM 17 header is available.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS DD/4WD - Colorado ZR2 Bison - Mallett Supercharger |
#10 | |
Upper branch diameter with 4 callouts 42.7mm(1-11/16") to 45mm (1-3/4") Upper branch diameter with 2 callouts 45mm (1-3/4")to 48.6mm(1-15/16")
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#11 | |
Drives: GT86 GTS
For NA purposes your really need to ditch the cat to get the performance but I some benefits for a supercharged setup, especially if you want to clear emissions as well Sent from my iPhone using Tapatalk |
#12 | |
Drives: 2015 FR-S Release Series 1.0
I can tell you that my HKS EL catless header with the stock FP is noticeably louder. I have the Vortech SC installed and I'm seriously considering going back to the stock header to make it quieter. To be fair I have the RS1 quad tip exhaust which was pretty loud even with the stock header. |
#13 |
Drives: 2017 subaru brz
Thread revival
![]() Wanted to harbor some thoughts from you guys. I've recently been looking at a Tomei EL header for my 2017+ brz which has the updated header from factory. According to this thread, the new oem design has larger pipe diameter (per post #2) starting from 45mm to 48.6mm. The Tomei is only 42.7mm to 45mm, which would be smaller than oem. The only advantage of the Tomei would be the removal of the cat. Would that mean stock headers would potentially have better performance, sound aside. |
#14 | |
Drives: JRSC BRZ SOLD
I've went from a HKS header 42.7/50.8/60 to a MY17 catted and decatted back to a HKS. The torque dip from the OEM header is huge even after punching out the cat. If you are want to run EL for around $600 if you look around, I'd go HKS. |
| The Following User Says Thank You to PulsarBeeerz For This Useful Post: | Tatsu333 (05-05-2022) |
| WTB: 2017 BRZ Stock Wheels | brzsubarusti13 | Want-To-Buy Requests | 4 | 10-26-2016 04:50 PM |
| WTB 2017 86 Stock Wheels | Slade | Want-To-Buy Requests | 0 | 09-30-2016 10:17 AM |
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 11:41 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 06:42 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 05:12 PM |
