Old 05-05-2020, 11:22 AM   #1
W0LFIE
Drives: 2019 86 Neptune Blue
How long do you think my engine will last?
What do we think folks?
2019 86 with about 7.5k miles. Current mods are N1 cat back and stage 1 tune. Have Borla UEL catless and stage 2+ waiting to go on, had the parts for like 7 months - I’m just lazy. Planning to go lightweight build and skip FI.
I drive the hell out of my car, a lot of highway driving, 40-60mph and I’d say nominally 60-70% of the time I row 1st-3rd gear to redline getting up to speed assuming I’m not stuck behind someone else. I revmatch/heel-toe downshift probably 90% of the time.
I’m hoping to get at least 80k miles out this engine before rebuild/swap the way I drive, 100k or more would be outstanding.
So given these details, how long do you think my engine will last? How do you drive your cars?
W0LFIE is offline   Reply With Quote
Old 05-05-2020, 12:05 PM   #2
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
It doesn't seem like you're really beating on your car compared to some of the people who track their cars hard and have north of 100k miles. There's also no reason to assume your engine would fail as long as you maintain it properly.
BigTuna is offline   Reply With Quote
The Following 2 Users Say Thank You to BigTuna For This Useful Post:
Spuds (05-05-2020), strat61caster (05-05-2020)
Old 05-05-2020, 12:07 PM   #3
It will last until it breaks. Not one minute shorter or longer.
The Following 13 Users Say Thank You to Tcoat For This Useful Post:
53Driver (05-09-2020), alex87f (05-06-2020), Busybee (05-06-2020), DarkPira7e (05-05-2020), Grady (05-05-2020), Halo_2 (05-06-2020), ichitaka05 (05-05-2020), jcw99 (05-05-2020), nikitopo (05-05-2020), RToyo86 (05-06-2020), soundman98 (05-05-2020), Spuds (05-05-2020), Wally86 (05-06-2020)
Old 05-05-2020, 12:13 PM   #4
Sasquachulator
Pavement Grey
At 82,186, your battery will be shot.
At 139,203 miles, your clutch will need to be replaced.
at 273,869 miles, alot of your gaskets will be worn down and you'll start seeing oil leaks and such.
At 345,876 miles, some catastrophic failure will occur and you'll need to replace all the major components.
And at exactly 415,986 miles you will need a new engine block.
The Following 14 Users Say Thank You to Sasquachulator For This Useful Post:
53Driver (05-09-2020), BigTuna (05-05-2020), Busybee (05-06-2020), Dadhawk (05-06-2020), HaXx (05-09-2020), jcw99 (05-05-2020), p1l0t (05-05-2020), saltywetman (05-06-2020), soundman98 (05-05-2020), Spuds (05-05-2020), strat61caster (05-05-2020), Tcoat (05-05-2020), Wally86 (05-06-2020), YamahaR86 (05-06-2020)
Old 05-05-2020, 12:27 PM   #5
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
You will money shift on a Tuesday in about 3 weeks and kill the engine.
I have a side gig in retirement..
The Following 4 Users Say Thank You to Sapphireho For This Useful Post:
53Driver (05-09-2020), jcw99 (05-05-2020), soundman98 (05-05-2020), strat61caster (05-05-2020)
Old 05-05-2020, 12:32 PM   #6
p1l0t
p1l0t's Avatar
I'm sure you will make it past 8,000mi easy.
The Following 3 Users Say Thank You to p1l0t For This Useful Post:
Busybee (05-06-2020), jcw99 (05-05-2020), Wally86 (05-06-2020)
Old 05-05-2020, 12:36 PM   #7
W0LFIE
Sounds legit, those numbers are out of the tech manual, right?
The Following 3 Users Say Thank You to W0LFIE For This Useful Post:
53Driver (05-09-2020), Dadhawk (05-06-2020), jcw99 (05-05-2020)
Old 05-05-2020, 12:39 PM   #8
Chickeneatman
Drives: 2013 FR-S Ultramarine
Hah! Your car is already broken.
In reality, these cars were made to be beat on. Just let it warm up properly, use good gas, and oil. These cars just seem to have issues randomly. There isn't much correlation to how they were used.
Chickeneatman is offline   Reply With Quote
The Following User Says Thank You to Chickeneatman For This Useful Post:
Old 05-05-2020, 12:57 PM   #9
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Maintenance and letting it warm up before beating on it is much more important than how you drive it.
These engines should do 300k easy.
Old 05-05-2020, 01:07 PM   #10
Riftur
Riftur's Avatar
I have a 2013 and drive it hard most of the time. I do regular oil changes and use high quality fuels. I will also tune it for e-85 occasionally. The engine and trans seem pretty well made. I am pretty sure you'll be fine for a long time.
Riftur is offline   Reply With Quote
Old 05-05-2020, 05:05 PM   #11
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Your engine is likely to last longer than you will have the car. Just make sure you let it warm up before running it out, use the appropriate octane gas, and perform recommended maintenance on time.
Old 05-05-2020, 05:36 PM   #12
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Keep on top of your fluid changes and it'll be good. If you want it to last forever, no mods and keep stock tune
Old 05-05-2020, 09:00 PM   #13
soundman98
ProCrastinationConsultant
soundman98's Avatar
cars are like any other relationship. some of them like when you beat on them, but it's about how you take care of them when they're not asking for it that makes for long term reliability.
if you use it, abuse it, and ignore it, things will fall apart sooner rather than later.
The Following 5 Users Say Thank You to soundman98 For This Useful Post:
Chickeneatman (05-07-2020), HaXx (05-09-2020), p1l0t (05-05-2020), Spuds (05-05-2020), Wally86 (05-06-2020)
Old 05-05-2020, 10:33 PM   #14
AKITA
AKITA's Avatar
Drives: 2016 Scion FRS Halo
I’m just lazy.
well I predict you'll leave the oil in there for like 15k a couple times thinking 7.5 was ok according to mfg recommendations so 15 is just pushing it.. while you drive the hell out of it.. blown head gasket at 67k right when you were thinking about getting around to changing that oil again.. lol just quoting you
kidding.. see how things can be taken so out of context .. change the oil frequently if nothing else. I wouldn't go over 5k without changing mine .. generally do it after three (I live in HEAT). Is there anybody who doesn't drive the hell out of this thing? In fact, I'm pretty sure it's not good for it to be driven all the time like a Sunday morning cruise to church either.
AKITA is offline   Reply With Quote
The Following User Says Thank You to AKITA For This Useful Post:
p1l0t (05-05-2020)
How long is too long for post-recall repair? ndsleep612 Issues | Warranty | Recalls / TSB 2 08-04-2019 05:35 PM
Engine long block derek1ee Want-To-Buy Requests 0 02-29-2016 10:51 PM
How long does stock battery last without engine on? jon2 Scion FR-S / Toyota 86 GT86 General Forum 15 03-15-2015 09:58 PM
Cinco de Slamo Meet in Long Beach NY (Long Island) whitefrs New England 11 05-01-2013 09:03 AM
