Old 09-20-2017, 11:13 PM   #1
tshrey
Drives: Black BRZ
Taller 6th gear?
Any of your tranny types (not judging) know if there are other cars with gears that will interchange with our transmission? I want a taller 6th for the highway. Stock puts me at 70 mph at 3k rpm, I'd like that pushed to more like 78 mph at that engine speed.
On my STI someone found you could swap out the 5th and 6 gears from a Legacy GT and get their taller ratios without having to change the center and rear differentials. I'd like to do something along that line.
And while the trans is out I could spring for those carbon synchros that were posted a little while ago...
tshrey is offline   Reply With Quote
The Following 2 Users Say Thank You to tshrey For This Useful Post:
Ultramaroon (09-22-2017), why? (09-22-2017)
Old 09-21-2017, 11:25 PM   #2
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
I know Mfactory already has gear ratio products such as taller 1st and 2nd and shorter 6th. You could talk to them about a custom order taller 6th gear. A taller 6th gear might have the same install process as the taller 1st where you have to shave a bit of the trans casing to make it fit.
I know i'd be interested as i'm looking to get a 4.44 final drive, but I'd like to keep highway rpms down closer to stock.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
The Following User Says Thank You to Spawn_Of_Creation For This Useful Post:
Sleepless (09-23-2017)
Old 09-22-2017, 09:38 PM   #3
gravitylover
I'd be interested in an answer to this too.
Old 09-26-2017, 08:58 PM   #4
nav
Drives: Toyota 86
I think it's a great idea for those who want to run shorter final drives for the track, and have a cruising gear for the street. Here is some data on what's out there:
Stock 6th Gear : 0.767
MFactory 6th Gear : 0.861
The car really benefits performance wise from a shorter final drive, at the cost of daily driving comfort. I'm currently on a 4.8 final drive, and the car runs at 3100rpm @ 60mph.
nav is offline   Reply With Quote
Old 09-26-2017, 11:22 PM   #5
Spawn_Of_Creation
Human
After calculation roughly translates to ~
Lexus is300 Final Drive 3.73:1 @ 3000 rpm:
Custom 0.687 ratio 6th gear = 86mph
Stock 6th gear = 77mph
MFactory 6th gear = 68mph
(Stock) Final Drive 4.1:1 @ 3000 rpm:
Custom 0.687 ratio 6th gear = 78mph <-- What OP wants
Stock 6th gear = 70mph
MFactory 6th gear = 62mph
Final Drive 4.44:1 @ 3000 rpm:
Custom 0.687 ratio 6th gear = 72mph
Stock 6th gear= 65mph
MFactory 6th gear= 58mph
Final Drive 4.55:1 @ 3000 rpm:
Custom 0.687 ratio 6th gear = 70mph
Stock 6th gear = 63mph
MFactory 6th gear = 56mph
Final Drive 4.67:1 @ 3000 rpm:
Custom 0.687 ratio 6th gear = 68mph
Stock 6th gear = 61mph
MFactory 6th gear = 55mph
Final Drive 4.8:1 @ 3000 rpm:
Custom 0.687 ratio 6th gear = 67mph
Stock 6th gear = 60mph
MFactory 6th gear = 53mph
The Following 2 Users Say Thank You to Spawn_Of_Creation For This Useful Post:
jcw99 (11-16-2018), TachyonBomb (09-27-2017)
Old 10-24-2017, 01:44 AM   #6
BRX
BRX's Avatar
Drives: Toyota GT86
Sign me up. I'm keeping the stock trans for my V8 swap for awhile and I need a much taller 6th gear. I already have a 3.73 final drive but that's still not enough even with 26" tall tires.
Sent from my Pixel XL using Tapatalk
BRX is offline   Reply With Quote
Old 10-24-2017, 05:09 AM   #7
Spawn_Of_Creation
Human
Comment in this thread (http://www.ft86club.com/forums/showthread.php?t=122738)
jcw99 (11-17-2018)
Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl jakebrz Issues | Warranty | Recalls / TSB 14 06-06-2016 06:28 PM
Do Automatics have Taller Gears ItzYaBoyBugZ Scion FR-S / Toyota 86 GT86 General Forum 19 05-31-2015 12:42 PM
taller final drive ratio SuperDave Engine, Exhaust, Transmission 17 10-26-2014 03:37 PM
Anyone running taller tires? cactus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 02-04-2014 03:22 AM
Would a taller / larger oil filter improve oil cooling? brillo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 05-14-2013 03:18 AM
