Old 07-16-2017, 12:57 PM   #1
ChRZ
ChRZ's Avatar
Drives: 2017 BRZ SP
Diff Mount Inserts install - Diff won't lower???
Ok I'm at a loss...I am trying to install the Whiteline KDT925 diff insert bushings and after I remove the two front bolts (while supporting the diff with a jack) then try lower the diff a half inch or so to get the bushings in, the diff is not going anywhere. It is not moving downward like it should.
As I look at it this makes sense. The diff rear bushings are supporting the up and down movement of the diff, and the front of the diff is tied to the driveshaft, so how is it supposed to lower down just by unbolting the two front diff mounts? Seems like the driveshaft would need to be unbolted to allow the front of the diff to tilt downwards some (towards the front of the car)
I'm confused. The instructions just say to do as I described above, no mention of unbolting anything else, and I haven't seen any challenges mentioned by anyone either when discussing these, just lots of talk about NVH...
Just for kicks I tried loosening the 4 subframe mounts but then realized that doesn't help either, just lowers the whole assembly altogether- diff and subframe.
ChRZ is offline   Reply With Quote
Old 07-16-2017, 03:12 PM   #2
Somerandom18
Drives: 2017 manual BRZ
I never bothered supporting it with a jack. The cradle bolts hold it well enough. It dropped down just enough to slip the inserts above the bushings.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 07-16-2017, 07:06 PM   #3
ChRZ
ChRZ's Avatar
Drives: 2017 BRZ SP
Ok, nevermind, I got impatient and figured it out.
I unbolted the three rear bolts in addition to the front 2, while supporting the differential, and that worked perfectly. Was able to lower the diff down exactly as needed and get the front bushings in.
Again, the instructions just say: "Support the differential....unbolt the two front bolts....lower the diff a half inch.....voila. Insert your bushing inserts and you're on your way. It then says to bolt them back up, torqe em to spec, then move on to the rear three bolts. So according to the instructions the rear three bolts were supposed to be there the whole time I was doing the front two???
Anyways I got it, so this post may help out the next person who runs into this problem in the future. Still, I'm curious as to how others accomplished this. Are the Whiteline instructions just wrong?
Side note....quick review. I did the subframe and the diff bushing inserts together and it is awesome. Right away as I pulled out of my driveway it was more connected. No more caboose effect. Taking up the clutch is so much more solid and instant into 2nd and 3rd gear.
I was nervous about making my nice smooth quiet 2017 (1st brand new car ever) a rattle box but it's totally fine. Definitely a little clunk here and there when taking up the clutch, some diff noise when turning at low speeds as the torsen bits are getting loaded and doing their job, and overall a slight bit more low hum from the chassis above about 25mph. The thing I notice most of all is when I am really on it, like over 5k, it sounds like the exhaust/engine is louder, but it's actually just the drivetrain. Still on stock exhaust but feels like I put on a catback when I get on it, but like normal when I'm not. I like it. It's like I'm more part of the car.
The Following User Says Thank You to ChRZ For This Useful Post:
Somerandom18 (07-16-2017)
Old 07-16-2017, 09:51 PM   #4
wparsons
wparsons's Avatar
There's no way the diff will drop with the rear bolts all the way in, what you ended up doing is exactly what I did to install mine as well.
flickr
Old 07-17-2017, 01:07 AM   #5
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Mine drooped far enough just by removing the two front bolts.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Somerandom18 (07-17-2017), wparsons (07-17-2017)
FOUND: Beatrush Diff Mount Support Brace (Rear) asnatlas Want-To-Buy Requests 1 05-21-2016 12:28 AM
FS: Whiteline rear diff inserts rever5e Brakes, Suspension, Chassis 6 03-16-2015 09:23 PM
Whiteline Diff cradle mount, steering rack bushings, etc.. Thongpocket Engine, Exhaust, Transmission 4 02-25-2014 06:26 PM
Beatrush diff support mount TouchMyHonda Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 08-14-2013 09:04 PM
Whiteline diff bushings and trans mount insert. Simmons Transmission and Driveline 7 06-09-2013 09:45 PM
