Old 12-29-2019, 12:18 AM   #1
GraysonBRZ
Drives: 2015 BRZ
Crawford Power Blocks idle issue
First post on this forum, I got the Power Blocks with the Grimmspeed CAI and Openflash tuner. I started my car and it would rev up and down through 1k and 2k rpm, bogging down when it gets below 1k rpm, and shuts off after around a minute. Im on the Stage 1 tune and I flashed it when I put the CAI on. All the PCV hoses are attached and everything is plugged in correctly from what I could see.
GraysonBRZ is offline   Reply With Quote
Old 12-29-2019, 12:20 AM   #2
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
Id recheck everything. it sounds like your idler control isnt functioning right so you got a leak someplace.
otherwise try adjusting the tune for the power block spacers.
https://www.ft86club.com/forums/showthread.php?t=71285
Clutch Dog is offline   Reply With Quote
Old 12-29-2019, 01:16 AM   #3
tomm.brz
Drives: brz 2017 hksv2
upload a log or can t help
did you rescale maf after installing CAI? but yes i would also think of a leak, check also the hoses under manifold
Old 12-29-2019, 02:09 AM   #4
86TOYO2k17
Drives: 2017 toyota 86
+1 for logs.
Based on that it would be a lot easier.
But my guess you pinched a gasket or it dropped/fell out and you got a bad vacuum leak.
Old 12-29-2019, 04:14 PM   #5
GraysonBRZ
Drives: 2015 BRZ
UPDATE: Found the problem, the gasket on the driver side of the manifold slipped when i put the blocks in, and when I tightened the bolts down, it must've cut the gasket. Ive already ordered new gaskets. Thanks for help ��
The Following User Says Thank You to GraysonBRZ For This Useful Post:
soundman98 (12-29-2019)
crawford billet blocks, idle problem
e85 and Crawford power blocks Lantana frs Engine, Exhaust, Transmission 10 07-21-2018 12:34 PM
Crawford power blocks Lantana frs Software Tuning 2 10-11-2016 10:54 PM
Crawford Power Blocks absolute Engine, Exhaust, Bolt-Ons 3 05-17-2015 12:21 PM
Crawford power blocks fs Triumphrider Engine, Exhaust, Bolt-Ons 2 04-06-2015 12:17 PM
Crawford Power Blocks like new oTaGGeDo Engine, Exhaust, Bolt-Ons 0 07-27-2014 10:22 AM
