Old 03-23-2017, 08:59 PM   #1
C4RBON
C4RBON's Avatar
Drives: '15 BRZ, '19 GTI
Kosei K4R 17x7.0 +50
I picked up a used set of Kosei K4R wheels for street-class autocross. I don't see these listed in the wheel directory yet, so I figured I'd make a thread in case anyone else is considering these wheels.
Specs:
- 17x7.0"
- +50mm offset
- 5x100 bolt pattern (Note: The wheels have the text "5x114.3" cast into the front. I have seen this on several sets of K4R wheels. It's just the way it is. The label on the wheel barrel says 5x100).
- 14.0 lbs according to TireRack. My bathroom scale says 14.2 lbs (without wheel weights or center cap).
- 9 spokes
- Made in Japan
- Tilt-cast spokes and flow-formed barrel
As of March 2017, you can purchase these new from TireRack for $199 each.
Pics on car:
Pictures of wheels:
C4RBON is offline   Reply With Quote
The Following 2 Users Say Thank You to C4RBON For This Useful Post:
Somerandom18 (03-23-2017), Vracer111 (03-24-2017)
Old 03-23-2017, 09:43 PM   #2
Somerandom18
Drives: 2017 manual BRZ
Been wanting these for years! ❤️
NE Ohio represent.
Somerandom18 is offline   Reply With Quote
Old 03-23-2017, 09:58 PM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
That's very light for cast wheel. And at such budget price. Would be nice to see offset at least no less then stock though.
Old 03-23-2017, 10:43 PM   #4
C4RBON
C4RBON's Avatar
I agree. I was planning to get RPF1's since they have the minimum street-class legal offset of +42mm offset. However, this set came up locally for $200 and I couldn't pass them up. Everyone else has RPF1s, anyway. I am seriously considering getting some extended studs and 5mm spacers to get to +45mm. But that is ~$120, which further erodes the savings I realized by getting these used Koseis instead of new Enkeis.
Old 03-25-2017, 06:43 PM   #5
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Kosei K4R 17x8 +36 have been in the Directory for nearly 5 years. There are threads on your exact wheel. Your search foo is not strong
http://www.ft86club.com/forums/showthread.php?t=9334
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 03-25-2017, 06:49 PM   #6
Cole
Not a troll
Cole's Avatar
Didn't realize that a +50 offset was the same as a +36 offset. Or that a 7" wheel is the same as an 8" wheel
Cole is offline   Reply With Quote
The Following 2 Users Say Thank You to Cole For This Useful Post:
Apoc (03-25-2017), why? (03-26-2017)
Old 03-25-2017, 06:58 PM   #7
Apoc
Apoc's Avatar
I never said it was. There are threads for this exact wheel that are 3 years old so my point is that it isn't new or a surprise
http://www.ft86club.com/forums/showthread.php?t=66115
“The World is Flat”
[||•]=(86)=[•||]
Old 03-25-2017, 07:13 PM   #8
imnotsureaboutbrz
Drives: between cars...
As they OP meantioned these are for Street class autocross where you change your offset by +\- 7mm, rim size +\- 1in and width must by unchanged...
**OP what tires are you running? Re71r's?
imnotsureaboutbrz is offline   Reply With Quote
The Following User Says Thank You to imnotsureaboutbrz For This Useful Post:
Apoc (03-25-2017)
Kosei K4R 17x7.0 +50 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 03-12-2016 11:23 AM
Kosei K6R 17x7 +50 Wheels Brand New jonesy Wheels and Tires 3 05-11-2015 03:12 PM
Wtb kosei k4r 17x7 or 8 jxl00 Wheels and Tires 0 11-02-2014 01:18 AM
FS (local only): Kosei K1-TS 17x7 +50, 5x100 AFRichZC6 Wheels and Tires 2 06-04-2014 10:23 PM
