Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
02-26-2018, 01:59 AM | #1 |
Drives: Scion FR-S
P0461 code
Been having this check engine line for the longest . I know what the code means but idk how to fix it . Has anyone found a solution or any suggestions and I always clear the code with the obd so it won’t annoy me.
02-26-2018, 05:09 AM | #2 |
Drives: FT86
Most likely the fuel level sender in tank,
The Following User Says Thank You to steve99 For This Useful Post: | H214M (02-26-2018) |
02-26-2018, 05:43 AM | #3 |
Huge E85 fan!
Drives: 2016 Scion FRS
IME a bad sending unit is the first step in your fuel pump going bad. It could be something else (I had a OBD2 port reader with a connection issue that would cause this CEL along with a CANBUS communication error), but if the car is under warranty, get it in and tested. If not, I'd run it until it dies- you can run with a bad sending unit for a LONG time and you'll be fine, it doesn't always mean that the fuel pump is screwed. Don't trust the fuel gauge, start using the trip odo instead
The Following User Says Thank You to guybo For This Useful Post: | H214M (02-26-2018) |
Similar Threads | ||||
Another CEL code | whitefrs | Forced Induction | 20 | 11-27-2019 11:27 AM |
P0461 code | H214M | Issues | Warranty | Recalls / TSB | 7 | 01-22-2018 01:28 PM |
p0462 fuel level sensor code. anyone else ran into this code | georgiafrsguy | Engine, Exhaust, Transmission | 1 | 02-28-2017 08:28 PM |
Lean Code and 02 Code diagnostics. | Kiske | Engine, Exhaust, Transmission | 12 | 04-28-2016 10:19 PM |
CEL code | ChandlerSwyng | Issues | Warranty | Recalls / TSB | 2 | 04-08-2014 01:27 AM |
