Old 02-26-2016, 07:50 PM   #1
Sonicp9
Drives: 2016 Raven FR-S
Looking for help adding sub and amp to existing 2016 FRS sound system and head unit
Hey guys,
Before I get flamed, I have searched for a thread on this many, many times and all I found were rather complicated guides on using stock amp (which I don't think my model has) to install additional speakers etc. etc. etc., all of which were no help to what I want to do.
From my old Jetta, I have two 12 inch MTX subwoofers with box and a monoblock MTX amp. My FRS has the bongiovi upgrade (Im in Canada) but the rear speakers are still crap. Therefore I want to put the subs and amp in the trunk and keep the 2016 factory deck and sound system. I am not sure if my best bet (or best result) will be to take the signal from the bongiovi amp or if I can use a line-out converter on the rear speaker cables from the head unit. I have not yet taken the head unit out so I am not sure if any signal from the bongiovi amp is even going to the rear speakers.
I have done a subwoofer install using an aftermarket deck that had sub inputs but not on a factory deck without them. I have seen a lot of guides but they all seem to focus on replacing every speaker and usually use the factory amp under the trunk carpet which I don't think my car has (the bongiovi amp apparently sits under the head unit). I was wondering if you guys could help me out with the best solution to this before I start taking things apart. Will using a line-out converter kill my signal quality? Any pros/cons? I am thinking of recording or at the least taking pictures of the entire install and making a guide.
Thanks,
Sonicp9 is offline   Reply With Quote
Old 02-27-2016, 10:25 AM   #2
Ashikabi
Ashikabi's Avatar
Originally Posted by Sonicp9 View Post
Hey guys,
Thanks,
I'm curious about this too. I have a scion so it's base model and I have an amp under the trunk carpet so I'm pretty sure you will too. I don't know squat about audio so I can't help you further than replace the factory amp maybe? I've heard of people tapping the rear speaker inputs for a sub but I have no further details
Old 02-27-2016, 11:24 PM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Well don't know about the new model but are you sure you don't have a amp on the trunk? If not then yeah, your better off taping into your rear speakers. Line out converters won't mess up your audio.
I have one it sounds just as good. Many new amps have built in line converters. My case I lost my wiring plug to it so I went with line out converter.
2016 BRZ Head Unit Wiring Harness TommyC Electronics | Audio | NAV | Infotainment 84 08-18-2017 01:05 AM
2016 Head Unit Question / Discussion Devante Electronics | Audio | NAV | Infotainment 31 04-18-2016 07:59 PM
Can I buy rear camera and head unit 2016 Mikeez Electronics | Audio | NAV | Infotainment 25 03-02-2016 11:23 AM
2016 FR-S Head Unit stock connections tk1138 Electronics | Audio | NAV | Infotainment 2 03-01-2016 07:47 PM
head unit swap speakers sound flat and muffled iketiak Electronics | Audio | NAV | Infotainment 5 04-20-2013 09:48 AM
