Old 02-02-2024, 12:52 AM   #29
troek
troek's Avatar
Drives: 2012 Toyota 86
Here are GR86 OEM rear struts and springs with 2013 model top hats. Fitment seemed fine to me.
cant get the pics to embed. link is https://imgur.com/a/kUEgiV6
troek is offline   Reply With Quote
Old 02-12-2025, 03:29 AM   #30
jtiptonk
jtiptonk's Avatar
Drives: 2013 WRB Subaru BRZ Limited 2.0
So if I were to put the 2022+ strut assemblies in a 2013 brz, would I be able to use the 2013 stock end links? What about if I also added the 2022+ jdm sti springs? Thanks!
jtiptonk is offline   Reply With Quote
Old 02-12-2025, 08:37 AM   #31
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
The assemblies are the same, just droop travel and valving have changed.
Old 02-12-2025, 09:25 AM   #32
Racecomp Engineering
OEM endlinks are the same for 1st and 2nd gen.
If your endlinks are 12 years old I'd plan on replacing them!
- Andrew
Old 02-12-2025, 11:15 AM   #33
jtiptonk
jtiptonk's Avatar
Gotcha, thanks! Yes I need to replace them, just trying to figure out which ones to get. Would you recco stock or adjustable? Only suspension mod I have at the moment are TRD sway bars, and plan to do a slight lower at some point, but probably no more than 15mm. (Sorry slightly off topic, I know)
Old 02-12-2025, 11:45 AM   #34
With OEM (or similar) struts and shocks I recommend OEM endlinks....except in some cases an adjustable endlink is helpful with certain adjustable sway bars.
I'm not familiar enough with the TRD bars to make a recommendation though. If you're okay right now with the OEMs you'll most likely still be okay later.
- Andrew
Old 02-12-2025, 12:18 PM   #35
jtiptonk
jtiptonk's Avatar
Got it, thanks!
The Following User Says Thank You to jtiptonk For This Useful Post:
Racecomp Engineering (02-12-2025)
Old 02-13-2025, 10:31 AM   #36
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
Speaking of endlinks, I really need to get around to changing the fronts on mine after adding coilovers.
My Perrin OEM length ones don't clear the inner fender / body with -4 degrees of camber, so I went back to stock. Perrin's bushing's are wider. Either way, both too long and the swaybar touches the control arm slightly, which I can't imagine is great for handling.
I highly recommend the Perrin OEM length ones for use with regular struts and stock / stock-ish ride height. They held up great through 2-3 seasons of autocross and I still have their front ones on my WRX after about 10 years. They'd be a nice little upgrade / replacement along with the 2022+ suspension.
cmiovino is offline   Reply With Quote
Old 03-06-2025, 06:38 PM   #37
grippgoat
Drives: 2023 BRZ, 2018 Golf R 6MT
I bought RacerX front endlinks to solve the clearance problem (MCS 2wnr with -4* camber). They have gobs of clearance. But the sphericals got creaky fast. Not sloppy, but just creaky. Not sure I'd get them again. The price is very good, though.
-Mike
grippgoat is offline   Reply With Quote
Old 03-06-2025, 08:59 PM   #38
We have some coming very soon.
Very good quality sphericals.
- Andrew
Standard Suspension Bump Travel 86•BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 87 07-26-2017 11:33 AM
Raceseng Shock Top - Rear Upper Shock Mount with 1” Increased Travel RJasonKlein Brakes, Suspension, Chassis 2 01-18-2017 04:33 PM
More rear suspension travel Hyper4mance2k Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 03-24-2016 08:13 PM
RallySport Direct's Mega Suspension Everything Thread!!! RallySport Direct Brakes, Suspension, Chassis 101 07-01-2015 11:01 AM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
