Member's Car Journals Car journals by our members. |
06-05-2024, 08:35 PM | #309 |
The Dictater
Drives: '13 Red Scion FRS
So, I've been still hearing a hissing sound on throttle. Went looking for leaks. I found one (I think ?) at the donut gasket, probably because I just reused the original. Maybe it's time for a catback since I gotta get a gasket anyway
Also, the fix for the undertray didn't hold. Thinking of trying out JB Weld fiberglass wrap to hold it. Or maybe I should just give in and get another one.
Also: "Build Thread" |
The Following 2 Users Say Thank You to Spuds For This Useful Post: | villainous_frx (06-07-2024), Wally86 (06-07-2024) |
06-09-2024, 08:36 PM | #310 |
The Dictater
So it turns out the front pipe flange is very pitted where the donut gasket seals, or doesn't seal in this case. Cleaned it up as best I could with a file, but getting it actually flat is going to take precision grinding/machining. I of course did the logical thing and tried some high temperature rtv. Waiting for that to cure, hopefully it works.
The Following User Says Thank You to Spuds For This Useful Post: | Ultramaroon (06-10-2024) |
06-09-2024, 09:02 PM | #311 | |
Drives: 2017 BRZ PP, 2004 WRX
I used Permatex red gasket maker. Slathered the donut gasket in it, tossed it, clamped it down, and waited 24 hours. Perfect seal. I was actually under my WRX today and the previous owner installed a Cobb turboback over 10 years ago. Glanced to see if there was any gasket maker. Sure enough, there were traces of it. If I ever do any exhaust installs in the future, I'll be using some sort of gasket sealer. I've sort of always been against it because the gasket should seal itself, right? But it just works. At least a little pinch doesn't hurt.
The Following User Says Thank You to cmiovino For This Useful Post: | Spuds (06-09-2024) |
06-09-2024, 10:56 PM | #312 |
The Dictater
Well that worked for about 2 minutes. Or there's another leak. It's really not that bad I tell myself. I'll figure it out eventually.
The other thing I did was make another attempt at repairing the transmission cover undertray. Used some jbweld fiberweld in segments /layers. It was about as frustrating as I remember composite layups being from 15 years ago but it seems like it will work. Hardens well with a strong bond, drillable, cutable, sandable which is good cause I had to do all that to make stuff fit. Rated for 400°F, should be fine on the left center hole, a bit away from the exhaust. Stuck some gorilla tape around it because it seemed like the thing wmto do. Next time I just try to order a replacement...
The Following User Says Thank You to Spuds For This Useful Post: | villainous_frx (06-10-2024) |
Similar Threads | ||||
2018 Camaro SS 1LE vs Spuds' FRS | Spuds | FR-S / BRZ vs.... | 13 | 06-16-2019 10:11 PM |
FRS from Vroom - RISKY? | Cosa | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 10-21-2018 09:27 PM |
So my key FOB was put in the washing machine.... | Kayzer Soze | BRZ First-Gen (2012+) -- General Topics | 11 | 06-07-2013 11:43 AM |
Vroom! - This week's blipshift shirt | blipshift | Miscellaneous | 1 | 11-13-2012 10:29 PM |
