Old 04-15-2013, 03:01 PM   #1
Mandy
I came from a motorbike
Mandy's Avatar
Drives: Firestorm 2013 FR-S 6MT
Flexyframe License Plate Cover (save yourself from scratches).
So I had some concerns after removing my dealer license plate covers, I noticed some scratches; thought I could cover it up with a larger one, but that rattled, and after closing the trunk it just lead to more scratching. Due to only having 2 bolts to hold the plate cover, I found that it makes it night impossible to leave your plate on there without this inevitable damage. You might think it's OCD, but over time your car might end up like this:
So I sought out an alternative to padding/weather stripping your plate/car, and I found the Flexyframe. It's actually designed for front bumpers, but I found that it had all the properties I was looking for:
Yes, I rep the U, but the gift from the alumni association was leading to more scratches then FSU, and UF fans combined.
I removed the plate, I literally washed the car the day before, but you can still see all of the dirt trapped behind the plate. Look up top and you can see some of the deep scratching caused by the frame.
More pictures of the scratches.
And scratches caused by the bottom.
I didn't feel like washing the car again, so I used the exterior detailer that came with my car. If you have a spray wax/quick detailer, either of those will work with a microfiber cloth.
Nice and clean now.
You can barely see the scratches on the top, pretty decent product.
The bottom scratches are still pretty bad. I wish they had put bottom plate screws on the car.
And here's what's going to save my paint back there for now.
And there's where the plate is going to be covered from the finish on the car. Very different than any other plate covers I've seen.
Doesn't look very thick once it's actually on the car.
Then again, it is 1" thick.
Bought the cover from here: Flexyframe
$20 for my OCD piece of mind was fine for me. I know it's probably photo overkill, but I'm off this fine, sunny ,Monday afternoon, so I thought I would do something productive.
Mandy is offline   Reply With Quote
The Following 2 Users Say Thank You to Mandy For This Useful Post:
Anthonytpt (04-15-2013), clzzical (04-15-2013)
Old 04-15-2013, 03:17 PM   #2
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
Can't see your photos, as I block Dropbox on my network at work, but I tried a couple different license plate frames and didn't like any of them. I ended up grabbing some adhesive backed foam tape and putting around the back side of my rear plate.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 04-15-2013, 04:08 PM   #3
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I used adhesive backed tape as well.
Old 04-15-2013, 04:47 PM   #4
Hanakuso
I put a lot of electrical tape on my license plate. No scratches or anything yet.
Hanakuso is offline   Reply With Quote
Old 05-22-2013, 08:32 PM   #5
BRZNutt
BRZNutt's Avatar
Drives: 2014 DGM Subaru Impreza 2.0i 5 Door
Put foam tape on top of the thin foam tape that is already on the car. You want the rubbing and wear to be on your license plate not the paint on your car. Also the thin Subaru OEM plate frame has spacers that keep the plate away from the paint. The frame keeps the plate straight so it can't touch the paint.
2016 World Rally Blue Subaru WRX Limited
2013 Satin White Pearl Subaru BRZ Limited 6 MT (Sold)
BRZNutt is offline   Reply With Quote
Old 05-23-2013, 03:15 PM   #6
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
I have the Subaru one, the spacers were a nice surprise.
Scenic Driver is offline   Reply With Quote
Old 05-23-2013, 11:00 PM   #7
FRiSson
Drives: FR-S MT
I went to a craft store and got a sheet of adhesive backed thin foam. Cut it to fit the plate and it rattles no more.
FRiSson is offline   Reply With Quote
Old 05-28-2013, 11:00 AM   #8
FReSh
Dirt Trackin'
FReSh's Avatar
Drives: '13 Raven FR-S MT
Hmm, something tells me that double stick velcro might also be a good option...
FReSh is offline   Reply With Quote
BRZ tow hook cover hole mod for license plate holder TSY BRZ First-Gen (2012+) — General Topics 19 05-10-2013 02:58 AM
[PSA] (Common knowledge?) Your license plate cover and you. Mandy Scion FR-S / Toyota 86 GT86 General Forum 10 04-02-2013 08:35 PM
Custom OEM Color License Plate Cover SkitterSkotter Cosmetic Modification (Interior/Exterior/Lighting) 17 01-16-2013 07:30 AM
Need help, plate lamp cover size? 8987846 BRZ First-Gen (2012+) — General Topics 0 12-22-2012 02:00 AM
[For Sale] Rho-plate Tow Hook Mounted License Plate rack pizzahead20 Canada Classifieds 0 08-23-2012 12:06 AM
