Old 04-02-2013, 10:12 PM   #1
LeftFootBrake
LeftFootBrake's Avatar
Drives: White 86 GTS AT
Cruise Control 'set' light
Is there a known issue with the cruise control's 'Set' indicator sometimes failing to light even when the speed is set correctly?
I'm encountering this and have reported it to dealer but they were unable to repro.
Notes:
1. Stability/Traction controls unchanged from engine turn on.
2. No traction loss during trip.
3. Speed above 40kph.
LeftFootBrake is offline   Reply With Quote
Old 04-02-2013, 11:11 PM   #2
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
Did you push the cruise button in first enforce "setting" cruise? I sometimes forget to do that. Also, not sure what speed cruise control will kick in, usually not until you are in 6th gear.
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 04-03-2013, 09:53 PM   #3
LeftFootBrake
Thanks. All those questions answered in first post.
Old 04-03-2013, 11:05 PM   #4
naking
Drives: 2013 Ultramarine AT FR-S
Cruise control won't work if you're in sport mode. Also if you have cruise control set and turn Sport on, cruise control will shut off automatically.
naking is offline   Reply With Quote
Old 04-03-2013, 11:19 PM   #5
LeftFootBrake
Thanks. Again though, as described in first post, none of that is applicable because the speed is set, it's just the 'set' light on the dash not coming on.
Old 04-04-2013, 09:38 AM   #6
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
So its cruising as it should but the light doesn't turn on?
Ranatsu is offline   Reply With Quote
Old 04-04-2013, 01:59 PM   #7
FR-S Matt
I'd get it on video with your phone next time it happens.
Old 04-04-2013, 08:17 PM   #8
LeftFootBrake
Sorry, why the video request? I can't understand what difference it would make to this thread.
Old 04-04-2013, 08:21 PM   #9
LeftFootBrake
Answered in post #1 and #5.
Old 04-05-2013, 12:07 AM   #10
Ranatsu
Cone basher
Actually it wasn't answered in either post.
I asked you if the car was actually cruising with the light off.
Meaning you drive up to 60mph, set cruise and take your foot off of the throttle and it maintains this speed. Yet the second light stating cruise is active does not turn on.
There are two lights one that says cruise control is turned on and the other that says its actively being used. This light turns off when you tap the brakes or pull back on the cruise control stalk.
Does that better explain my question?
If the secondary light isn't turning on yet the car is maintaining speed as it should be. Then just take it into the dealership. Its probably a dead bulb or something.
Old 04-05-2013, 01:35 AM   #11
LeftFootBrake
Actually, it was.
Old 04-05-2013, 06:17 AM   #12
Shagaliscious
Drives: Firestorm FR-S (MT)
Dude, take it to the dealership. Clearly no one else has experienced this problem, if they had, this thread would be a couple pages long with people saying "yup, happens to me too."
Get it on video (like someone already said to do), so you can show the dealership.
Old 04-05-2013, 08:35 AM   #13
LeftFootBrake
Sigh.
Old 04-05-2013, 08:49 AM   #14
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
Sigh.
When you turn the car on acc and the cluster does the bulb check, do both cruise lights illuminate? Easy easy to verify its not a bulb issue.
NotSoJDM is offline   Reply With Quote
Cruise control malfunction totally Issues | Warranty | Recalls / TSB 20 02-26-2018 09:13 PM
Cruise control temporarily disabled? DarrenDriven Scion FR-S / Toyota 86 GT86 General Forum 15 06-29-2016 08:35 PM
First Check Engine Light and Traction control QFry Issues | Warranty | Recalls / TSB 26 10-04-2014 11:27 PM
christmas light cruise xclusive_brett Southern California 1 12-03-2012 04:45 PM
cruise control and speedo issue.. tibsy92 Issues | Warranty | Recalls / TSB 1 10-10-2012 12:21 PM
