Old 03-12-2013, 12:39 PM   #1
wu_dot_com
Drives: accord
Misc DIY parts / tool spec and references
This DIY list is intended to gather all the miscellaneous parts / tool that we used for our projects. By having a compilation of the relevant parts and spec list, it should help others to source their parts in the future.
Please use the following format to make the future search effort easier.
Application: (the usage application)
Name: (name of the product)
Spec: (the specification of product, size, length, material etc)
Source: (where to buy it from, link seller website if possible)
PN: (part number)
Price: (price of parts reference)
Pic: (picture if available)
Comments: (all other relevant info goes here, thoughts, review, credit, etc)
wu_dot_com is offline   Reply With Quote
Old 03-12-2013, 12:45 PM   #2
wu_dot_com
Drives: accord
Application: Clutch Slave Cylinder Bleeding
Spec: Thd Size (M7 X 1.0); Overall Length, in/(mm) 1.19/ (30.22)
Source: http://www.speedbleeder.com
PN: SB7100S
Price: $7.00 + shipping
Pic: see website
Comments: the S behind the PN SB7100S stands for short. You may use the standard length PN SB7100 which are 1.38” overall length for this application. Stainless Steel valve is also available with PN SB7100S-SS
The Following 2 Users Say Thank You to wu_dot_com For This Useful Post:
86ft.lb (08-17-2016), BatStig (07-29-2014)
Old 03-12-2013, 12:51 PM   #3
wu_dot_com
Drives: accord
Application: Brake Caliper Bleeding
Spec: Thd Size (M10 X 1.0); Overall Length, in/(mm) 1.35/ (34.44)
PN: SB1010
Pic: see website
Comments: Stainless Steel valve is also available with PN SB1010-SS. Info from F1pont4 SS brake line DIY http://www.ft86club.com/forums/showthread.php?t=20311
Old 03-12-2013, 01:02 PM   #4
wu_dot_com
Drives: accord
Application: Clutch master cylinder hardline fitting size
Name: AN union / AN fitting
Spec: AN -3, male
Source: any, ebay
PN: N/A
Price: N/A
Pic:
Comments: this is a common fitting size, select the other side of this fitting depends on the matting stainless steel line you want to use. For example, if you select an AN -4 SS line, then you will get a AN3 male to AN4 male union.
Old 03-12-2013, 01:09 PM   #5
wu_dot_com
Drives: accord
Application: Clutch hardline to soft line fitting size
Spec: M10 x 1.0 thread, male
Source: any, ebay
PN:
N/A
Price: N/A
Pic: N/A
Comments: M10 is also a common size to see on the AN fitting. For example, you can get an AN-3 to M10x1.0 fitting from ebay for $6. Select the other end of the fitting based on the SS line size you needed. For example you can replace your clutch hardline with AN -3 to AN -3 union + AN -3 SS line 6”-9” + AN-3 to M10 x 1.0 fitting.
OFFICIAL Torque Android app PID/Misc Thread Brody602 Engine, Exhaust, Transmission 872 03-04-2024 10:00 PM
Greddy intake and misc parts JoeBoxer Engine, Exhaust, Transmission 20 07-19-2012 01:58 AM
3D Model for Rfactor 2 NEED REFERENCES! Mr.Ferret FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 05-03-2012 09:03 PM
Misc 1st86 Trip Photos. Dadhawk FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 18 04-12-2012 10:19 PM
My misc AIMS photos [56k lolno] PuGZoR Other Vehicles & General Automotive Discussions 8 10-24-2010 06:32 PM
