Old 03-08-2013, 10:05 AM   #1
HillCountryGuru
Drives: Ultramarine Scion FR-S
Vortech Supercharger or AVO Turbo
I have been doing some research and I am really torn between these two kits. Both are in my price range. Both are reliable companies. Is there a reason to get one over the other? Help!
Sent from my DROID RAZR HD using Tapatalk 2
HillCountryGuru is offline   Reply With Quote
Old 03-08-2013, 10:07 AM   #2
Frostyman
Drives: 2013 Raven FRS
Get both, MONSTER POWAH!
Frostyman is offline   Reply With Quote
The Following 5 Users Say Thank You to Frostyman For This Useful Post:
-Ozzy- (04-11-2014), Amadeus (03-08-2013), Batman (03-08-2013), SnapOv3st3r (03-25-2013), swift996 (03-14-2013)
Old 03-08-2013, 10:14 AM   #3
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
I'm still waiting to see what happens with the Innovate twin screw. If I had to choose only between these two it would probably be AVO for me based on torque results. A twin screw should do a better job with immediate torque than the Vortech, so I wait.
Jeff86 is offline   Reply With Quote
Old 03-08-2013, 10:17 AM   #4
YourFearlessLeader
Team ScioNRG President
YourFearlessLeader's Avatar
Drives: 2017 WRB BRZ
turbo for drag car
SC for road racing car
2017 Subaru WRB Limited BRZ w/ PP
YourFearlessLeader is offline   Reply With Quote
Old 03-08-2013, 10:22 AM   #5
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
A turbo as small as AVO's is a viable option for road imo.
The Following User Says Thank You to Jeff86 For This Useful Post:
Batman (03-08-2013)
Old 03-08-2013, 10:39 AM   #6
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I honestly see no reason to pick vortech over the AVO kit on paper. Both are more or less track tested and well built, the AVO just has alot more power. It's not like the AVO is a monster turbo with miles of piping. It's a small compact kit running low boost on a high compression car. Really have to drive both to know the answer here. The Vortech seems to be overpriced for what it offers at this point though.
industrial is offline   Reply With Quote
The Following 3 Users Say Thank You to industrial For This Useful Post:
2forme (03-14-2013), Charleswinky (06-23-2013), Sportsguy83 (03-14-2013)
Old 03-08-2013, 10:54 AM   #7
HillCountryGuru
I will be taking the car to a track nearby. The only reason I was thinking avo is BC of the low amount of boost, I will be waiting 6months or so to buy anything so we will see what innovate throws out.
Old 03-08-2013, 11:44 AM   #8
HATED1
HATED1's Avatar
Drives: 86
you might want to consider which one has better MPG, im in the same boat.
HATED1 is offline   Reply With Quote
Old 03-13-2013, 10:45 PM   #9
jkonquer
Drives: 2005 Subaru STI
according to what we have read so far in the threads, it seems like vortech s/c is pretty much maxed out from the factory. There are few power gain from adding smaller pulley but the actual compressor is at its limit. Where as AVO, you have more option to upgrade in future as with most turbo kits.
It really comes down to what you plan on doing with your car. Both are reliable but i would think vortech will be better since it doesn't use oil or water cooling which result in oil consumption in turbo application. As far as cooling, turbos are known to heat up dramatically in 86.
jkonquer is offline   Reply With Quote
Old 03-14-2013, 01:16 AM   #10
sw20kosh
Drives: 2013 Black FR-S
I'd wait for Innovate's sc and AVO's stage 2 finalized results. AVO's fast spool + 270 WHP is hard to beat.
I am also addicted to risp NA response and supercharger whine so Innovate's looks yum to me too.
Old 03-14-2013, 02:26 AM   #11
AVOturboworld
I've not seen any oil consumption issues over the last 6000 miles of turbo testing. I don't except there to be any, either. EJ25 turbo motors have oil consumption issues practically out the door (due to blow-by). This is a different motor, and doesn't have those same issues.
All turbochargers heat up dramatically in all setups - they make power off the exhaust! Since we place ours down in the area set up for the exhaust manifold already, it doesn't affect anything near it. And given how we do our turbocharger oiling system, we haven't seen any large oil/coolant differences from stock.
The Following 2 Users Say Thank You to AVOturboworld For This Useful Post:
Jeff86 (03-14-2013), Sportsguy83 (03-14-2013)
Old 03-14-2013, 02:45 AM   #12
matchamochi
matchamochi's Avatar
Drives: swp brz
Vortech gets carb emission. Sounds stupid - but in California it actually matters unfortunately if your car is your dd :/
matchamochi is offline   Reply With Quote
Old 03-14-2013, 04:15 AM   #13
sw20kosh
AVO turbo kit carb approval would seriously seal the deal for a lot of people. Especially considering it looks like a OE part. It, however will not pass CARB as it stands.
Old 03-14-2013, 06:29 AM   #14
Delsy
Delsy's Avatar
Drives: Gt86
To install AVO do you need some modification on your car? I use a GT 86 aero with all stock. Also I use 100oct gas. Thanks a lot!
Delsy is offline   Reply With Quote
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
Vortech supercharger skatery1989 Forced Induction 293 04-19-2013 04:58 PM
Vortech supercharger. skatery1989 Engine, Exhaust, Bolt-Ons 2 02-23-2013 07:19 AM
Vortech Supercharger FRS/BRZ vividracing Forced Induction 5 01-29-2013 07:03 PM
