Northern California NorCal
MisterSheep
Old 03-04-2013, 12:51 AM   #1
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Average Gas Mileage
Just wondering. What's the average gas mileage you guys get around the city in the bay area on your FRS/BRZ. I'm hitting ~20mpg or less driving normally (shift around 2.5-3k) and that's from home to school/work and vice versa.
Bach415 is offline   Reply With Quote
Old 03-04-2013, 02:25 AM   #2
Melody
Melody's Avatar
Drives: 2013 BRZ Limited
Seems to be about 22-24 city driving, but haven't gone a full tank with just city driving (it usually becomes a mix of city/hwy) so it's hard to tell... 20 or less seems low though!
Melody is offline   Reply With Quote
Old 03-04-2013, 02:38 AM   #3
dnL
Drives: Ultramarine FR-S
A little over 30 mpg, but most of the miles are on the freeway.
dnL is offline   Reply With Quote
Old 03-04-2013, 03:58 AM   #4
JohnAyySays
JohnAyySays's Avatar
Drives: Scion FR-S Whiteout
I average about 26mpg doing city and highway driving.
JohnAyySays is offline   Reply With Quote
Old 03-04-2013, 09:26 AM   #5
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
See my sig
Old 03-04-2013, 11:18 AM   #6
sw20kosh
Drives: 2013 Black FR-S
22-30 mixd freeway/city
Old 03-04-2013, 11:30 AM   #7
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I'm getting 24 avg with almost exclusively city driving.
I'm not sure if this is true, but could gas mileage actually suffer by shifting too early? 2.5-3k seems awfully low to me, given how high these engines are designed to run. I just mean that there might be times especially in the later gears where it might seem like the engine is lagging when shifting at those lower RPMs.
You could try listening to the sound of the revs/motor itself instead of going by the gauge, and just shifting in each gear based on feel/sound. Might have an impact if you're able to just go with the natural shift points of the engine instead of keeping shifts exclusively at 2.5-3k rpm.
Originally Posted by Bach415 View Post
(shift around 2.5-3k) .
Old 03-04-2013, 12:29 PM   #8
tnt
Drives: argento frs at
~25-26 combined
tnt is offline   Reply With Quote
The Following User Says Thank You to tnt For This Useful Post:
RaineyStar (04-01-2015)
Old 03-04-2013, 12:45 PM   #9
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
I'm getting a steady 24-25 mpg with about 80/20 city/hwy doing a very similar shift pattern as you (around 2.5-3.5k rpm).
Unfortunately for me, I've been so well trained from the break-in period, I have to consciously rev past 4k if I wanted to. If I go by sound/feel alone, I naturally shift at around 3k.
Old 03-04-2013, 12:48 PM   #10
Travis
Travis's Avatar
Drives: FR-S 6MT Whiteout
Try checking your tire pressures, mine were each down just a few PSIs but I noticed a decent drop in mpg. When mine are at factory setting I average around 24.5mpg which is a lot of stop and go traffic and city driving
Follow me on Instagram @filthytravis
Travis is offline   Reply With Quote
Old 03-04-2013, 01:05 PM   #11
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
~28 mpg, 4500 miles in. I shift at similar points and try to keep the engine between 1,900 and 3,000 rpm, mostly commute miles in stop and go. It really shines on freeway trips averaging 30+ (depending on the terrain) with the cruise control on even at 80 mph. I could easily see high 30's with forgiving terrain and ~50 mph in 6th.
Stop and go on city streets with no cruising distance will tank your mileage no matter what you drive, that's why hybrids exist. Combustion engines are best at constant speeds with constant loads (see CVT)
ALSO: Very important, the onboard average fuel economy gauge is optimistic at best, I've never had it be within 1 mpg of what I was actually getting. My last fill up it estimated that I was getting 33.0 mpg; actual: 30.99, ~6% error.
ineedyourdiddly
Old 03-04-2013, 02:56 PM   #12
matchamochi
matchamochi's Avatar
Drives: swp brz
I'm doing about 29.9 after 2 fuel ups, but I'm still in the break in period and primarily 30/70 city/freeway.
matchamochi is offline   Reply With Quote
Old 03-04-2013, 03:53 PM   #13
SC David
Bloberator
Drives: 2013 Asphalt FR-S 6MT
I get about 22mpg around city streets, and 32mpg highway cruising at 70-75. Usually equals out to about 27mpg mixed, each tank.
SC David is offline   Reply With Quote
Old 03-04-2013, 04:34 PM   #14
Thesandlord
Thesandlord's Avatar
Drives: Whiteout FR-S
28, mostly street at 30-50 mph with a little highway thrown in also.
Thesandlord is offline   Reply With Quote
Average waiting time for an 86 GT Nytemayr AUSTRALIA 18 11-11-2012 04:10 AM
Average wait time on Volks? TuxedoCartman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 46 10-10-2012 12:22 AM
FRS/BRZ What's the average age out there for you guys who ordered the cars ? SCIONMONTREAL CANADA 38 09-19-2012 02:24 PM
WHATS YOUR AVERAGE MPG? imravenit Scion FR-S / Toyota 86 GT86 General Forum 1 07-10-2012 01:10 AM
What will the average MPG be? Poll! SOB Scion FR-S / Toyota 86 GT86 General Forum 52 04-22-2011 05:48 PM
