Old 01-29-2013, 04:25 PM   #1
sw20kosh
Drives: 2013 Black FR-S
Muffler Delete sound without deleting muffler
What would the exhaust sound be like if you just drilled a hole/s into the piping pre-muffler?
Ok you are thinking...ghetto...but...
I ask because:
A. For track laps I want to hear the exhaust for determining when to shift.
B. Recent anecdotal evidence has shown that the stock muffler acts as a pseudo diffuser and if removed will create a fair amount of lift in high speed corners (track).
Would this sound terrible? Or would it sound sorta like a muffler delete pipe (which I have used already).
Old 01-29-2013, 04:29 PM   #2
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
It would be a lot less permanent to just put some washers between the flanges in the final exhaust joint.
In either case, though, I'd be a little worried about damage from hot exhaust back there. You've seen the pictures of bumpers melted off, right?
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
Old 01-29-2013, 04:32 PM   #3
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
If your looking to keep your oem muffler and in the same time seeking a performance upgrade, you might want to look into a gutted stock muffler.
We have them if you are interested
86_ZN6 is offline   Reply With Quote
The Following User Says Thank You to 86_ZN6 For This Useful Post:
sw20kosh (01-29-2013)
Old 01-29-2013, 04:45 PM   #4
sw20kosh
--Dan
Mach V
Which is why I was thinking of drilling instead of washers. If you drill a hole on the bottom of the pipe, it shouldn't shoot hot gasses up towards the bumper.
Why hasn't anyone created a nice functional diffuser already so we can ditch this stock can once and for good?
Old 01-29-2013, 04:51 PM   #5
Hanakuso
If you really want the stock muffler but sound. Buy a muffler delete and hack away the piping on the muffler that would get in the way.
Hanakuso is offline   Reply With Quote
Old 01-29-2013, 05:35 PM   #6
sw20kosh
So just keep the muffler with its hangars, and install my muffler delete pipe? That could work if I decide to mutilate the stock axle-back.... hmmm
Old 01-29-2013, 05:40 PM   #7
be6sti
be6sti's Avatar
Drives: 2013 scion frs
It will sound terrible.... Air rushing over the holes would cause a whistle like noise.... Don't do it...
"Fuck it lets go!"
be6sti is offline   Reply With Quote
The Following User Says Thank You to be6sti For This Useful Post:
Old 01-29-2013, 05:41 PM   #8
be6sti
be6sti's Avatar
I did this to a cargo can I had when I was 14 thinking oh yea! It'll sound great!!! No it sounded like a car with an exhaust leak... Cuz it was a car with an exhaust leak....
"Fuck it lets go!"
Old 01-29-2013, 08:11 PM   #9
CSG David
CSG David's Avatar
It is being in the works. We are also testing a prototype Berk axleback exhaust to properly fill the void which we have been thoroughly testing on public streets, back roads, highways, and track use. We have undergone quite an extensive set of iterations and we'll be testing, hopefully, the final iteration of the Berk exhaust soon prior to its release. Your concerns are the same as ours since the beginning.
Old 01-29-2013, 10:06 PM   #10
ScionFrsFan
any idea how far till release lol
ScionFrsFan
ScionFrsFan is offline   Reply With Quote
Old 01-30-2013, 05:09 PM   #11
CSG David
CSG David's Avatar
Berk has been backed up with a ton of work. We'll definitely let everyone know when the exhaust will be released.
Muffler Delete SkitterSkotter Engine, Exhaust, Transmission 37 07-04-2017 12:44 AM
Muffler delete zooplane Engine, Exhaust, Transmission 11 12-16-2012 07:00 PM
Dual Muffler Delete by F.M.S fmsida Engine, Exhaust, Transmission 2 10-19-2012 08:37 AM
Resonator delete? Sound with stock muffler? Nate219BRZ Engine, Exhaust, Transmission 23 09-05-2012 06:42 PM
X-Pipe with Muffler delete dav0777x Engine, Exhaust, Transmission 3 06-21-2012 10:30 AM
