Old 01-28-2013, 11:10 AM   #1
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
DIY- Scion Frs Fog lights
Installed these on my Frs a few days back and posted them on here. My indox has been blowing up since then with people asking for part # and a DIY. I put these videos together from videos taken on different days hope they help. Any questions feel free to ask.
Videos:
Parts needed:
-H11 harness of your choice
-2 Outback Fog lights Part #84501AJ00A
http://www.subarupartsforyou.com/cp_...p?partid=19073
-JDM Fog light bezel
Originally Posted by Nikkojoe View Post
RH Fog light cover - SU00301518
http://www.amayama.com/search/?q=su00301518
LH Fog light cover - SU00301519
http://www.amayama.com/search/?q=su00301519
-4 screws with locking bolt (will go to Home Depot to take pics of what I used)
Reselts!
No lights at all:
Fogs on:
Fogs + HiD bulbs:
HID's only against wall:
Fogs only:
HID's + fogs:
[/QUOTE]
Juanito08 is offline   Reply With Quote
The Following 23 Users Say Thank You to Juanito08 For This Useful Post:
baldolera (04-01-2013), Bingbong (05-24-2013), brianlo622 (01-29-2013), campy (02-03-2013), Chimera (04-24-2014), Dadhawk (05-03-2013), Enraged21 (04-05-2013), Got3n (01-29-2013), imravenit (02-24-2013), KlafKoon (02-25-2013), Laika (01-28-2013), lbroskee (01-28-2013), mezdup (01-28-2013), mkiisupra (01-28-2013), normancw (01-28-2013), sal (01-29-2013), SkAsphalt (01-28-2013), so26 (01-28-2013), subwaynm (12-15-2013), tbwoodlee (03-06-2013), terrypm (01-29-2013), Thedishdoc (01-30-2019), Wes (01-28-2013)
Old 01-28-2013, 12:29 PM   #2
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
good work here!
Old 01-28-2013, 12:58 PM   #3
MrTranxD
MrTranxD's Avatar
Drives: Scion FR-S
May i ask what you did with the switch?
2013 Ultramarine FR-S 6MT
MrTranxD is offline   Reply With Quote
Old 01-28-2013, 01:10 PM   #4
Ingen
Drives: Ultramarine FR-S 6MT
Dang, way cheap! I like it
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 01-28-2013, 06:47 PM   #5
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
great work. strongly considering this for another spring project.
mezdup is offline   Reply With Quote
Old 01-28-2013, 07:59 PM   #6
RICEBOY_86
RICEBOY_86's Avatar
Drives: whiteout FR-S
Looks sick good job
RICEBOY_86 is offline   Reply With Quote
Old 01-28-2013, 08:20 PM   #7
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
NICE! Siked to see someone finally do this.
Did you ever consider wiring it to the fuse box? I feel a bit uncomfortable wiring it straight to the battery.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 01-29-2013, 10:40 AM   #8
Retro86
Retro86's Avatar
Drives: Awesome
im doing this! nicely done!
Retro86 is offline   Reply With Quote
Old 01-29-2013, 12:20 PM   #9
MrTranxD
MrTranxD's Avatar
Drives: Scion FR-S
It has a switch so it wouldn't drain the battery. Its wired to only draw power if your parking lights are on. I did a similar install on m friends 06 Si. Gonna do the same on my frs after my parts come in. hehe. Also, IIRC, these lights need a constant source of power. thats why its connected to the battery.
Old 01-29-2013, 12:58 PM   #10
HunterGreene
Hail Magnet
HunterGreene's Avatar
About how much time did this take for you?
Old 01-29-2013, 02:29 PM   #11
terrypm
First86 & burning gas!!
terrypm's Avatar
Drives: Asphalt 2013 Scion FR-S
Juanito08, sorry but I am confused. What is the purpose of wiring the green wire to the side maker light? Also with the wire you ran through the firewall into the interior what did you connect it to make the fog lights to be controlled by the light stalk? Did you install a new light stalk?
Do your fog lights turn on every time the parking/headlights are turned on? Did you not use a toggle switch to be able to turn the fog lights on and off independently?
Thanks
terrypm is offline   Reply With Quote
Old 01-29-2013, 02:47 PM   #12
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
Originally Posted by terrypm View Post
Juanita08, sorry but I am confused. What is the purpose of wiring the green wire to the side maker light? Also with the wire you ran through the firewall into the interior what did you connect it to make the fog lights to be controlled by the light stalk? Did you install a new light stalk?
Thanks
The green wire is like a remote wire. I tapped into the parking light so that it can come on with the parking light switch. I didn't put in a switch as of yet trying to see where I might mount it first. So as far as right now the switch wires are hard wired to one another
The Following User Says Thank You to Juanito08 For This Useful Post:
Old 01-29-2013, 05:28 PM   #13
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Just a thought I've been tossing around, you might have some luck getting a JDM power folding mirror switch and use that for the fogs.
Old 01-29-2013, 06:32 PM   #14
Khánh
Khánh's Avatar
Drives: sc00ter
went to the dealer and got me a pair of fogs for $104.13 taxed.. now, time to wait for the bezels.. can't wait!!
Khánh is offline   Reply With Quote
Custom Shadow Led Lights Scion FR-S Precisionleds Cosmetic Modification (Interior/Exterior/Lighting) 84 07-14-2013 04:26 PM
