Old 10-31-2011, 07:42 AM   #1
Nardi330
Nardi330's Avatar
Drives: 86
Exclamation Scion FR-S / FT-86 / Subaru BRZ Specs and Options. 200hp / 151 lb-ft tq
Scans from a training manual.
Power/weight:
HP: 147kw (200ps) / 200hp @7000rpm
Torque: 205nm (151 lb/ft) @ 6600rpm
Weight:
  • 2662 ponds (1210kg) for base manual (~ 2580 lbs dry weight)
  • 2706 pounds for higher trim manual
Columns:
First 2 column are for "small FR sport", column 1 is a higher spec model, column 2 is a lower spec model. 3rd column is Mx5/Miata, 4th is RX8 and last is CRZ. It's a comparison chart.
Top Section:
The top section is the dimension in mm, length width height wheelbase, ground clearance then number of seats. Next is weight.
Top spec manual is 1230kg, auto is 1250kg.
Low spec manual is 1210kg, auto is 1230kg.
Then its turning radius.
High spec rides on 17" wheels and low spec on 16.
Second Section:
This section is engine. Boxer 4 DOHC, 1998cc. Output as listed on 1st post above. Drinks premium unleaded and 50L fuel tank.
Fuel consumption base model:
13 km/l
30.58 mpg
49.21 kmg
Fuel consumption top model:
12.4 km/l
29.17 mpg
46.94 kmg
Third Section:
This section is front engine/rear drive, transmission type, suspension type, brake then tyre size.
High spec brakes: ventilated discs front and rear.
Low spec brakes: ventilated front, non ventilated rear.
Last Section:
Last section is equipment which is not that easy to understand. First thing I notice is top spec has LSD for manual and auto while low spec only has LSD on manual. I'll post more if I can read more.
More update:
Both spec have VSC, front passenger and front and rear curtain bags. Top spec has front LED, leather steering wheel, 6 speakers audio (low spec has 2 speakers), white rev counter with shift light and sport pedals. Top spec also has "smart entry and start".
MORE THINGS OF NOTE:
Strut front, double wishbone rear suspension
Base halogens, optional HIDs on base trim, standard HIDs on high trim
LSD on all MT cars
Stability control standard
Only 2 speaker audio on base car
High Spec:
  • Has "high-quality fabric" (上級ファブリック).
  • Option for leather heated seats with Alcantara inserts.
  • Steel door sill insert / scuff plate (ステンレス製ドアスカッフプレート)
  • Interior metallic door handle inserts
  • Carbon fiber center console trim
  • Door courtesy light
  • Knee pad on console
The "Customize Grade" at the bottom is interesting:
  • the "customize grade" bare bones model is 1190 kg !!
  • Unpainted bumper
  • 16 steelies (says ornament-included, guessing it includes the logo)
  • plastic steering wheel
  • NO A/C (only a heater)
  • Power door locks
  • Sunvisor (no vanity mirror)
  • No speakers
the car in fact does require premium unleaded gas (無鉛プレミアム)
the rear seat is one piece and is foldable (一体可動式)
did anyone mention that the high spec model comes with a digital speedo and tachometer? (デジタルスピードメーター revメーター)
Here are translated charts (by our members Spaceywilly and dimension6!!)
Training manual images:
Nardi330 is offline   Reply With Quote
The Following User Says Thank You to Nardi330 For This Useful Post:
ESBjiujitsu (05-09-2012)
Old 10-31-2011, 07:55 AM   #2
zigzagz94
BRZerhood Lurker #13
zigzagz94's Avatar
Drives: 15 DGM BRZ Premium
hey ichi can you translate the spec sheet for us?
200ps and 1200 kg is not bad could have been alot worse
zigzagz94 is offline   Reply With Quote
Old 10-31-2011, 07:59 AM   #3
kaivo
Drives: -.-
13.0 km/liter ? damn high or what .
kaivo is offline   Reply With Quote
Old 10-31-2011, 08:00 AM   #4
Nardi330
Nardi330's Avatar
Drives: 86
First 2 column are for "small FR sport", column 1 is higher spec, column 2 is lower spec. 3rd column is Mx5/Miata, 4th is RX8 and last is CRZ. It's a comparison chart.
The top section is the dimension in mm, length width height wheelbase, ground clearance then number of seats. Next is weight. Top spec manual is 1230kg, auto is 1250kg. Low spec manual is 1210kg, auto is 1230kg. Then its turning radius. High spec rides on 17" wheels and low spec on 16.
I'll try to figure out more and post here.
More:
Next section is engine. Boxer 4 DOHC, 1998cc. Output as listed on 1st post above. Drinks unleaded and 50L fuel tank.
Then it's fuel consumption.
Next is front engine/rear drive, transmission type, suspension type, brake then tyre size.
Next section is equipment which is not that easy to understand. First thing I notice is top spec has LSD for manual and auto while low spec only has LSD on manual. I'll post more if I can read more.
More update:
Old 10-31-2011, 08:03 AM   #5
zigzagz94
zigzagz94's Avatar
Thanks Nardi. It's looking more and more like a rwd DC2 type R and that'a good thing
Old 10-31-2011, 08:23 AM   #6
Nardi330
Nardi330's Avatar
Drives: 86
Yeah. The only remaining puzzle are the name and the price.
There is even 1 spec that comes in unpainted bumpers and steel wheels!!
Old 10-31-2011, 08:26 AM   #7
Nambo
Nambo's Avatar
Drives: '12 BRZ [CBS]
Looks like the lower spec won't have the switches and digital tacho like the GT-R, and the bare bone spec is ideal for the track. Cheers Nardi for sharing this
Nambo is offline   Reply With Quote
Old 10-31-2011, 08:28 AM   #8
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
haha awesome. i believe the non painted bumpers and steel wheels one is for people who want to take it drifting and want their own wheels and stuff. pretty good idea
czar07 is offline   Reply With Quote
Old 10-31-2011, 08:31 AM   #9
Nardi330
Nardi330's Avatar
Drives: 86
A bit like the FD2 Civic Type R where they offered a bare bone car. Only front dash, driver seat (basic style), steering wheel, 4 door trims and nothing else!!
Old 10-31-2011, 08:53 AM   #10
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
So 197hp/151tq in a car that weighs 2662lbs with a nice interior and exterior? Sign me up and take my money Toyobaru.
tranzformer is offline   Reply With Quote
Old 10-31-2011, 08:55 AM   #11
ForReal-Someday
Drives: Company Vehicle
Looks like we might be getting the tuner model after all!
ForReal-Someday is offline   Reply With Quote
Old 10-31-2011, 09:07 AM   #12
86er|n2
Drives: ae86 levin coupe
actually its 2711lbs with the "nice interior"
also note that the nicer ne has what look like steering wheel controls and interior options for red or black and basic ones have only all black clusters with no shift light or digi gauge
I think the 16s look nicer than the 17s that the mule has been running aroun on though
86er|n2 is offline   Reply With Quote
Old 10-31-2011, 09:10 AM   #13
no_name
no_name's Avatar
Drives: 2005 Hyundai Accent
That's on the japanese testing cycle so I'd wait to see what the EPA gives it.
no_name is offline   Reply With Quote
Old 10-31-2011, 09:15 AM   #14
Moolz
Drives: none
Different headlights for the fully specced model ;o
Moolz is offline   Reply With Quote
brz forum, brz forums, brz specs, brz sti forum, fr-s review, fr-s specs, frs review, frs reviews, ft-86 review, ft-86 specs, ft86 forum, ft86 forums, ft86 specs, scion fr-s, scion fr-s forum, scion fr-s horsepower, scion fr-s hp, scion fr-s review, scion fr-s reviews, scion fr-s specs, scion fr-s weigh, scion fr-s weight, scion frs, scion frs forum, scion frs review, scion frs specs, subaru brz, subaru brz forum, subaru brz forums, subaru brz horsepower, subaru brz hp, subaru brz specs, subaru brz sti, subaru brz sti forum, toyota ft-86, toyota ft-86 forum, toyota ft-86 horsepower, toyota ft-86 hp, toyota ft-86 review, toyota ft-86 specs
AutoBild gives specs of the Subaru BRZ Ice_Man BRZ First-Gen (2012+) — General Topics 43 10-30-2011 06:43 PM
Guessing Scion FR-S specs?? dClutch Scion FR-S / Toyota 86 GT86 General Forum 58 04-28-2011 11:07 PM
If there is no Toyota will you go with Scion or Subaru tranzformer Scion FR-S / Toyota 86 GT86 General Forum 91 04-25-2011 11:53 PM
200hp / 2700lbs - Really? Rickster Scion FR-S / Toyota 86 GT86 General Forum 385 04-18-2011 02:47 PM
TRD options and Badging? BanningFT Scion FR-S / Toyota 86 GT86 General Forum 43 11-08-2009 03:53 AM
