Old 01-10-2013, 10:00 PM   #1
Unichip Jack
Unichip Jack's Avatar
Drives: E36 M3, Whiteout FR-S
Unichip MapsQ software
As more guys get into downloading, I’m getting calls with questions about maps and downloading so it’s probably time to start a thread for that.
To remap, you need a download cable… that’s $35 and gets you access to the MapsQ software and the maps library. With access to the library, you can download any map as many times as you want for no cost. Unlike the reflash guys, we’re not selling maps.
The software is so simple, I don’t think there’s any need to go over it… there’s also a FAQ covering it at our website with all of the steps. If somebody has a question, by all means ask and I’ll be happy to answer.
The only thing not obvious with the software is that Map 1 is unique in that if you disconnect the Map switch – or the Flux2 Display, whichever you're using – the Unichip defaults to Map 1. The Unichip doesn’t remain where it was last set… it constantly looks at an input to decide what map to select which is what allows us to switch on the fly.
For that reason, Map 1 probably shouldn’t be anything unusual like the immobilizer map… if you for some reason disconnect the switch or Flux2, you may have a car that won’t start and “why” that is may not be obvious. The Unichip will be doing what it’s programmed to do and prevent the engine from starting, but that may not be what you really want.
There is no right or wrong way to program your maps, but we recommend making Map 1 pretty vanilla and putting the good stuff in Map 2 – 5.
In the next week, we’ll be releasing more mapping options to play with… the maps are all tested; we just need to finish the administrative stuff to get them posted. In addition to the existing maps, we’ll be building map “families” with variations with more ignition timing for cars that want the timing and others with less timing for cars that want less.
Similarly, we’ll post maps that are 0.5 AFR richer and others that are 0.5 AFR leaner for cars with minor stacking tolerance variations that make them either a little leaner or richer than peak power values when running the “typical” maps.
There will be combinations of all of the above… the goal is to offer simple tune tweaks for the best fit for each car out there. With the down load cable, you’ll be able to try any and all and find what works best for your car. It's not a matter of "wanting more" but finding the best values for your car.
More to come…
Unichip Jack is offline   Reply With Quote
The Following 6 Users Say Thank You to Unichip Jack For This Useful Post:
bakerr6 (01-11-2013), Innova (01-11-2013), ScionFrsFan (01-10-2013), TrickyFrenchman (01-11-2013), Wesley (02-14-2013), xcelir8brz (01-11-2013)
Old 01-11-2013, 06:13 AM   #2
bakerr6
Drives: 2013 raven black fr-s
Thanks Jack, this is exactly what I was looking for. I know with the current maps I am running, the tune is about 99.9% perfect on lt and st fuel banks. IATs and of course cooling issues are non-existent also.
bakerr6 is offline   Reply With Quote
Old 01-11-2013, 07:21 AM   #3
xcelir8brz
Drives: 2013 BRZ Limited
Sounds very good.
xcelir8brz is offline   Reply With Quote
Old 01-14-2013, 11:16 PM   #4
Unichip Jack
Today we finished the first Maps Library expansion which will be posted tomorrow. As outlined in the thread’s opening post, the “map families” offer tuning “tweaks” that slightly change the standard tuning solution that may be a better fit to individual cars with minor variations… with a download cable, you’ll be able to try each to find the ones that work best for your car. This is the first step building the families.
Each bolt-on configuration will have 27 different gasoline map variations available. To find your map, the first thing you’ll choose is fuel octane, then fuel tuning, and finally timing tuning. Each selection will open a folder that contains all the follow on options.
Octane. The first folders you’ll find will be the Low, Midgrade, and Premium octane folders. All of the options for a particular fuel octane will be in that folder.
Fueling Options. Inside each Octane folder, you’ll find the second break out which is fuel tuning. You’ll see “Standard Fuel,” “Fuel In,” and “Fuel Out” folders. To really dial in your car, the best bet is using a tail pipe wide band O2 sensor.
Fuel Standard – all maps in this folder have the fueling changes required by a typical vehicle and the chances are really good this is where your map will be. Inside this folder, you’ll find all of the timing options for the standard fuel tuning solutions.
Fuel In – all maps in this folder have a fueling change that is approximately 0.5 AFR richer than the standard fueling solution maps. These maps are intended for vehicles running slightly leaner than the target AFR with the standard fueling solution maps. Inside this folder, you’ll find all of the timing options for the fuel in tuning solutions.
Fuel Out – all maps in this folder have a fueling change that is approximately 0.5 AFR leaner than the standard fueling solution maps. These maps are intended for vehicles running slightly richer than the target AFR with the standard fueling solution maps. Inside this folder, you’ll find all of the timing options for the fuel out tuning solutions.
Timing Options. Inside each fuel folder, you’ll find the last map break out which is ignition tuning. You’ll see “Timing Standard,” “Timing In,” and “Timing Out” folders.
Timing Standard – all maps in this folder have the timing changes required by a typical vehicle and the chances are really good this is where your map will be. Inside this folder, you’ll find the maps for the bolt-on configurations for the previously selected octane and fuel tuning solutions that have the standard timing values. Click on the appropriate bolt-on configuration to load the map into the MapsQ software.
Timing In – all maps in this folder run slightly more ignition timing than the standard fueling solution maps. These maps are for vehicles that can tolerate the additional timing without triggering a flashing misfire CEL, or for higher than standard octane fuels. Inside this folder, you’ll find the maps for the bolt-on configurations for the previously selected octane and fuel tuning solutions that have slightly more timing that the standard map values. Click on the appropriate bolt-on configuration to load the map into the MapsQ software.
Timing Out – all maps in this folder run slightly less ignition timing than the standard fueling solution maps. These maps are for vehicles that get a flashing misfire CEL with the timing standard maps, or for lower than standard octane fuels. Inside this folder, you’ll find the maps for the bolt-on configurations for the previously selected octane and fuel tuning solutions that have slightly less timing that the standard map values. Click on the appropriate bolt-on configuration to load the map into the MapsQ software.
Tomorrow the complete Standard Fuel map folder will be posted with 135 mapping options giving you all of the fuel grade and timing variations for all of the current bolt-on configurations. The next update should be finished and posted in about a week.
More after the IT guys get the maps posted.
Cheers
The Following 2 Users Say Thank You to Unichip Jack For This Useful Post:
swift996 (02-18-2013), TrickyFrenchman (01-14-2013)
Old 01-14-2013, 11:27 PM   #5
Innova
psst... any word on E85? Sorry to keep bugging ya but we're anxious.
2013 BRZ Limited - 6-speed - Namelss, Perrin, Invidia, Unichip.
Innova is offline   Reply With Quote
The Following User Says Thank You to Innova For This Useful Post:
ScionFrsFan (01-14-2013)
Old 01-14-2013, 11:31 PM   #6
ScionFrsFan
lol I just posted that on another page... haha
ScionFrsFan
ScionFrsFan is offline   Reply With Quote
Old 01-14-2013, 11:39 PM   #7
Unichip Jack
Working on E85... like I said, they will take a bit longer because they're a little more involved. As soon as they're final, we'll get the posted I promise.
Cheers
Old 01-15-2013, 06:24 PM   #8
xcelir8brz
Hell yeah!
:-D
Old 01-15-2013, 06:50 PM   #9
youcantseeme24
youcantseeme24's Avatar
Drives: 2013 subaru brz
this is good info.
youcantseeme24 is offline   Reply With Quote
Old 01-15-2013, 09:27 PM   #10
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Hoping the updated library includes true CAIs like VMS, Perrin, and fa20club. The current list only includes short ram intakes as far as I know.
Old 01-15-2013, 11:19 PM   #11
ScionFrsFan
Has anyone installed the software on windows 8?
ScionFrsFan
Old 01-15-2013, 11:46 PM   #12
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
I thought i saw somewhere mentioned that you could create your own maps?
how does this work? is the software free? or that another product?
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
Old 01-15-2013, 11:54 PM   #13
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
With all the different maps etc, i reckon there will need to be a unichip FR-S/BRZ forum. somewhere people can post results.
Old 01-16-2013, 06:22 AM   #14
bakerr6
I have not, but I will. I just need to buy windows 8 first, or go to my dad's house and upload it on there. I had bronchitis and a sinus infection, and now I'm battling other health issues, so I haven't been out much lately to do anything
Unichip map downloads and tuning Unichip Jack Software Tuning 1133 06-30-2023 04:28 AM
Unichip EMS Unichip Jack Engine, Exhaust, Bolt-Ons 300 11-22-2014 03:13 AM
unichip 13 FR-S Veteran Engine, Exhaust, Transmission 9 02-03-2013 11:05 PM
unichip 13 FR-S Veteran CANADA 0 12-03-2012 05:31 PM
Software Gauges shirouxkamui Electronics | Audio | NAV | Infotainment 1 08-12-2012 10:30 AM
