Old 10-18-2012, 12:01 AM   #1
D1cker
Drives: B9 S4/ND2
Question about Whiteline COM-C + KW V3. Video Inside.
Hey Guys,
Just installed the the Whiteline COM-C on some KW V3 (put the com C directly on to the purple top piece on the KW's) When out of the car it rotated 100% freely, but now it seems to be flexing a lot while the car is on the ground and the wheels are turning.
Does anyone else with these know if this is normal or if there is something wrong with my car?
[ame="http://www.youtube.com/watch?v=B-a1mzPcmSM"]White line Com-c + KW V3 - YouTube[/ame]
D1cker is offline   Reply With Quote
The Following 2 Users Say Thank You to D1cker For This Useful Post:
ATL BRZ (10-18-2012), Surok (11-06-2012)
Old 10-18-2012, 05:21 AM   #2
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
That is not normal...
I will not run those Com-Cs due to all the problems I have read about on other forums.
Too bad because the idea is excellent, seems the execution is not there.
uspspro is offline   Reply With Quote
The Following User Says Thank You to uspspro For This Useful Post:
Surok (11-06-2012)
Old 10-18-2012, 05:38 AM   #3
OrbitalEllipses
Drives: Attitude
If you want stiffer front mounts, I believe standard (2002-2007 Impreza) Subaru front Group-N top hats fit. They do not alter geometry in anyway; just a harder durometer rubber.
To embed a YouTube link use the long link format without anything after the video identifier part of the link.
D1cker (10-18-2012)
Old 10-18-2012, 02:26 PM   #4
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
Yeah, shouldn't be doing that. Looks like the rubber insert is moving inside of the mount itself, it should be stationary. When it moves like that it is changing the camber and caster angle...not good.
I would contact Whiteline US office now and offer to send them that video. Whiteline makes a good product and it will only help them to get feedback like this so they can make changes and improvements.
Circuit Motorsports is offline   Reply With Quote
The Following User Says Thank You to Circuit Motorsports For This Useful Post:
D1cker (10-18-2012)
Old 10-18-2012, 02:43 PM   #5
D1cker
Drives: B9 S4/ND2
I emailed Whiteline for help as well. Hopefully I made some sort of installation error!
Old 10-18-2012, 03:25 PM   #6
Racecomp Engineering
You made an installation error. You need a conical washer in there.
EDIT: this is a "Subaru" thing...and anyone packaging top mounts for this car should be aware of it. The OEM upper spring perch has a washer integrated for the brz...however when you switch to coilovers its obviously not there since you are using the coilover perch. The WL top mounts do say to use the OEM conical washer since they were originally designed for GD body impreza and THAT car used the washer as a separate piece. Not having that piece causes all sorts of problems.
- Andrew
Surok (11-06-2012)
Old 10-18-2012, 03:31 PM   #7
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
- Andrew
Can you please elaborate some more and give details on the type and size of washer? My Com-C's were doing exactly what the video shows in this thread, where they were rattling over bumps, deforming rubber, and bearings were notchy upon removal.
Whiteline sent me a new set with good bearings (that I have been reluctant to install) but now I'm not sure if it was the lack of conical washer that killed the bearings and caused all the noise in my original set.
There is no washer included in the packaging, nor do the provided instructions that I have mention using a conical washer, nor have I heard any mention of it officially being necessary until now, before it was just mentioned in phone conversations I had with Myles.
Old 10-18-2012, 03:40 PM   #8
I edited my post above. I'll try to get a pic of the part I'm talking about but I'm in the backseat of a car being driven home from physical therapy typing on a smartphone.
Note: this only has to do with coilovers. If your WL tops are making noise with OEM dampers then they very well could be busted.
- Andrew
Old 10-18-2012, 03:43 PM   #9
ATL BRZ
ATL BRZ's Avatar
Hmmm ok. I have OEM dampers and RCE Yellows. Are you sure a washer wouldn't help OEM dampers? Mine were allowing contact between the upper spring perch and the bottom of the Com-C's, and the rubber was deflecting like crazy just like in the OP's video. I switched back to the OEM top mounts and no issues.
Old 10-18-2012, 03:51 PM   #10
This thread describes the conical washer for GD body Impreza:
http://www.iwsti.com/forums/gr-suspe...uspension.html
For the BRZ and FR-S this part is integrated into the upper spring perch. This means that you need to do something else when you are using a coilover since the OEM upper spring perch is removed. Its a cheap part. I don't have the number memorized or I'd post it.
Again this is for coilovers only and may depend on which top hat you are using.
- Andrew
Old 10-18-2012, 03:56 PM   #11
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by ATL BRZ View Post
Can you please elaborate some more and give details on the type and size of washer? My Com-C's were doing exactly that the video shows in this thread, where they were rattling over bumps, deforming rubber, and bearings were notchy upon removal.
I'll check mine later but I didn't notice it after installing them. I'm using OEM dampers with the COM-C, Eibach springs and OEM spring perch.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-18-2012, 03:58 PM   #12
OrbitalEllipses
Drives: Attitude
All the info you want: http://forums.nasioc.com/forums/show....php?t=1757339
Part Number: 20326AA000
EDIT: Andrew beat me to it, lol.
Old 10-18-2012, 04:09 PM   #13
ATL BRZ
ATL BRZ's Avatar
I'm tempted to get a couple of these and test fit them with OEM dampers on top of welded washer on the upper spring perch and see if this new set of Com-C's will play nice and stay quiet and not bind up. Is that a bad idea? Will I run short on threads with the upper mounting nut?
Sorry for the slight derail.
Old 10-18-2012, 04:15 PM   #14
OrbitalEllipses
Drives: Attitude
I'm tempted to get a couple of these and test fit them with OEM dampers on top of welded washer on the upper spring perchand see if this new set of Com-C's will play nice and stay quiet and not bind up. Is that a bad idea? Will I run short on threads with the upper mounting nut?
See what RaceComp said. The washer should only be necessary for coilovers, not OEM dampers.
+++ALL INVIDIA PARTS FOR FRS/BRZ (N1, Q300, FRONT PIPE) at AMAZING PRICES! +++ genometuning Engine, Exhaust, Bolt-Ons 249 01-17-2015 09:51 PM
Took her to the NASA Auto-X at VMP today! (video inside) xjohnx Tracking / Autocross / HPDE / Drifting 4 08-27-2012 09:54 AM
Engine cutting power after hard cornering... Video inside CSG Mike Engine, Exhaust, Transmission 4 08-21-2012 08:06 AM
Idle RPM dip.... video inside. CSG Mike Engine, Exhaust, Transmission 24 08-17-2012 01:45 PM
My fists are made of hams. Paint help question inside... Mitch Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 07-14-2012 02:05 AM
