Old 10-16-2012, 08:05 PM   #1
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
motul Oil
i changed my stock oil to Motul Oil 0w-20
how often do i have to do an oil change using motul?
thx
Old 10-16-2012, 08:41 PM   #2
David@SPE
Drives: Tonka Truck
Changing the brand of oil doesn't change when you need to do an oil change sooner or later. So at however many miles you normally do your oil change at, keep it the same.
- David
David@SPE is offline   Reply With Quote
Old 10-16-2012, 08:42 PM   #3
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
so i can change my motul oil every 5k?
Old 10-16-2012, 08:47 PM   #4
David@SPE
Drives: Tonka Truck
Yup. Notice a difference with Motul oil compared to factory oil?
EDIT: I just like changing my oil every 5000 miles. Regardless of brand and oil weight.
- David
Old 10-16-2012, 08:48 PM   #5
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Should be fine if you got the 8100, the 300v i would change a little sooner. I did my first with 8100 at 3300 miles and will do the second at 7500, third probably at 12k.
Old 10-16-2012, 08:57 PM   #6
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
- David
yes i do, feels smoother and quitter
Old 10-17-2012, 12:02 PM   #7
bluesubie
Drives: 2004 Subaru Forester 2.5XT
Your warranty allows you to go to 7,500 miles regardless of what brand you use (as long as it meets the proper specs).
You can also get your oil analyzed to determine if it should be changes sooner. Anything else is pure speculation.
http://www.blackstone-labs.com/free-test-kits.php
-Dennis
bluesubie is offline   Reply With Quote
The Following User Says Thank You to bluesubie For This Useful Post:
Voodoo Rufus (10-17-2012)
Old 11-03-2012, 02:24 PM   #8
AJ PwR
AJ PwR's Avatar
Drives: R35 R56 CZ4A ZC6
Send a message via ICQ to AJ PwR Send a message via AIM to AJ PwR Send a message via MSN to AJ PwR
Motul 300V normally can last up to 5000km. For 8100, I would say 5000 miles is about right. If you abuse it often, you might wanna consider change it sooner.
AJ PwR is offline   Reply With Quote
Old 11-05-2012, 05:31 PM   #9
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
I wouldn't worry about the oil too much... as most high quality synthetic oils can easily last up to 5,000+ miles.
Just be regular about changing the filter, and topping off the oil level as needed.
Touge Factory is offline   Reply With Quote
Old 11-12-2012, 08:42 PM   #10
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
I wouldn't exceed the factor interval to maintain warranty validity.
With that said, we have had Motul oil's checked at blackstone and the results are staggeringly amazing. They told one of our customers it was almost as good as new after almost 4000 miles.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
The Following User Says Thank You to AZP Installs For This Useful Post:
flippy (12-07-2012)
Old 05-24-2013, 09:50 AM   #11
regal
Drives: Scion FR-S/Toyota Yaris
-Mike Paisan
Was that the new Motul 300V?
As far as the OCI, I don't see the point in pushing it past the 3500 mile "severe" call-out in the manual. Severe duty is really much broader than people realize. If you have a 1-5 mile commute, you have severe duty because you never burn off the gas that leaks into the oil, if you drive in a dusty area, if you drive in a hilly area, a lot of stop and go traffic. These can all be considered for the recommended 3500 oci. I believe what I read in the manual for this, especially with a brand new unknown track record engine like this.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 05-24-2013, 10:12 AM   #12
AZP Installs
This was in a wrx so we were using the Motul x-clean c3 8100 5w30.
The Motul is good to 7-8k miles in the turbo cars and probably longer in an NA car, however for warranty you always want to make sure to do it on schedule so your warranty isn't effected.
-Mike Paisan
Motul fluids Filipino Royale Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 88 04-20-2014 09:36 PM
1 Day Motul Oil Change Sale, Sat Sept 22 AZP Installs NY / NJ / CT / PA 0 09-20-2012 07:35 PM
Delete driver01 CANADA 5 08-30-2012 04:58 PM
Motul Oil's & K&N oil filter deals! No Limit Motorsport Engine, Exhaust, Bolt-Ons 3 08-01-2012 07:27 PM
Service Parts! Motul Oil / Oil Filters vividracing Mechanical Maintenance and Tools 8 06-20-2012 12:46 AM
