Old 10-11-2012, 02:07 AM   #1
EN2_Squirrel
EN2_Squirrel's Avatar
what fails first
With these absolutely amazing numbers coming out of a stock engine running big boost, what do you all think will fail first?
EN2_Squirrel is offline   Reply With Quote
Old 10-11-2012, 02:13 AM   #2
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
Rods/rod bearings probably.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 10-11-2012, 05:35 AM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
The welds on the intake manifold.
The Following 8 Users Say Thank You to Calum For This Useful Post:
2forme (10-11-2012), cobrabyte (10-11-2012), finch1750 (10-11-2012), FIREISFUN135 (10-11-2012), FreedE (10-11-2012), Jeff86 (10-11-2012), n2oinferno (10-11-2012), sdwztofu (10-14-2012)
Old 10-11-2012, 05:54 AM   #4
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
I wonder if Visconti and ECUTEK can get a "Danger to Manifold" light to come on over the odometer.
Coheed is offline   Reply With Quote
The Following User Says Thank You to Coheed For This Useful Post:
Calum (10-11-2012)
Old 10-11-2012, 05:56 AM   #5
serialk11r
Drives: '06 AM V8V Coupe
Clever clever.
(intake manifold is cast plastic)
The Following 2 Users Say Thank You to serialk11r For This Useful Post:
Calum (10-11-2012), soros151 (10-28-2012)
Old 10-11-2012, 08:59 AM   #6
eikond
Wish Nissan made one
eikond's Avatar
Drives: '13 WRB BRZ Premium
the trap door in the passenger side floor board.. ?
Back on topic.. I think the valves or valve springs will be the first to go. Something in the head is my bet.
eikond is offline   Reply With Quote
The Following 3 Users Say Thank You to eikond For This Useful Post:
cobrabyte (10-11-2012), finch1750 (10-11-2012), ZakD (10-11-2012)
Old 10-11-2012, 09:11 AM   #7
JDMenrique
DEEEERP
JDMenrique's Avatar
im gonna have to agree with this
JDMenrique is offline   Reply With Quote
Old 10-11-2012, 09:14 AM   #8
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
I'm going to agree with that too. The subaru turbo boxers are known for that.
Rayme is offline   Reply With Quote
Old 10-11-2012, 09:19 AM   #9
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
the piston rings. a factory subaru rod is pretty damn strong, for them to fail is very rare.
it's always the piston rings....or the heads will lift, since the motor wasn't designed for the boost.
but what do we know, subaru may have built this thing strong as hell knowing that they failed with the sti's stock block on later models and knowing the aftermarket world was going to turbo the poop out of the car.
VSGTS14 is offline   Reply With Quote
Old 10-11-2012, 09:31 AM   #10
DarkSunrise
DarkSunrise's Avatar
Yeah I agree with this. The ringlands were by far the weak point on the EJ257s. Curious to see if this will repeat itself with the FA20.
The Following User Says Thank You to DarkSunrise For This Useful Post:
winsometang (10-11-2012)
Old 10-11-2012, 09:34 AM   #11
CBR600RR
Drives: Raven Black
i think we have already determined that the clutch fails first. at about 300HP+
The Following 4 Users Say Thank You to CBR600RR For This Useful Post:
EN2_Squirrel (10-11-2012), Jeff86 (10-11-2012), winsometang (10-11-2012), ZakD (10-11-2012)
Old 10-11-2012, 10:56 AM   #12
ANTI_LAG
ANTI_LAG's Avatar
Drives: Ones with Big Turbos
rods
ANTI_LAG is offline   Reply With Quote
Old 10-11-2012, 11:06 AM   #13
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
I saw a thread from Crawford on Facebook, pictures galore. Sorry at work can't link FB right now.
I think the Crank journals will fail first. Looking at the EJ20 versus the FA20 the FA block has less mass around those crank journals. This is where we will see some great detonations from boost.
Spartan65 is offline   Reply With Quote
The Following User Says Thank You to Spartan65 For This Useful Post:
carbonBLUE (10-11-2012)
Old 10-11-2012, 11:06 AM   #14
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Yep... gotta get a clutch to hold the power in the first place. Then you might grenade the tranny or throw rod through block
Jeff86 is offline   Reply With Quote
If the ft86 fails... Sea1monkey2 Other Vehicles & General Automotive Discussions 33 07-16-2011 05:57 AM
Top Automotive Fails of 2009 S2KtoFT86 Other Vehicles & General Automotive Discussions 8 01-28-2010 07:13 PM
