Old 09-07-2012, 01:03 AM   #1
Mcdj18
Drives: Toyota FR-S
Project Kics 15mm P.C.D. Conversion Spacer
Not sure if this has been posted yet...
[ame="http://www.youtube.com/watch?v=O-cl1f4MYzw"]Project Kics 15mm P.C.D. Conversion Spacer - 5x100 to 5x114.3 - 2013 Subaru BRZ - YouTube[/ame]
Mcdj18 is offline   Reply With Quote
Old 09-07-2012, 01:39 AM   #2
gmookher
does not appear to be a hubcentric design. if you can cnc it, I would buy it and pay more for it, if made available. but i'm open minded...how long have you ran them? been tracked?
interested
what wheels fit with the OE studs sticking out? It would compel me to buy them if I hade a few options right off the bat
Old 09-07-2012, 10:38 AM   #3
JC@lutzPerformance
Drives: haggard drift mobile
we have h&r one that are Hub-Centric. Def worth buying the correct ones, this i can say from personal experience, the wheel wobble from running just a spacer is so ridiculous
JC@lutzPerformance is offline   Reply With Quote
Old 09-07-2012, 10:56 AM   #4
Mcdj18
Drives: Toyota FR-S
interested
I am not running this setup. Just found the video and wanted to share the info.
Old 09-07-2012, 02:06 PM   #5
gmookher
Please tell me more, price and avail. Pm me thanks.
Old 09-07-2012, 04:11 PM   #6
phenom86
phenom86's Avatar
Drives: Scion FRS Asphalt
i had the wobble issue when i used ones on my car back in the day but mine wasnt a conversion but to stick my wheels out further cuz i need then wheels to clear cuz i was running something wide.. if you noticed in the video the original studs stuck out far with the conversion installed and with cars using studs vs cars using lug nuts that go into the hub (example A). you will need to have wheels that have deep wells (example B) vs ones that are shallow (example C). If you want to use those conversion without any type of issue trim your original studs to fit the wheels and also use lug nuts with beveled ends to center your wheels without using hub centric rings. I've done it and i never had any issues afterwards.
Example A
Example B
Example C
phenom86 is offline   Reply With Quote
Old 09-07-2012, 04:26 PM   #7
thelegaCy
Drives: cbs brz limited - RIP
so do these work? I have a set of enkei's sitting around that are 5x114.5
thelegaCy is offline   Reply With Quote
Old 09-07-2012, 04:31 PM   #8
empower-auto
Kouki-Monster
empower-auto's Avatar
there's a 10mm KICS version made for this car, will be at SEMA
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 09-07-2012, 04:56 PM   #9
phenom86
phenom86's Avatar
these work but how thick would you want it to be.. if its too thick it will push your wheels out pass your fenders.. check your offset of the wheel then see how thick you can go with the conversion without passing your fender. remember if your wheels are wide already and you used a thin conversion then you should have space for your oem studs to fit in the wheel cavities.
Old 09-07-2012, 05:13 PM   #10
thelegaCy
theyre 18x9 +35... this space would make them 18x9 +20... guess it could work with - camber
Old 09-07-2012, 05:35 PM   #11
RYU
RYU's Avatar
Drives: really slow...
What is the thickness of the H&R and the cost? I may order a set from you.
Also, if you're having problems with wheels wobbling there's something else wrong. Hubcentricity is only of any real concern when torquing down the lugs. All wheels/hubs/lugnuts should be LUG CENTRIC. This is why some rings are even made out of high density plastic. If you have a hub centric setup but still using the wrong taper lugnuts you will still have issues. However, if you have the right taper lugnuts and even w/o hub centric provisions you will be ok (Just make sure you retorque your lugnuts after a few miles).
Of course, a hub centric setup is always preferred but not an absolute necessity.
RYU is offline   Reply With Quote
Old 09-07-2012, 06:12 PM   #12
phenom86
phenom86's Avatar
yeah or you can buy the Rock bunny kit
Old 09-12-2012, 09:08 AM   #13
JC@lutzPerformance
Sorry for the late response
we have 5mm, 15mm, and 25mm.
If you send me your zip code and size, i can get you shipped prices for a pair or set.
Just let me know
Old 01-07-2013, 08:36 PM   #14
Evasive Motorsports
Evasive Motorsports's Avatar
Drives: 2012 FR-S and BR-Z
Send a message via AIM to Evasive Motorsports
Project Kics 10mm P.C.D. Conversion Spacer - 5x100 to 5x114.3 (12x1.25mm) THESE ARE 1 PIECE AND HUBCENTRIC FOR 56MM HUB BORE
Project Kics 15mm P.C.D. Conversion Spacer - 5x100 to 5x114.3 (12x1.25mm) Hubrings are optional.
We have a special with free shipping on on right now.
http://www.ft86club.com/forums/showthread.php?t=25432
-Randy
Evasive Motorsports is offline   Reply With Quote
Spacer how to right in your driveway. F3dzo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 10-22-2013 07:31 PM
Volk, Advan, Gramlights, SSR, Enkei, Project Kics, Muteki - Wheels/Lugs/Spacers No Limit Motorsport Wheels and Tires 25 11-20-2012 04:01 PM
Project Kics/Muteki Lug Nuts! Get them for your new wheels on your FRS/BRZ! IslandImportPerformance Wheels and Tires 0 07-20-2012 04:12 PM
wheel spacer to 5x114 derka-derka AUSTRALIA 12 07-02-2012 11:27 PM
