Drives: 2018 BRZ 6MT
GR86 steering wheel on 1st Gen?
Found a JDM GR86 steering wheel with airbag for sale and was wondering what I'd have to do to get it working on my '13 FRS. It looks extremely similar to the 17-20 wheels so perhaps it is the same process.
Thanks!
#2 |
Drives: Q5 + BRZ + M796
Besides the wheel, you would probably need the angle sensor and clock spring. Maybe more stuff like a subharness.
#3 |
[||•]=(86)=[•||]
Drives: 2017 Toyota 86
The wheel will fit, you won't need any more parts.
For the air bag, your best bet is to find one for a 2017+ Toyota 86 because as mentioned air bag detonator could be different. But the buttons won't do anything since you have a 2013 car. You could find a JDM trim steering trim for the base model 86 2017+, they don't have any button on it.
| The Following User Says Thank You to trueno86power For This Useful Post: | Capt Spaulding (01-11-2022) |
#4 |
Drives: Toyota 86, 2012 Manual.
Old Thread, but replying as I've recently done exactly this to my 2012 GT86.
As with many things ZN8 to ZN6, the steering wheel fits perfectly & is a great upgrade. Only thing to be mindful of is the airbag as mentioned above, though if buying a GR86 wheel from the same region as your ZN6 was originally from, you'll be fine. The connectors from the 2012 clock spring are compatible with the new GR86 airbag, plug n play. No SRS lights or explosions ![]() If connecting a single stage airbag to a dual stage clock spring, you plug the airbag to the yellow connector (Stage 1/ Primary deployment) and a 2.2 ohm resistor to the black connector (Second stage deployment) to keep the airbag functional & avoid SRS lights. *Please do more of your own research and at your own risk if adapting as per above - my GT86 airbag was single stage, so was the GR86 wheel I got, the above is only my basic understanding if it may help anyone* Cruise control stalk is also working perfectly, though you do need to swap over the harness from the old cruise control stalk, to plug into the new one (30 second job) |
| The Following User Says Thank You to nackles For This Useful Post: | whataboutbob (07-02-2025) |
#5 | |
Drives: 2017 GT86
Depending on the particular airbags involved, the inflators aren't always compatible for swapping this way, but between ZN6 and ZN8, I can't imagine it not matching. |
| FS: 2017+ Steering wheel - 2017+ Steering wheels covers | trueno86power | Interior Parts (Incl. Lighting) | 5 | 06-26-2022 05:11 PM |
| Retaining steering wheel controls w/ aftermarket steering wheel on +17 BRZ/86 | DDavid | Electronics | Audio | NAV | Infotainment | 8 | 04-22-2021 05:37 AM |
| Blue carbon steering wheel and steering wheel trim... installed! | Pointmutation | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 02-06-2017 11:20 PM |
| WTB after market steering wheel set up . Steering wheel, hub and quick release. | Vroomin86 | Want-To-Buy Requests | 1 | 11-05-2015 06:44 PM |
| FS: Works bell steering wheel hub, buddy club seat rail, momo steering wheel in Socal | mtsui | Interior Parts (Incl. Lighting) | 5 | 08-11-2015 12:15 AM |
