Old 02-10-2024, 01:34 PM   #1
motrek
Drives: 2018 BRZ
Cruise control turning off by itself for no reason
Like the title says, my cruise control works fine most of the time but once in a while it will turn off for no reason.
My feet and hands are nowhere near the pedals or stalks when this happens.
It works correctly for many/most drives, but when it does turn itself off, it will often turn itself off 2-3 times in relatively quick succession (within the span of 5 to 10 minutes).
This happens during maybe one drive per week. The "SET" light turns off on the dashboard when CC turns off, so that's working right.
The problem is more annoying than anything. (It's a little disconcerting to be tooling along at 70 MPH on a highway doing literally nothing and have the engine cut out abruptly.) I'd rather not pay anybody to diagnose it at this point. Any ideas what might be wrong? Thanks in advance!
motrek is offline   Reply With Quote
Old 02-10-2024, 04:33 PM   #2
sato
sato's Avatar
Drives: Dodge Patitas
I know there are a few circumstances where it won't even activate, triggered by some other ECM event or check engine light, but that probably isn't what you are talking about.
So yeah: have noticed my CC deactivating under unknown circumstances also. No clue whatsoever.
Sent from my XQ-CQ62 using Tapatalk
sato is offline   Reply With Quote
The Following User Says Thank You to sato For This Useful Post:
motrek (02-10-2024)
Old 02-10-2024, 05:18 PM   #3
Grady
Grady's Avatar
Things that will make cruse control turn off:
Brakes
Clutch
Neutral
Traction
Engine code
Probably more
Start by checking those to see if you figure out what one is causing it. My guess is a flakey switch.
The Following User Says Thank You to Grady For This Useful Post:
motrek (02-10-2024)
Old 02-12-2024, 12:14 PM   #4
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
When you engage cruise, try jiggling the clutch or brake in a side to side to see if one of the switches is more sensitive.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
humfrz (02-19-2024), motrek (02-18-2024)
Old 02-12-2024, 07:43 PM   #5
SuperSub7
Drives: Awesome
You can also check for loose connections or frayed wiring in the cruise control system. Vibrations or bumps while driving could cause slight electrical interruptions, leading to the cruise control turning off unexpectedly. Also, the cruise control module can be experiencing some malfunctions and can be affecting the system. Since the problem happens every now and then, it is difficult to diagnose the issue without certain equipment, but you can start by checking parts for any damage or wear.
SuperSub7 is offline   Reply With Quote
The Following User Says Thank You to SuperSub7 For This Useful Post:
motrek (02-18-2024)
Old 09-16-2024, 11:33 PM   #6
motrek
Drives: 2018 BRZ
I've done some searching online and I can't figure out where to even start re: checking the cruise control wiring and components.
Is there a repair manual I need to be looking at?
Is there a computer in the car that logs events, e.g., why the car thinks the cruise control should have been disabled? And if so, what kind of device would I need to read such a log?
Thanks in advance. This problem is getting worse so I appreciate any information.
Old 09-17-2024, 01:44 AM   #7
see manuals link in my sig line
motrek (09-17-2024)
Traction control kicking in when turning right Thecakeisalie Issues | Warranty | Recalls / TSB 28 09-16-2022 02:15 PM
Nexus 7 Volume Control with Cruise Control RavioliG Electronics | Audio | NAV | Infotainment 8 12-06-2016 01:38 PM
Cruise Control nospoons Scion FR-S / Toyota 86 GT86 General Forum 34 06-17-2014 02:28 PM
Cruise control notout86 Scion FR-S / Toyota 86 GT86 General Forum 50 05-13-2013 02:01 AM
