Old 03-05-2023, 02:53 PM   #1
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
Non-Coilovers options for track use
Hi all,
My race team has a 2013 FRS we are running and we currently have rebound/height adjustable MCS Coilovers. One of the series we run (ChampCar) does penalty points based on mods, and these coilovers score us a ton of points and penalty laps.
We are looking for a sort of cup kit alternative that would save us the points for when we run Champ. I don’t see any full kits, so am mostly wondering if anyone here has experience with different shock/spring combos on track.
Thanks!
Flat Black VW is offline   Reply With Quote
Old 03-06-2023, 03:37 PM   #2
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
I don't know a lot about ChampCar rules so is the ride height adjustability the problem? Spring changes? Both? Multiple line items?
Bilsten makes a pretty good OEM replacement shock you could probably get that is non-adjustable to save points, but you'd need to go back to stock springs (or other aftermarket lowering spring) also.
You can then decide if you want to use or not use camber plates etc, but at least you would probably save some points for non-adjustable perches and non-adjustable shocks.
Someone that knows ChampCar rules in here may have some better ways to optimize but those are just a few ideas
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
Kelse92 is offline   Reply With Quote
The Following User Says Thank You to Kelse92 For This Useful Post:
GrandSport (03-20-2023)
Old 03-07-2023, 09:19 AM   #3
M0nk3y
Originally Posted by Flat Black VW View Post
Hi all,
Thanks!
I would contact Jonathan Lugod at Shaftworks and customize a set of non-adjustable valved at the specific rate you're planning on running.
I know personally he's done this for an NA Miata running within Champ and that team has been more than impressed with the change.
Kyle H. - #89 STX
The Following 4 Users Say Thank You to M0nk3y For This Useful Post:
G_Ride (03-10-2023), Kelse92 (03-07-2023), RedReplicant (03-20-2023), strat61caster (03-07-2023)
Old 03-07-2023, 01:37 PM   #4
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
https://shaftworksusa.com
JDMChris is offline   Reply With Quote
Old 03-07-2023, 04:01 PM   #5
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Could you switch perches and springs on the MCS and save enough points to make it worth keeping 'em?
The way the spring rules are written are wild, no idea what they are trying to accomplish other then making replacing sagging springs on an old car with readily available H&R or Eibach springs valid (like old specE30 kits, which got replaced with linear rate springs a few years ago apparently), which like, you're hitting a racetrack, a set of Eibach/Hyperco 2.5" springs are way cheaper then oem style 90mm lowering deals and they can accomplish their goals with just the spring diameter line and remove the rest.
While I'm a happy shaftworks customer seems to me Koni Yellows might be a good choice unless you take significant points for the rebound adjustment and are looking for non-adjustable, which Bilstein is pretty much the only quality option for this car that I know of.
ineedyourdiddly
Old 03-13-2023, 01:44 PM   #6
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Are you allowed a spring change without penalty?
The Bilstein B8+Eibach Sportline spring is an effective combination. Non-adjustable and non-height adjustable.
PRO86 | WTCC | STL
The Following User Says Thank You to rice_classic For This Useful Post:
Kelse92 (03-21-2023)
Old 03-20-2023, 03:56 PM   #7
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
This. Why not just rebuild/revalve/respring OEM to whatever you run your coilovers at?
If that's not allowed, I'd strongly recommend looking into cheating lol. Just spray them with WD40, rub them in a little dirt and paint the springs OEM color. lol
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Too tall in '22 BRZ at first track day - Options? ss600 Tracking / Autocross / HPDE / Drifting 7 07-05-2022 12:41 PM
Powertrain options for track only GrandSport Engine, Exhaust, Transmission 15 06-02-2022 08:39 AM
BRZ/FR-S Suspension Options List (Springs and Coilovers) WingsofWar Suspension | Chassis | Brakes -- Sponsored by 949 Racing 333 02-01-2022 05:32 PM
BLITZ ZZ-R Coilovers - other options? tawheed Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 08-01-2017 03:39 AM
Strut and spring options (not coilovers) firemedic1428 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 01-28-2016 10:59 PM
