Old 09-21-2022, 07:11 AM   #1
bushuangaa
Drives: brz s
Question helmholtz chamber vs popping tune?
Hi fellows, i was looking into this video about welding a j pipe/helmholtz chamber to counter my exhause drones-
the thing with my brz is it's on flashtablet's stage 2 plus with a backfire/popping custom tune.
it's great fun with the poppings of cos.
I'm wondering if adding a j pipe will affect the popping since the exhaust gas will have more pipes to go through and explode in the closed end of j pipe possibly or not?
wonder if anyone tried this 2 mods together??
bushuangaa is offline   Reply With Quote
Old 09-21-2022, 07:35 AM   #2
KillerBMotorsport
KillerBMotorsport's Avatar
There should be no issue with doing this. The J-Pipe is what we have done for drone and if you calculation on size and length are correct, it works very well. No exhaust actually travels through the J-Pipe tube because it's capped. So, it should have little-to-no effect on your pops.
KillerBMotorsport is offline   Reply With Quote
Old 09-21-2022, 07:43 AM   #3
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Before other comments come in about your P/B tune, all I'm going to say is that if you're trying to reduce drone, you should probably try to upgrade our exhaust hangers for JDM ones, switch to OEM front pipe, or upgrade to a double resonated one.
What is your complete exhaust setup?
spcmafia is offline   Reply With Quote
Old 09-21-2022, 10:18 AM   #4
bushuangaa
Drives: brz s
thanks for the reply!
following that youtube video my calculation for the length of j pipe to be 47 inches, i doubt if i have that much space underneath the car haha
Old 09-21-2022, 10:24 AM   #5
bushuangaa
Drives: brz s
i am on psr uel header and perrin 2.5 resonated exhaust.
front pipe is stock.
exhaust hanger upgraded to oem sti ones, it does help to tone down the drone, i will say about 30 percent, still has substantial drone from 2k to 2.6k rpm.
Old 09-21-2022, 11:18 AM   #6
spcmafia
spcmafia's Avatar
Alright, seems like you should have everything to tone down some noise. The JDM ones are a popular choice which I also have too. Haven't really much info on STi ones but before doing any weld work, a cheaper route would be getting the JDM ones. May be some on Ebay because ordering from Nengun or equivalent takes about a month.
Old 09-21-2022, 11:34 AM   #7
bushuangaa
Drives: brz s
they are jdm. part number 44066AJ010
Old 09-21-2022, 01:32 PM   #8
KillerBMotorsport
No problem!
There are other calculators out there. You can trade diameter for length if need be.
Old 09-21-2022, 04:30 PM   #9
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
May want to try sound deadening the trunk area, and under the rear seats.
You really have a setup that shouldn't really drone that much, possibly may be quieter with a nvidia q300 or a hks legamax or something with a bigger suitcase style muffler.
My nameless with a catless uel never droned so the perrin must be louder than others with mufflers
Old 09-22-2022, 09:12 AM   #10
bushuangaa
Drives: brz s
No problem!
really where did u find those calculation? i only see people saying get the j pipe same diameter as the connecting exhaust pipe works the best
Old 09-22-2022, 09:21 AM   #11
bushuangaa
Drives: brz s
for the same exhaust, people seems to have all sorts of experience. i searched and see lots of posts about perrin having drones at our platform despite more users comment them as 'zero drone'.
every car is made slightly different i guess.
looking at the bright side, at least i am hearing less of the random rattles in my brz haha
Old 09-22-2022, 09:41 AM   #12
KillerBMotorsport
It doesn't need to be the same size. It can be smaller, or a tube with a dead end can on it.
Here's one from a quick google search...
https://www.omnicalculator.com/physi...oltz-resonator
The Following User Says Thank You to KillerBMotorsport For This Useful Post:
x808drifter (09-23-2022)
Throttle chamber Trap63 BRZ Second-Gen (2022+) — General Topics 8 12-27-2022 09:55 AM
Velox chamber plates and ride height? BRZHarley Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 09-01-2017 07:06 PM
Helmholtz chamber design differences? Var Engine, Exhaust, Transmission 3 07-25-2017 07:49 PM
FS- ARK mid pipe w/ Helmholz Chamber Jetbill Engine, Exhaust, Bolt-Ons 15 10-12-2015 05:05 PM
DI Popping noise, just installed new updated tune file. Bg8780 Issues | Warranty | Recalls / TSB 21 06-27-2013 11:56 PM
