Old 09-11-2022, 09:19 PM   #1
andyk5
Drives: GR86
Front tire damage in skidpad.
Falken 660 with 5-6 trackdays, 28 psi hot. This happened on a Streets of willow skid pad excersize. I was pushing pretty hard trying to figure out the limits of the car and the tires. Getting a lot of understeer off very tight 180 degree turns. Second gear full throttle coming out of the turn would just push instead of oversteer. I think the speeds were a bit too slow and the weight shift to the back would grip the rear. Dry conditions plus low tire pressures….not the right thing to do on the skid pad. Sheered the thread right off.
Just ordered GT Radial sx2s from Walmart, lets see how they hold up.
https://imgur.com/a/UCdqDnF
andyk5 is offline   Reply With Quote
Old 09-11-2022, 09:27 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
They were starting to delaminate and you kept running them. You can see it starting here. 28psi hot is really low to me. I ran 34-37psi. 5-6 days is pretty good out of a set. I got like 4 days.
Old 09-11-2022, 09:31 PM   #3
andyk5
Drives: GR86
I can’t read tires, what am I looking for? I wanted to decipher what the tire wear was telling me…Like what is delaminate? Is it the thread coming off or the way tire is wearing in a wave pattern?
Edit:Also would more camber (in addition to higher pressures) help here?
Old 09-11-2022, 09:35 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That is a spot we’re you almost wore through the tread and it then pealed a chunk away. Then continuing to run on the tire it caught a spot like that and pulled a chunk of the tread away. Need to check your tires before every session.
Here’s a pic of one of mine.
andyk5 (09-11-2022)
Old 09-11-2022, 09:53 PM   #5
andyk5
Drives: GR86
So lets say I catch it chunking like that, what do I do? Wait for cooler weather, increase pressure?
Old 09-11-2022, 09:56 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Put new tires on, they are done at that point.
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post:
andyk5 (09-11-2022), Icecreamtruk (09-26-2022), Tokay444 (09-12-2022), x808drifter (09-12-2022)
Old 09-11-2022, 11:07 PM   #7
TommyW
TommyW's Avatar
Drives: '13 Whiteout
to induce oversteer (rotate) you need to be braking properly and not accelerating, that will always push. Try that skidpad when they wet it. Use crappy tires with no traction. Skid pad is more car control exercise and not really where you look for the limit.
TommyW is offline   Reply With Quote
The Following User Says Thank You to TommyW For This Useful Post:
Old 09-11-2022, 11:15 PM   #8
andyk5
Drives: GR86
Yeah…I was “trying” to trail brake towards the tight apex and come out on the gas but did not get the result I was looking for. Next excersize was going around the white circles which would have been easier to break loose on but I did not make it that far. Tire shop was closed and the tire stores I called in the Lancaster area did not have anything decent in stock.
Old 09-11-2022, 11:22 PM   #9
TommyW
TommyW's Avatar
get ahold of Nik Romano at Fast Sideways. A session there will be more valuable to you that all the new tires in the world.
Old 09-12-2022, 02:17 PM   #10
CSG Mike
CSG Mike's Avatar
Turn your steering wheel less, coming out of the turn.
You're causing your own push.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
andyk5 (09-12-2022), Icecreamtruk (09-26-2022), SCFD (09-18-2022), TommyW (09-12-2022)
Old 09-12-2022, 03:47 PM   #11
andyk5
Drives: GR86
I think this is very true. The setup was long straight, a car width of entry marked by cones, 180 tight turn marked by cones. I’d be coming in too fast and my steering wheel were usually was beyond 90 degrees and I’d get on the gas at that time….less steering engle would def have more grip.
Will try that next time.
Old 09-12-2022, 03:56 PM   #12
jflogerzi
jflogerzi's Avatar
Why would you be use RT 660's skid pad stuff anyways. Get some cheap tires like you ordered
2013 Series 10 FRS #553
Old 09-12-2022, 04:17 PM   #13
CSG Mike
CSG Mike's Avatar
So that it's a 1:1 translation rather than a close to 1:1 translation.
Old 09-12-2022, 04:34 PM   #14
andyk5
Drives: GR86
This…
also they were close to being done.
Now that I found out about 86Cup, I am going to try to compete in the Stock class, SX2s seem to be ok for stock, cheap and something I can learn on by getting as much track time as possible without breaking the bank as hard.
The Following User Says Thank You to andyk5 For This Useful Post:
CSG Mike (09-19-2022)
Front bumper damage is this repairable? JaeMHC Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 09-05-2020 12:21 AM
tire damage question? Thet Scion FR-S / Toyota 86 GT86 General Forum 12 03-26-2015 03:07 PM
Front bumper damage roosahorn Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 07-27-2014 02:46 AM
Little Front bumper damage tintumz22 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 05-16-2013 02:47 AM
Damage to built up area of sidewall/stock tire. Zadkiel Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 09-25-2012 09:03 PM
