Old 08-06-2022, 04:12 AM   #1
Zer0
Drives: 2015 frs
Vorshlag wheel specs.
Is there any info on the wheel specs Vorshlag used on the wide body frs shop car? I know they went with 18x11 wheels with 315 30 tires on the front and 19x12 wheels with 335 tires on the rear super concave F14s. I just need the offset as it wasn't mentioned. I was going to order a set from Vorshlag but they no longer sell wheels, and ask not to be contacted with wheel questions. Any help would be appreciated. 😊
Zer0 is offline   Reply With Quote
Old 08-06-2022, 06:31 PM   #2
Zer0
Drives: 2015 frs
I was able to locate the rear wheel specs Forgestar F14 super concave 18x12 8.25" backspacing. Now I just need the front wheel specs. Anyone have the info?
Old 08-06-2022, 08:50 PM   #3
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
This set of 18x11s was ordered in the exact same spec as the set we ran in 2019, so we know they will fit. But I had Brad put these on in March of 2021, just to make sure they were made to the spec we sent. These took nearly eleven months to arrive, which is one reason why we no longer sell wheels from this group - nobody can wait that long for custom wheels.
https://www.vorshlag.com/forums/foru...t-thread/page3
so it sounds like 18x11 8.25" backspacing
G-Man is offline   Reply With Quote
The Following User Says Thank You to G-Man For This Useful Post:
Zer0 (08-07-2022)
Old 08-06-2022, 11:44 PM   #4
Zer0
Drives: 2015 frs
Did you see where they said the backspacing on the fronts were 8.25" on the 18x11s ? I was only able to locate the backspacing on the rear. I will look more!
Old 08-07-2022, 12:55 AM   #5
Zer0
Drives: 2015 frs
The numbers they throw around when they were trying to get the 12" wide wheel on the front don't make it easy to figure it out. They stated they used a 38mm spacer and it had 19mm poke but cleared the suspension. Subtract the 38mm reduce the backspacing and you end up with more further out past the flare. I don't think they provide enough precise info to get it right on the money, but they were not trying to give us the info. They were trying to fit what they needed, and write it up as they went. Looks like I will need to buy the tool, and some tires to measure it precisely.
Thanks for trying to help me find the info!
Old 08-09-2022, 01:50 AM   #6
G-Man
G-Man's Avatar
other option is to just ask around here on what rocketbunny fitments people use, vorshlag isnt the only company to do it
Zer0 (08-10-2022)
Old 08-09-2022, 01:52 AM   #7
G-Man
G-Man's Avatar
https://www.ft86club.com/forums/show...ht=rocketbunny
here is the big thread from this site
here is a post that might be useful for you
Zer0 (08-10-2022)
Old 08-10-2022, 08:23 PM   #8
Zer0
Drives: 2015 frs
Unfortunately most Bunny Boyz are show. Their cars look great but wouldn't function well on a road course. Again most, not all. I was able to email Vorshlag and they provided me with the information I was in need of. Going to check out the link you provided as well and check out the setups.
Old 08-11-2022, 08:44 AM   #9
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
I was going to recommend that you contact them directly. Sometimes they can be a bit slow to respond (very busy shop) but usually not too bad and tend to be very helpful.
Now that you have the info, why don't you post it for other people looking in the future?
CrowsFeast is offline   Reply With Quote
The Following User Says Thank You to CrowsFeast For This Useful Post:
Zer0 (08-11-2022)
Old 08-11-2022, 05:06 PM   #10
Zer0
Drives: 2015 frs
I need to make sure they don't mind me sharing the info they spent time and money working the fitment up. I will update as soon as I hear back.
The Following User Says Thank You to Zer0 For This Useful Post:
CrowsFeast (08-24-2022)
Old 08-11-2022, 05:48 PM   #11
Zer0
Drives: 2015 frs
Vorshlag said Its ok to post the specs 18"x11" et33 running 315 30 18s track tested successfully. Rear 18"x12" 8.26"
backspacing 335 tires mounted. Not tested on a track yet. Anyone running those specs? Thoughts, opinions?
vorshlag, wheel, widebody
OEM Wheel specs for 2022 sygfrid BRZ Second-Gen (2022+) — General Topics 4 11-06-2021 11:13 AM
Turbo wheel specs Sloyota Want-To-Buy Requests 5 03-20-2019 09:51 PM
Wheel Specs (RB FRS) ejv_frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 01-11-2016 02:06 AM
help with wheel specs KidRed Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 06-04-2015 05:28 PM
wheel specs? VENOM~ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 10-19-2012 06:41 AM
