Old 06-01-2022, 10:43 AM   #1
SpeBud07
Drives: 2013 FRS
Consensus on Delicious Tuning Coil Packs?
My son and I are starting a build of a 2013 FR-S and we are doing all of the preventative maintenance items to make sure we have a good baseline for things like a JRSC later. I know the 13's seem to have coil issues from what I've read, but there seems to be two questions I have:
1) Do we do the coil pack harness upgrade proactively? I know it's a bunch of work, but I'm not afraid of it per se. Or just replace the coils on an almost 10 year car and call it good.
2) Are the Delicious Tuning high cap coils worth the extra money? I would assume you can get a little more juice in a tune from them, but perhaps negligible?
I tried the search, but didn't have a lot of luck. Thanks!
SpeBud07 is offline   Reply With Quote
The Following User Says Thank You to SpeBud07 For This Useful Post:
alphasaur (06-01-2022)
Old 06-01-2022, 11:01 AM   #2
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
https://www.counterspacegarage.com/i...-86-subaru-brz
https://www.ft86club.com/forums/showthread.php?t=138102
This may work.
spcmafia is online now   Reply With Quote
The Following User Says Thank You to spcmafia For This Useful Post:
SpeBud07 (06-01-2022)
Old 06-01-2022, 11:44 AM   #3
WNDSRFR
Drives: FR-S,GTI
I have a '13 FRS that has gone over 200,000 miles on the original coils. No problems at all ever.
So....
Not all '13's have a coilpack issue.
The Following User Says Thank You to WNDSRFR For This Useful Post:
Teseo (06-01-2022)
Old 06-01-2022, 12:24 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I have almost 100k and dozens and dozens of track days. Have only lost one coil pack when I went to Thunderhill.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
SpeBud07 (06-01-2022), Teseo (06-01-2022)
Old 06-01-2022, 12:55 PM   #5
Teseo
Drives: frs
When the time go for sparkplug change, I may consider to swap coils pack... idk if that make sense or put the money on fuel filter
Old 06-01-2022, 01:34 PM   #6
I'll change plugs and packs when one starts to misfire.
ShadowReaper (01-20-2024), Tcoat (06-01-2022)
Old 06-01-2022, 03:07 PM   #7
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Yeah. Not splooging $850 for four coils.
Seems to be overkill for light duty fun and convenience.
Old 06-01-2022, 04:19 PM   #8
norcalpb
norcalpb's Avatar
170k miles on my 2013 and still on the original coil packs. They seem reliable.
It's not like these cars are older Audis/VWs where it's a prerequisite to carry an extra coil pack or 2 in your car at all times.
The Following 2 Users Say Thank You to norcalpb For This Useful Post:
dynarun55 (04-11-2023), WNDSRFR (06-01-2022)
Old 06-01-2022, 05:39 PM   #9
WNDSRFR
Drives: FR-S,GTI
yeah
Unfortunately I know what you mean.
Capt Spaulding (06-04-2022)
Old 06-02-2022, 06:48 AM   #10
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
I just ended up buying the revised 2015+ coilpacks (~$100 for 4) off of eBay off of a low/medium mileage wrecker and a set of harness adapters.
If I need to buy more coilpacks sooner, I don't mind since it's hundreds cheaper than new or aftermarket
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
norcalpb (06-02-2022)
Old 01-20-2024, 12:00 PM   #11
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
I'm on JDL turbo and I had loss of power past a specific RPM/PSI. Turned out that a coil pack was the issue, went ahead and got new spark plugs while they were there. I honestly didn't even know coil packs were a thing to watch.
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
Old 03-17-2024, 01:10 AM   #12
jflogerzi
jflogerzi's Avatar
just as an fyi 2013-2015 mid way through the MY had an issue with the harness. it mostly affects the front most coil on the passenger side. catless headers and heat is what kills the coil. I have been through a few since tracking the FRS regularly. I can extend the coil pack by use gold foil tape on the exposed part. it helps but still fails. OEM is just fine
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
Old 03-18-2024, 09:52 AM   #13
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
My feeling from what I seen online so all second hand as I have not dealt with it myself is that heat is causing the harness connector to loosen and the coil pack themselves are fine.
You can see when they changed the coil pack harness they added a locking connector I assume this is why.
autoracer86 is offline   Reply With Quote
BRZ, FRS, GT86, FA20, IP Coil Packs FRW-86 Engine, Exhaust, Bolt-Ons 2 06-05-2025 03:32 PM
IP Coil Packs bozack Engine, Exhaust, Transmission 6 03-06-2022 01:36 PM
Knockoff coil packs redlined600 Tracking / Autocross / HPDE / Drifting 22 11-26-2021 04:03 PM
2013 Coil Packs, where did you guys get them from? Keenercarguy Issues | Warranty | Recalls / TSB 24 05-25-2018 08:43 PM
Stock 13/14 coil packs shaynek Want-To-Buy Requests 1 04-26-2018 08:20 AM
