Old 05-19-2022, 07:47 PM   #1
Kulebrero1
Drives: Gr86
Camber plate recommendations
Looking for recommendations for camber plates to go along with a set of RaceComp Tarmac 2 coilovers.
What does everyone use?
Kulebrero1 is offline   Reply With Quote
Old 05-20-2022, 10:39 AM   #2
Racecomp Engineering
We're pretty darn happy with the Vorshlag camber plates paired with Tarmac 2s.
- Andrew
Old 05-20-2022, 11:45 AM   #3
Joon525
Joon525's Avatar
Drives: 2016 BRZ
- Andrew
I will emphatically endorse the Vorshlag plates as well.
Joon525 is offline   Reply With Quote
The Following User Says Thank You to Joon525 For This Useful Post:
Racecomp Engineering (05-20-2022)
Old 05-20-2022, 12:21 PM   #4
marco_mc22
Drives: Toyota 86
My vote goes to Kw, for two reasons:
1) Reliability, since they’re the only plates with a dust boot which cover the bottom part preventing debris and dust to come inside the spherical.
2) Design: they roughly add 15mm of bump travel and the plastic collar between the upper spring perch and the bottom part of the spherical case makes everything super silent and smooth while the strut is turned.
Kw doesn’t sell the pillow ball as a replacement but you can easily buy one from Rodobal.
marco_mc22 is offline   Reply With Quote
Old 05-20-2022, 12:28 PM   #5
Kulebrero1
Drives: Gr86
Thanks for the advice on the Vorshlags. I noticed they are the most expensive top hats I’ve seen paired with Coilovers for the GR86/BRZs. I figured there might be respectable less expensive options.
Old 05-20-2022, 01:04 PM   #6
The KW plates are not sold separately in the USA.
- Andrew
Old 05-20-2022, 01:20 PM   #7
marco_mc22
Drives: Toyota 86
Ups, sorry I didn’t know.
Old 05-20-2022, 02:25 PM   #8
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
I think I originally planned to get raceng plates but due to time/cost I wound up getting Verus camber plates instead. They've been on the car for a couple of years, including winter driving, with no issues yet.
Vorshlag plates were just too expensive and longer shipping/lead time than I was working with at the time.
CrowsFeast is offline   Reply With Quote
The Following User Says Thank You to CrowsFeast For This Useful Post:
Old 05-20-2022, 03:19 PM   #9
dreamwonder
Drives: GR86 2022
Get a set of rce superstreet, save the shocks as backup/down time during rebuild/off season driving etc. That is basically what I did. I used roughly a dozen different camber plates and those KWs is the most I liked.
dreamwonder is offline   Reply With Quote
Old 05-20-2022, 03:30 PM   #10
The Verus plates work well too.
- Andrew
Kulebrero1 (05-24-2022)
Old 05-21-2022, 06:00 AM   #11
54fighting
Drives: 2020 toyota 86
Another vote for Verus
54fighting is offline   Reply With Quote
The Following User Says Thank You to 54fighting For This Useful Post:
Old 05-25-2022, 03:56 PM   #12
CrowsFeast
CrowsFeast's Avatar
- Andrew
Yup, like I said; no problems with a couple of years on them including winter driving.
Old 05-25-2022, 11:03 PM   #13
Kulebrero1
Drives: Gr86
- Andrew
Andrew,
Are you sure the Verus plates fit in the ‘22 models?
Old 05-26-2022, 09:05 AM   #14
Originally Posted by Kulebrero1 View Post
Andrew,
Sorry I was thinking of the first gen. Not sure on 22 models.
-Andrew
Camber plate increments. gen3v8 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 05-19-2022 10:28 PM
FS: KW V3 with Camber plate ChaosTheSlayer Brakes, Suspension, Chassis 6 08-22-2019 12:10 AM
This is how camber affects toe in front. Also RCE camber plate info. Pat Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 05-04-2016 10:08 PM
Issue with camber plate ZionsWrath Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 08-02-2015 05:04 PM
Jrz rs1 no camber plate? CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 09-09-2014 10:16 PM
