Old 04-27-2022, 06:02 AM   #1
jamestemperante
Drives: Subaru BRZ
RPM fluctuating at idle and AC not cold
hello again! hope everyone is doing fine. just want to ask your opinion on this matter. I'm on a red light then suddenly, my AC went out and rpm starting fluctuating. Although, car is fine now, all I did was turn of the AC for a few seconds and then all of a sudden, rpm back to normal at idle and AC went back.
Any idea what went down? thanks!
here is a clip of the rpm fluctuating.
https://youtube.com/shorts/cyWBvdzGuh0?feature=share
jamestemperante is offline   Reply With Quote
Old 04-27-2022, 06:51 AM   #2
tomm.brz
Drives: brz 2017 hksv2
since the very lack of infos about your car, like which year it is or which tune, mods etc, you re getting a generic response as well: it s normal
jamestemperante (04-27-2022)
Old 04-27-2022, 07:40 AM   #3
jamestemperante
Drives: Subaru BRZ
It has a custom ecutek tune. 2013 model NA. it has a blitz intake, agency power headers, nvidia q300. nothing fancy.
Old 04-27-2022, 07:52 AM   #4
tomm.brz
Then if you have a custom tune best is to ask to your tuner, or post here a log of your car idling and fluctuating
if tuner kept same idle settings as stock then it s quite normal to be not so steady when AC turns on and off
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
jamestemperante (04-27-2022), x808drifter (04-27-2022)
Old 04-28-2022, 05:38 AM   #5
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Try cleaning out your throttle body, no idea if this actually works tbh - some people claim it fixed the problem in the comments.
I've experienced similar behavior .. but mine was due to spark plugs, coil packs, and battery due for a change.
But perhaps I should consider cleaning out the throttle body too ..
The Following User Says Thank You to Bonburner For This Useful Post:
jamestemperante (04-28-2022)
Old 04-28-2022, 08:56 AM   #6
jamestemperante
Drives: Subaru BRZ
I haven't change the coil packs, ignition coils but already cleaned my throttle body, changed the spark plugs and battery 2 months ago.
Old 04-28-2022, 08:59 AM   #7
jamestemperante
Drives: Subaru BRZ
idk what went wrong. but the car runs fine now. no rpm dips during idle, only when coming to a stop and AC is on.
Old 04-28-2022, 10:23 AM   #8
Compelica
Compelica's Avatar
Drives: 86 GT
In my experience, internally the ECU needs to learn idling and that can take a lot of driving to get it settled so that could be your cause. However there's no indication on when it has fully learned apart from monitoring the Deposit Loss Flow PID.
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
The Following User Says Thank You to Compelica For This Useful Post:
jamestemperante (04-30-2022)
Old 04-28-2022, 04:45 PM   #9
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
maybe fuel quality or coil packs then
also consider cleaning your MAF sensor
Old 04-30-2022, 01:29 PM   #10
jamestemperante
Drives: Subaru BRZ
rpm drops only when coming to a stop and AC is on. When I'm on a standstill, it doesn't drop.
Old 05-02-2022, 04:30 AM   #11
jamestemperante
Drives: Subaru BRZ
Caught a video of the actual rpm dropping when AC is on.
https://youtube.com/shorts/rXoW_7jf6Wc - AC compressor turning on and off and rpm fluctuating
https://youtube.com/shorts/gWtegwzUUaA - high side of compressor
Old 05-02-2022, 09:37 AM   #12
tomm.brz
... can you post a log of the car doing this ?
Rough cold start idle Tonrogs Issues | Warranty | Recalls / TSB 17 04-30-2022 03:15 AM
Revving after 10 mins idle from cold start Hayer_86 Scion FR-S / Toyota 86 GT86 General Forum 70 03-05-2020 02:39 PM
Idle fluctuating Jmk91 Issues | Warranty | Recalls / TSB 6 12-07-2019 03:09 PM
Will not idle when cold Kris86 Engine, Exhaust, Transmission 5 08-29-2017 09:37 PM
(Spark?) Knock on cold start idle nickw14 Software Tuning 0 04-07-2015 12:41 PM
