Old 04-13-2022, 11:02 AM   #1
larryt
Drives: 2018 BRZ
Track Pad Swap Question
I will be using a track specific pad for the track and a street pad for daily use. When I remove the track pads is it important to be sure they go back in the same position (drivers vs. passenger side/inside vs. outside of caliper) when reinstalling for the next track event? I assume it does not matter, but would rather be sure.
larryt is offline   Reply With Quote
Old 04-13-2022, 12:38 PM   #2
Autoxer62
Related question - is there a specific bedding in process to follow when switching pads?
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace
Autoxer62 is offline   Reply With Quote
Old 04-13-2022, 01:19 PM   #3
jflogerzi
jflogerzi's Avatar
Yes you should try to label them so you know which caliper and position inner or outer but its not 100% required.
Try to stick with the same compound for street and Track. Example I use Carbotech 1521's for street driving (100% quiet) and switch XP10's/8's for track driving and never need to re-bed.
But if they are different manufactures or pad materials you will/want to bed the pads in each time or risk not getting optimal brake feel/stopping power
2013 Series 10 FRS #553
Old 04-13-2022, 04:12 PM   #4
Autoxer62
Thanks, sounds like just normal bedding, not some tricky cleaning process prior to swapping the pads. Just need an extra day or so rather than switching at the event.
Old 04-14-2022, 02:15 AM   #5
CSG Mike
CSG Mike's Avatar
Base calipers? Yes, because the outer pad will tend to taper more than the inner.
andys_garage (05-13-2022)
Old 05-09-2022, 11:54 PM   #6
einars
Drives: 14FRS
planning on doing the same, what can I swap to if I'm using stock brake pads (first gen frs)?
einars is offline   Reply With Quote
Old 05-13-2022, 08:50 AM   #7
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
We did a couple videos on this topic...hopefully these help. These methods will work on any pads and discs once you understand the underlying concepts.
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
The Following User Says Thank You to JRitt For This Useful Post:
Question on a WRX FA20 swap into a FRS Stoll_It317 Engine Swaps 6 07-27-2017 05:33 PM
WK V3 - Spring Swap Question Stang70Fastback Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-18-2016 08:29 PM
LSx engine swap for track use, thread foodman Tracking / Autocross / HPDE / Drifting 77 03-16-2015 03:23 PM
Engine swap question koyv90 Engine, Exhaust, Transmission 4 03-22-2012 01:08 PM
Headlight Swap Question nogaroblues4 Scion FR-S / Toyota 86 GT86 General Forum 9 02-07-2012 02:45 AM
