Old 04-09-2022, 07:56 PM   #1
radroach
Drives: car
Undertray flange bolts question
Question regarding reattaching bolts on the fiberglass undertray on a 2013 BRZ. There are a number of 10mm flange bolts that are used in reattaching the undertray and they don't seem to go in all the way, they stick out. I could keep turning the bolt and try to press it in further, but I want to see if that is the right way to do it, or if I'm going to strip the threads? If I'm supposed to keep turning the bolt until its pressed all the way in, let me know!
Old 04-09-2022, 08:27 PM   #2
Spairo
Drives: 2013 FR-S 6 spd in Halo
There are two different size bolts under there. Make sure that you have the right bolts in the right holes. They should thread in completely with only your fingers.
Sent from my SM-G950U using Tapatalk
Spairo is offline   Reply With Quote
Old 04-10-2022, 08:33 AM   #3
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
What size are the 2 bolts ive lost a few over the years and could use a few more
Old 04-10-2022, 11:09 AM   #4
Spairo
From memory, the heads are 10 and 12mm. I do not know the thread pitch and diameter.
Old 04-10-2022, 03:38 PM   #5
The bigger M8 ones come loose. I just went to the dealer and bought a bag of new ones. A bit of blue loctite helps.
Old 04-10-2022, 04:08 PM   #6
Joon525
Joon525's Avatar
Drives: 2016 BRZ
For the aluminum panel and fiberglass (?) panel there are 4 different types of fasteners.
Aluminum panel
  1. 12mm flange bolts - 901000413 - 8 of them
  2. Plastic rivets - 56411CA000 - 6 of them
Fiberglass panel
  1. 10mm flange bolts - 901000344 - 7 of them
  2. 10mm bolts - 10006167 - 4 of them (these actually attach the two panels)
All the bolts are silver in color.
From the looks of your picture, you have the wrong ones.
Joon525 is offline   Reply With Quote
The Following 2 Users Say Thank You to Joon525 For This Useful Post:
Breadman (04-11-2022), BRZ FTW (08-29-2022)
Old 04-10-2022, 04:12 PM   #7
radroach
Drives: car
lol yes looks like I've done it wrong..
I snapped most of the 10mm bolts off into the frame..
I think that someone willing should do a proper "how to disassemble and reattach which bolts goes where" video. (please don't post the diagram I've seen them)
Old 04-10-2022, 04:19 PM   #8
Joon525
Joon525's Avatar
Drives: 2016 BRZ
I've snapped 2 in the frame too. I got them out with this.
You have to take your time and drill STRAIGHT.
Wear goggles too because a bunch of shavings will fall right on your face.
I was JUST under the car this morning, I would've taken pics had I seen this before but to help you out.... I don't think it's necessary though since my original reply already tells you which ones go to which panel and if you click the hyperlinks there are pictures of the bolts but anyway...
The green circles are for the first list item in my original post's "Aluminum panel" section.
Blue circles are for the second list item in my original post's "Aluminum panel" section.
Red circles are for the second list item in the "Fiberglass panel" section.
And the rest is easy to figure out by process of elimination.
The Following User Says Thank You to Joon525 For This Useful Post:
radroach (04-11-2022)
Old 04-11-2022, 07:32 AM   #9
Breadman
Breadman's Avatar
Aluminum panel
Fiberglass panel
coming in clutch. thanks
Undertray Bolts Part #'s and/or sizes smbstyle Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 03-15-2017 07:55 PM
Need to get a Catback doughnut flange (Just the flange), but where??? Kostamojen Engine, Exhaust, Transmission 11 04-12-2014 09:10 PM
Camber bolts question AceNiNe Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 08-14-2013 09:50 AM
Borla UEL flange, more in common with a pretzel then a flange. Adeets Engine, Exhaust, Transmission 13 04-12-2013 05:38 PM
Exhaust MP/FP (flange/spring bolts) install help! rbizzle004 Engine, Exhaust, Transmission 9 03-04-2013 11:34 AM
