Old 03-03-2022, 12:54 AM   #1
Garvin29
Drives: Subaru BRZ limited 2015
450 Whp possible with 12.5:1 compression
I am putting together all the parts for my engine, but the piston decision is complicated, my goal is 400+whp, my turbo is an EFR6258 and the E85 option does not work for me. I don't have e85 nearby and I don't want to rely on e85. I just wanted to know if it's not crazy or which one do you recommend for this goal.
Garvin29 is offline   Reply With Quote
Old 03-03-2022, 05:41 AM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Maybe?
I've yet to see anyone actually try High Comp boost with those numbers.
Most are too afraid to try and find out, cause it it doesn't work it's wasted money or worse.
I'd say get a stroker kit to help.
Old 03-03-2022, 07:20 AM   #3
tomm.brz
Drives: brz 2017 hksv2
to me that s not possible on 93oct and stock compression, even if you install a super huge turbo to keep charge temp down and it would anyway have an extreme lag
you'd want something like 10:1 with normal fuel to reach those hp, and a big turbo
tomm.brz is online now   Reply With Quote
alphasaur (03-03-2022)
Old 03-03-2022, 09:24 AM   #4
cpierr03
Drives: 2022 BRZ
Too much for pump gas imho, you'd need E85, C16, or meth injection to reduce knock.
EFR6258 is going to produce a ton of heat making 400+ whp
cpierr03 is offline   Reply With Quote
Old 03-03-2022, 09:42 AM   #5
86TOYO2k17
Drives: 2017 toyota 86
Get some meth
Old 03-03-2022, 01:00 PM   #6
p1l0t
p1l0t's Avatar
On a stock block or one of those HKS jobs?
Old 03-03-2022, 03:03 PM   #7
Garvin29
it is a stock block, I was thinking that maybe with an increase in displacement it could be possible
Old 03-03-2022, 03:05 PM   #8
Garvin29
I could actually play it safe and go down to 10.5:1 but I really like the efficiency and the lag can't be giant
Old 03-03-2022, 03:21 PM   #9
Garvin29
Originally Posted by 86TOYO2k17 View Post
Get some meth
Now that I think about it, meth can be more easily adapted to what I'm looking for, I'll put it among the options, the problem is that with strong movements it may fail.
Old 03-03-2022, 03:26 PM   #10
Garvin29
Has anyone achieved something similar?
Old 03-03-2022, 03:38 PM   #11
Grady
Grady's Avatar
Possible yes, longevity no.
The Following User Says Thank You to Grady For This Useful Post:
p1l0t (03-03-2022)
Old 03-03-2022, 04:15 PM   #12
p1l0t
p1l0t's Avatar
Sounds like about 400hp is the most you want to do on a stock block. (If you want to drive it more than once or twice)
According to https://www.ft86club.com/forums/showthread.php?t=38494
Old 03-03-2022, 04:55 PM   #13
CSG Mike
CSG Mike's Avatar
Possible? Yes.
How deep are your pockets?
You're gonna need race gas if you don't want to do e85.
p1l0t (03-03-2022), Poogchomp (03-03-2022)
Old 03-03-2022, 08:29 PM   #14
tomm.brz
if he doesn t want to rely to e85 that he could get on the street, it seems to me useless to propose racegas.. and with 93 oct those hp and stock compression are not possible
BRZ engine compression 13.5:1 or 12.5:1? mangler BRZ Second-Gen (2022+) — General Topics 2 12-05-2021 05:16 PM
Lowering compression Boris_Petrov Forced Induction 3 01-19-2019 05:19 AM
compression+boost? subatoy Forced Induction 74 01-30-2015 04:32 PM
Low compression? Venator Engine, Exhaust, Transmission 4 06-17-2014 10:37 AM
Low Compression - 10:1 // 9:1 1086 Engine, Exhaust, Transmission 12 12-13-2013 05:46 PM
