Drives: Fr-s
Knockoff coil packs
Has anyone tried non-oem coil packs? Do they have a shorter lifespan than the OEM parts?
Normally an OEM part is the path I would take here but as fast as they go out I'm wondering if having a NEW knockoff is better than a used OEM part in this case. Ebay Coilpacks Even cheaper
#2 |
Drives: Crapcan
I dunno about those cheap ones. I am running an NGK coil pack in my car that was about 65 bucks I think. It has been good for quite a few years.
#3 | |
2013 Series 10 FRS #553
#4 |
Drives: GR86 2022
I use to replace oem coilpacks often, like every 6 to 8 ish track days. Till I bought some eBay ones...forgot what they are but it's blue. 40+ days so far still no issues. This is on a 2013.
#5 |
Drives: GR86 2022
Looked it up.
Benchmark Legacy 2.0 FA20 Performance Ignition Coilpacks FK0438 Full Set 2015> |
| The Following 2 Users Say Thank You to dreamwonder For This Useful Post: | DarkSunrise (05-24-2021), Lonewolf (05-24-2021) |
#6 | |
Drives: 2013 FRS, 2024 Trueno
I had the idea to switch to the 2015+ coils using the ice fab pigtails or buying the parts separately. Would still have to add the price of coils on top of these connectors. https://www.icefabrication.com/produ...grade-to-2015/
#7 |
Drives: Fr-s
Were you able to find these for the 2013-2014? Ebay only lists the 2015+
#8 |
Drives: GR86 2022
Oh yea, I recall now. It was the wrong connector, so I texted the guy and he sent me the ones with the correct connector for a 2013 FRS. Maybe text the ebay seller and see what he can do.
Seller: we-want-great-feedback Price paid for 4: $170 |
| The Following User Says Thank You to dreamwonder For This Useful Post: | redlined600 (06-03-2021) |
#9 |
Drives: 2014 Scion FRS
Off the Line Performance just recently released their OTL Street Series Ignition Coils that I would call an OEM+ replacement. They're not going to be as cheap as the ebay ones, but they're less expensive than the OEM ones.
They've sent me a set that I'm going to test out on my track car. They're supposed to output 10% more power as well. |
| The Following User Says Thank You to thekevinvo For This Useful Post: | Lonewolf (06-04-2021) |
#10 |
Used my last replacement coil at the track this past weekend. So I found the listing for the 2013-2014 coils and ordered a set. Same seller as dreamwonder, they sent a PM to confirm the connector type. Price was $172+shipping.
#11 |
The Stig's German cousin
At Spring Nats we used whatever generic part we could get from Napa to replace a failing coil. It was less than $120 after tax. No idea how good the part is but it appears to generate spark at the appropriate time.
| The Following User Says Thank You to renfield90 For This Useful Post: | CrowsFeast (10-13-2021) |
#12 |
Well its been about 4000 miles and the coil from cylinder 1 is failing. I've contacted the seller so we will see what happens.
#13 |
Drives: Fr-s
These were the blue benchmark coils mentioned above?
#14 | |
Sent from my Pixel 5a using Tapatalk
| coil packs Replacements OEM or Aftermarket | jflogerzi | Tracking / Autocross / HPDE / Drifting | 76 | 10-05-2022 08:47 PM |
| IP Coil Packs | bozack | Engine, Exhaust, Transmission | 6 | 03-06-2022 01:36 PM |
| 2013 Coil Packs, where did you guys get them from? | Keenercarguy | Issues | Warranty | Recalls / TSB | 24 | 05-25-2018 08:43 PM |
| Stock 13/14 coil packs | shaynek | Want-To-Buy Requests | 1 | 04-26-2018 08:20 AM |
| Do I have bad coil packs or a failing DI pump? | xkalelx | Forced Induction | 16 | 03-15-2016 01:56 PM |
