Old 05-21-2021, 09:27 AM   #1
dinfern22
dinfern22's Avatar
Drives: 2016 Scion FR-S(Halo)
Replace a single tire?
Hey everyone, hope all is well!
I have 3 HP Primacy tires that have not been used for a while and I wanted to put them back on my car, but I have a bit of an issue.
I initially put away the tires after one tire blew out, and replaced them with PSS, but now those are worn. The HP's have only been used for 1 year and only have ran about 5-10k.
My question is, can I put a single new HP Primacy tire with the rest or will that affect the treading etc. I was thinking about buying a used tire, but now I don't feel safe using a used tire.
Here are the 3 tires...Will they be ok with a single new tire?
dinfern22 is offline   Reply With Quote
Old 05-21-2021, 10:14 AM   #2
Vital
Drives: 2015 BRZ
It'll work just fine. Id be more worried about those other 3 tires since they might be getting old, i guess it would be alright since you didnt really use them much.
Old 05-21-2021, 10:29 AM   #3
dinfern22
dinfern22's Avatar
Great thanks!
Is that really a cause for concern, what could happen to tires that haven't been used in a while?...Because these 3 tires have been sitting in the backyard shed for around 4 years now.
Old 05-21-2021, 10:34 AM   #4
Transport3r
Drives: -
Originally Posted by dinfern22 View Post
Great thanks!
Rule of thumb is that tires lose a significant portion of their grip after ~6 years of being made, and after 10 years they should be replaced regardless of thread wear.
I personally don’t use performance tires at all after they reach 6 years.
Check for the date stamp on them, if they’re older than 2016 I’d toss them.
https://m.tirerack.com/tires/tiretec...e&gclsrc=aw.ds
Transport3r is offline   Reply With Quote
The Following 2 Users Say Thank You to Transport3r For This Useful Post:
dinfern22 (05-21-2021), Vital (05-21-2021)
Old 05-21-2021, 10:37 AM   #5
KMA KiCKz
Certified Wumbologist
KMA KiCKz's Avatar
Drives: 2015 Scion FR-S
Might want to get a used one with almost the same amount of tread life left, if possible.
If you buy a new tire, you'll be stuck with a single one once it is time to replace the old set but you could keep it as a spare just like your previous incident.
Based on the pictures, them tires still got a good amount of life left on them.
It would depend on how they were stored. Were they garaged or left outside in direct sunlight?
- My 2015 Scion FR-S OEM+ Build Thread -
TRD | Brembo | RAYS
KMA KiCKz is offline   Reply With Quote
The Following 2 Users Say Thank You to KMA KiCKz For This Useful Post:
dinfern22 (05-21-2021), Transport3r (05-21-2021)
Old 05-21-2021, 10:53 AM   #6
Transport3r
Drives: -
Doesn’t really matter. Exposure to oxygen is what ages the tire compound. Unless they were sealed in vacuum bags, they’re more or less done after 6 years.
dinfern22 (05-21-2021), KMA KiCKz (05-21-2021)
Old 05-21-2021, 10:59 AM   #7
dinfern22
dinfern22's Avatar
Shoot! Looks like it says 2015. Is there any chance it's safe to use? Money is kind of tight right now...
Old 05-21-2021, 11:00 AM   #8
dinfern22
dinfern22's Avatar
It was left in the shed in the backyard for about 4 years, so no light. Never touched once they were taken off.
The Following User Says Thank You to dinfern22 For This Useful Post:
Old 05-21-2021, 11:30 AM   #9
KMA KiCKz
KMA KiCKz's Avatar
I forgot about how oxygen could be a factor, thanks for mentioning it.
It might be best to play it safe. Better to spend money on new rubber than to be in an accident due to old tires.
TRD | Brembo | RAYS
The Following User Says Thank You to KMA KiCKz For This Useful Post:
Old 05-21-2021, 11:32 AM   #10
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
I don't see any signs of dry rot so I'd say you'll be ok. The tires don't look too worn either so the one new tire shouldn't have that much of a difference in circumference (which I think is where the recommendation to always change at least 2 tires at a time comes from). That said; I'm just some guy on the internet.
CrowsFeast is offline   Reply With Quote
Old 05-21-2021, 11:35 AM   #11
Transport3r
Drives: -
Most sources will tell you 10 years is the maximum you should be running, I’ve noticed that tires between 6 and 10 years old are more unpredictable then before. I wouldn’t say 2015 tires are unsafe, just realize they may behave differently at the limit and the limits will be lower. Better than running a set of $60 tires that’s for sure.
Old 05-21-2021, 11:37 AM   #12
Transport3r
Drives: -
Oh, and put the new tire on the front, just in case there is a small difference in rolling diameter between the old tires and new tires, your LSD won’t have to deal with it.
The Following User Says Thank You to Transport3r For This Useful Post:
Tcoat (05-21-2021)
Old 05-21-2021, 12:06 PM   #13
Transport3r
Drives: -
Originally Posted by beltax90 View Post
@ 5:01
Yea sunlight and heat will quicken the process too, and dry the tire out. Modern tires are pretty resistant to that though, they have a molded-in dressing/conditioner that ‘sweats’ out of the tire over time and protects the surface of the rubber. That compound sweating out is what makes tires look brown after a while.
beltax90 (05-21-2021)
Old 05-21-2021, 01:00 PM   #14
Just inspect the tires. If they still look and feel fine they will be. There is not a drop dead date on them. I have seen 6 month old tires I wouldn't touch and 10 year old ones that were still perfect.
Keep in mind that the different tread and wear patterns, stiffness and other variances between makes have been know to play havoc with sensors and the diff!
EDIT: As Trans said and I just noticed.
dinfern22 (05-21-2021), soundman98 (05-22-2021)
Stripped a screw where the tire lug nut goes, how much does it cost to replace? btan219 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 02-23-2019 02:00 PM
Flat tire...replace or plug? Fugazi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 11-11-2018 11:24 AM
Should I replace or repair a new tire? cat94 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 12-13-2016 01:23 PM
Replace Only 1 Tire? / Spare Tire Question chermo12 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-28-2015 01:44 PM
Replace one blown OEM tire or upgrade to Super Sport? Yellow_Jacket Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-23-2013 09:33 PM
