| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2020 BRZ rs
Eliminating torque dip
Is it necessary to swap out stock header to address torque dip or can a tune alone do the trick? I prefer to have a cat for sound and environmental reasons.
| The Following User Says Thank You to BitusB For This Useful Post: | jcw99 (03-16-2021) |
#3 | |
Drives: 2018 Subaru BRZ
The headers do help decrease most of the torque dip. A tune can also help, but preferably with the help of a new header. Or like the comment above, boosting resolves that too. It all depends on what application you plan on sticking with (NA/Boost). If you add a turbo, you'll have to change the headers anyways. You can get for example, a JDL UEL/EL and be able to add a SC without replacing the headers.
#4 |
Drives: 2013 WRB BRZ
#5 |
Drives: Crapcan
E85 tune will do it if you have E85 available.
| The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post: | BitusB (03-11-2021), Dzmitry (03-11-2021), Lantanafrs2 (03-11-2021), p1l0t (03-11-2021), spike021 (03-11-2021) |
#6 |
Drives: 2018 BRZ
My understanding is that removing the cats (either with an aftermarket header or by decating the OEM one) is what allows the tune to improve the torque dip. On top of that, the 2017+ engine changes make the tune+header less noticeable vs. the pre-2017 models.
#7 |
Howdy
Drives: 2020 BRZ PP
Catless header and tune. Like 80% gone and for sure noticeable driving round town
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
#8 |
friendly
Drives: 17' 86
I run a catted header (ft86 speed factory) with a tune from Mike @Xero-Limit and I don't seem to have the dip anymore.
Seek comfort in discomfort.
#9 | |
Drives: 2018 Subaru BRZ Limited with PP
A tune alone will improve power all around a bit, but will still give you the torque dip feeling, just improved. A header and tune gives the feeling of a smooth torque curve, AKA dip eliminated. |
#10 |
Drives: Red 2019 Subaru BRZ
You can easily eliminate the torque dip, by staying above it. When you drive the car seriously you will never see that dip.
I dunno, kids these days.
| The Following 3 Users Say Thank You to PenGun For This Useful Post: |
#11 | |
Master Collaborator
Agreed. Other than the first gear dip, you can keep the revs up high and never get back into that dip. Downshift when needed and when you should, and you won't have to worry about it. That dip is there to remind you that these engines are a balance between decent performance and good fuel efficiency. Perhaps the OP should consider an automatic only 2.0 liter Supra instead of a twin. |
#12 | |
Drives: 2013 frs red
| The Following User Says Thank You to Lantanafrs2 For This Useful Post: | MuseChaser (03-12-2021) |
#13 |
Some headers will put a torque hump where the dip was. I personally prefer to drive above 4500 rpm and replace the short block every year. I also masturbate with a shoe rasp in my ass and wear my shoes on the wrong feet.
| The Following User Says Thank You to Lantanafrs2 For This Useful Post: | alphasaur (03-11-2021) |
#14 | |
friendly
Drives: 17' 86
| Tags |
| torque, torque solution, tune |
| Calculate torque when using a crows foot on torque wrench | BirdTRD | DIY (Do-It-Yourself) Guides | 0 | 10-11-2015 04:02 PM |
| Requested torque and Calculated torque | nickw14 | Software Tuning | 3 | 06-13-2015 04:09 AM |
| Torque Pro | sav | AFRICA | 33 | 08-27-2013 07:31 AM |
| What torque dip? | pdreams | Engine, Exhaust, Transmission | 44 | 11-12-2012 06:56 PM |
| Torque App | ZetaVI | Other Vehicles & General Automotive Discussions | 4 | 12-02-2011 12:22 AM |
