Old 12-31-2020, 02:31 PM   #1
Scoob
Scoob's Avatar
Drives: 2013 FR-S Asphalt
Question Installing Spec-D fog lights
Hi all,
I finally got some fogs for my FR-S but the wiring harness they sent with their kit is different from that shown in their video and written instructions. The wiring now appears to be geared toward using under-dash sources instead of wiring directly off the battery under the hood. I do not work with electricity very much so I'm not confident how to wire the always on 12V and the ACC. I found an ACC wire I can tap into but I'm not as confident about the always-on side of the equation. Can I just tap one of the unused hot fuse ports for that connection? Do I need to install a fuse along with it if I do that? I don't want to melt or blow up anything and they're out of the office (apparently - there's no message) and I want to finish it this week while I have the time.
Thanks, Scott
2013 FR-S Asphalt Grey
HKS Hipermax IV GT
Sparco Assetto Gara MGC 17x7.5
Invidia N1 exhaust
Scoob is offline   Reply With Quote
Old 01-23-2021, 10:40 AM   #2
Scoob
Scoob's Avatar
Bumping back up. They are not responding to any messages and not answering their phone. Sad that they may be struggling, but meanwhile I have partially installed lights but no power (and a missing cover). I'm amazed that they did not include revised instructions to go along with their revised wiring harness. Anybody?
My only option to not screw up according to my limited knowledge is to wire a separate hot wire back out through the firewall directly to the battery so it's wired mostly like the original design but with the relay inside the car. Thoughts on that?
HKS Hipermax IV GT
Invidia N1 exhaust
Old 01-23-2021, 01:12 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
a diagram/link to what they say, and/or what you did would really help
Old 01-23-2021, 05:48 PM   #4
Scoob
Scoob's Avatar
What they have on their website is this: https://specdtuning.com/content/Spec...ion%20FR-S.pdf
But those install instructions are from before they had the OEM-style switch. Once they changed over to that switch, they now have a big connector that can't fit through the firewall so the entire harness is completely different. And since it's one big harness, it must be designed to be under the dash instead of under the hood. That means all of those instructions are now useless and I now have both the 12V hot and the ACC hot under the dash - unless I run an (unsupplied) extension wire through the firewall to the battery.
Right now, I only have the blue extension wire from the light harness running through the firewall inside to its mate on that harness. I found a few Acura and Honda install instructions on their site that utilize this type of harness and they show tapping into the 12V hot and ACC hot wires on a nearby harness. I tried that today but those stupid tap clips either didn't do the trick or I missed my target.
Instead of tapping those wires, can I use either unused fuse box ports or share a few of already-used ports in that fuse box? Without shorting out or burning down my car?
HKS Hipermax IV GT
Invidia N1 exhaust
Old 01-23-2021, 10:13 PM   #5
soundman98
soundman98's Avatar
it's been a while since i've looked at the fuses. i specifically recall that unused GM and Chrysler fuse ports don't have any wiring at them(from trying to do something similar), and want to say that these cars are the same.
but you should be able to use an 'add-a-fuse' in one of the accessory fuse locations to get the power you need.
Scoob (01-24-2021)
Old 01-24-2021, 08:55 AM   #6
Scoob
Scoob's Avatar
Thanks for that. I’d seen add-a-fuse mentioned before but I’d never looked at it until your message. Looks like I should be able to add a few of those since there are, indeed, several locations wired and hot. Any ideas on what fuses to add for the fogs? I wish Spec-D would answer these questions...
HKS Hipermax IV GT
Invidia N1 exhaust
Old 01-24-2021, 01:58 PM   #7
soundman98
soundman98's Avatar
according to the diagram i'm looking at here:
https://tinkerine.com/topic/lb/234/brz-fuse-box-cover
the radio, ecu acc, or gauges should be applicable. you can check the seat heater spots, to see if a fuse is setup to go there as well.
Old 01-29-2021, 08:45 PM   #8
Scoob
Scoob's Avatar
Woo hoo! Add-a-fuse worked perfectly. Thanks for all your help.
HKS Hipermax IV GT
Invidia N1 exhaust
The Following User Says Thank You to Scoob For This Useful Post:
soundman98 (01-29-2021)
Installing nur spec wing carlovestela Cosmetic Modification (Interior/Exterior/Lighting) 4 05-18-2018 05:15 PM
Installing/Wiring Spec-D FRS lights into my Subaru BRZ subtledriver Cosmetic Modification (Interior/Exterior/Lighting) 14 04-28-2018 01:53 PM
Need urgent help installing the Spec D headlights up and running. aznknightz17 Cosmetic Modification (Interior/Exterior/Lighting) 2 07-16-2014 02:17 PM
Crap lights on my dash after installing coilovers. Eelusive BRZ First-Gen (2012+) — General Topics 43 02-12-2014 01:08 PM
