Old 10-05-2020, 12:26 AM   #1
av8rdav
av8rdav's Avatar
Drives: 2015 Subaru BRZ Limited no mods
2015 BRZ rear suspension problem
Bought this car a month ago with 41000 miles. It handled great. No problems.
Now all of a sudden the traction control or stability control is activating a lot sooner that when I first got the car. The rear is not as solid as it was. It feels like it floats out when cornering. Also during acceleration I hear what sounds like tires rubbing. I know it's not that. Is this what the stability control sounds like when active?
Best I can guess is something in the rear broke or is loose or slipped.
Seems like its getting worse. Any ideas what could have happened? Also the car has no mods that I know of.
Thanks in advance and hello to everyone.
av8rdav is offline   Reply With Quote
Old 10-05-2020, 01:55 AM   #2
Griever423
Drives: 2020 BRZ PP
Could be an alignment issue. Maybe a toe issue. I'd get the alignment checked ASAP.
Griever423 is offline   Reply With Quote
Old 10-06-2020, 07:11 AM   #3
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
36 psi all the way around?
look at your rear sway bar pickup points/end links or post a picture.
thomasmryan is offline   Reply With Quote
Old 10-06-2020, 10:21 AM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
Are you getting any warning lights?
I had an incident at the track a few weeks ago where a yaw sensor went bad (apparently). It seemed cause the front left to be overworked under hard braking. No lights at this point. Then the VSC warning light came on, and at the next braking zone it just locked the front left, then both fronts :O
You might try removing the 40A ABS fuse and see if the car behaves normally. It could be that the VSC is confused and is applying asymmetric braking to "fix" things...
Old 10-06-2020, 11:56 AM   #5
p1l0t
p1l0t's Avatar
Ever since I shut my nannies off I stopped getting annoying lights on during hard turns.
Old 10-06-2020, 05:30 PM   #6
av8rdav
av8rdav's Avatar
No warning lights. I'm taking it to Subaru tomorrow.
Old 10-07-2020, 09:46 AM   #7
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
Sounds like a bushing to me, but this is also the typical 'diagnostic via internet' dilemma.
CrowsFeast is offline   Reply With Quote
Old 10-07-2020, 10:10 PM   #8
av8rdav
av8rdav's Avatar
Took the car to Subaru and they drove it and diagnosed it as a bad VSC (VDC) Control Module. Only about $1500 for that part.
Thanks to those who responded.
Old 10-08-2020, 04:23 PM   #9
ZDan
ZDan's Avatar
Drives: '23 BRZ
Jeezis... 95% sure mine's bad too. I guess at 46k miles I'm outta warranty on that :'(
Old 10-08-2020, 08:28 PM   #10
p1l0t
p1l0t's Avatar
OUCH I guess that's not something you can just find on the bay eithet.
Old 10-08-2020, 10:26 PM   #11
av8rdav
av8rdav's Avatar
Plenty of ECM's but none of these.
The Following User Says Thank You to av8rdav For This Useful Post:
p1l0t (10-09-2020)
Old 10-08-2020, 10:30 PM   #12
av8rdav
av8rdav's Avatar
The people at Subaru said they had never had an issue like this. I'm just glad the tech was able to drive it and see what I was talking about. He did say it was intermittent but he was able to get it to act up.
Old 10-08-2020, 11:35 PM   #13
norcalpb
norcalpb's Avatar
Is this what they replaced?
Old 10-09-2020, 08:11 AM   #14
Ragin Gti
Drives: '15 Subaru BRZ
I doubt that’s what’s wrong, sounds more like a wheel speed sensor. I’d call Subaru customer service (1-800-Subaru3) and ask for financial assistance. Customer service will often offer to help pay for a repair.
Ragin Gti is offline   Reply With Quote
The Following 2 Users Say Thank You to Ragin Gti For This Useful Post:
soundman98 (10-09-2020), ZDan (10-09-2020)
Possible problem after suspension install? max20s14 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 12-19-2016 01:43 PM
2015 frs (fit rear camera) problem sroby Electronics | Audio | NAV | Infotainment 2 01-20-2016 06:49 PM
Was looking at this set up. Will i have a problem fitting my 2015 RS1 ?? ChuckButta Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 10-09-2015 01:43 PM
Suspension problem Border7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 10-17-2014 05:03 PM
I need info and help with suspension problem kkkirbyyy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-26-2013 11:37 PM
