Old 08-02-2020, 01:59 PM   #1
airrick
Drives: TRD R.S. 1.0 FRS
Rear passenger wheel leaking?
Hello,
Last night i noticed there was fluid leaking from my rear passenger wheel. I assuming its brake fluid. It doesnt seem like diff fluid. I have pulled off the wheel and the axle seems to be a little rusted. I checked the brake fluid lvls last night, but the levels were fine. Any suggestions to find this leak would be greatly appreciated.
airrick is offline   Reply With Quote
Old 08-02-2020, 02:07 PM   #2
p1l0t
p1l0t's Avatar
Yeah only lines back there are hydraulic and gas. Gas would probably* evaborate and have that distinct smell. The only oil back there is in the rear differential but that is easy to see if it leaking from underneath.
airrick (08-02-2020)
Old 08-02-2020, 02:13 PM   #3
airrick
Hmm. I have seen on another thread about a member having the same problem but its was leaking brake fluid from the banjo fitting. And im still checking things. Theres no leak from it.
Its no gas, its the next day and it hasnt dried up at all.
Hydraulics, it could be the shock right?
Old 08-02-2020, 02:58 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
What do your CV axle boots look like?
Old 08-02-2020, 03:04 PM   #5
airrick
Looks fine.
Old 08-02-2020, 03:07 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That is actually quite a bit of grease coming out of that one. What about the outer joint?
Old 08-02-2020, 03:07 PM   #7
JD001
JD001's Avatar
Drives: Subaru BRZ
The pattern of spray on the face of the wheel makes me think that it may have come from outside ie not your car...
Old 08-02-2020, 03:20 PM   #8
airrick
Thats what i thought last night. I pulled off the wheel and you can see in one of the pics, the LCA has some kinda dried fluid on it. So im thinking it is from my car. Hopefully its not and i just ran over a puddle of oil or something
Its dry. And the other inner axle boot looks has the same amount of grease coming out.
Car has 65k miles. Recently boosted it.
2nd pic is of the other inner axle boot
Old 08-02-2020, 03:21 PM   #9
ls1ac
ls1ac's Avatar
The large puddle on the inside of the wheel could have splashed all over. Looks like it has only had a leak in one or two positions. It looks like it did not get on the outside of the rotor, check the inside. Have someone else push hard on the brake while you look for a leak from the hose or connectors.
Do not worry about the rust at he hub. That is normal.
Spray every thing with brake cleaner and old rag. Re assemble and drive for a short while and take the wheel off again and check carefully. Repeat until you find the leak.
It does look like brake fluid, but could be the robot dog next door peed on it in the night.
The Following User Says Thank You to ls1ac For This Useful Post:
Old 08-02-2020, 03:26 PM   #10
ls1ac
ls1ac's Avatar
Could you have driven through a puddle of oil at a construction site? A good cleaning with brake cleaner will show if it comes back..
Old 08-02-2020, 03:39 PM   #11
airrick
Alot of construction going on right now in my city so maybe? Great i just ran out of bradk cleaner. And all the other cars are gone. Lame. Ill re install everything and go to the dang auto parts store. Fingers crossed, its just that robot dog or cat.
Rear Passenger wheel bounce during cornering Takumidesh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 04-29-2019 02:34 PM
A lot of brake dust on passenger rear wheel DTMdreaming Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 05-26-2018 03:32 AM
Buzzing from rear passenger wheel Mattybro410 Issues | Warranty | Recalls / TSB 1 11-04-2014 09:25 AM
Water leaking in from under the dash on the passenger side FRSNewb Issues | Warranty | Recalls / TSB 3 07-23-2014 07:52 AM
AT Transmission rear seal leaking. CircuitJerk Issues | Warranty | Recalls / TSB 6 10-31-2013 03:41 PM
