Old 07-10-2020, 04:46 PM   #15
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Originally Posted by ZDan View Post
GiroDisc site doesn't show BRZ fitments, but this site shows front and rear Girodisc 2-piece rotors for BRZ "with Brembo brakes":
https://www.knsbrakes.com/c/car-item...5_Brake+Rotors
They only show the front but no rear, did they take it off?
Anyone order this Giro Disc 2-piece, I am interested in shaving 6 lbs in the front.
Thanks!
botbs is offline   Reply With Quote
Old 07-14-2020, 09:18 PM   #16
botbs
botbs's Avatar
A quick update for you all:
All these 3 are dual drilled (confirmed with Girodisc via email).
A1-007 will work on the front 100%.
They cannot confirm the rear but both are dual drilled.
https://www.girodisc.com/Girodisc-Fr...Ti_p_5514.html
https://www.girodisc.com/Girodisc-Re...Ti_p_5527.html
https://www.girodisc.com/Girodisc-Re...Ti_p_5537.html
Old 07-14-2020, 09:19 PM   #17
botbs
botbs's Avatar
08+ STI rears will only fit if the hat is dual drilled for 5x100 and 5x114.
- Andrew
Girodisc confirmed the A2-095 is dual drilled so it should be fine? I hope?
Old 09-14-2020, 09:55 AM   #18
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Hey guys, I actually found another option for the fronts at least. $700 for the fronts @ 17.1 lbs, so not as light but still decent weight savings.
https://paragonbrakes.com/2-piece-ro...ackage-brz-ts/
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 09-22-2020, 12:46 AM   #19
Rx FR-S
Drives: 2013 FR-S MT, 2023 Acura Integra
I got the TRD/PP Brembos for a fairly good deal and swapped in the fronts the other day. Found out I need to do something about the dust shield in the rear so the rears are still stock but I weighed the calipers and rotors (I believe they are the same for all non-Brembo models)- non-Brembo weight first, then Brembos:
Front rotors: 16lb, 15oz / 22lb, 12oz
Rear rotors: 13lb, 1.5oz / 16lb, 13.5oz
Front calipers: 13lb, 15.5oz / 12lb, 1.5oz
Rear calipers: 6lb, 15oz / 5lb, 15oz
Rx FR-S is offline   Reply With Quote
The Following 4 Users Say Thank You to Rx FR-S For This Useful Post:
Espi (08-14-2021), NaturallyAspirated (09-22-2020), SuperTom (08-25-2025), treedodger (05-10-2022)
Old 09-24-2021, 10:25 AM   #20
AndMsc
Drives: MY2018 GT86 EU
Does anyone know the disc width and disc airgap for the PP Brembos Front and Rear? I want to upgrade the discs, but I want to make sure that they are the same.
AndMsc is offline   Reply With Quote
Old 11-16-2021, 03:52 PM   #21
Skyehigh55
Drives: 2017 Pure Red BRZ w/ Perf Package
Girodisc to the rescue!
Confirmed Girodisc fitment from Girodisc themselves!
I reached out to them (finally) since I wanted to shave some weight down on the rotors when I replace my brake pads later this year.
Front rotor replacements: A1-007 5x100
Rear rotor replacements: A2-095 5x100 and 5x114 dual drilled
They also finally made a section for our platform with performance package/TRD Brembo’s!
I hope this post helps out anybody in the future
Skyehigh55 is offline   Reply With Quote
The Following 2 Users Say Thank You to Skyehigh55 For This Useful Post:
timurrrr (11-16-2021), ZDan (11-16-2021)
Old 11-16-2021, 05:30 PM   #22
jflogerzi
jflogerzi's Avatar
Thanks so much guys!
If the Gerodisc for '04-'17 fronts fit I might just get 'em. -11.6 lb. unsprung mass off the nose of the car, for *only* $800! Dayum...
Probably stick with 1-piece rears for now...
Give me DBA Slotted Rotors + more track time
2013 Series 10 FRS #553
Old 11-16-2021, 10:44 PM   #23
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Awesome, thanks for following up on that!
Updated https://www.ft86club.com/forums/showthread.php?t=144662 accordingly.
Old 11-16-2021, 10:50 PM   #24
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Maybe ask them to update the photos for the product page of A2-095 while at it?
The photo clearly shows a rotor with a 5x114 hole pattern, not dual-drilled.
Old 01-28-2022, 09:49 PM   #25
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Has any track rat tried Girodisc A1-007 yet? Any feedback?
Old 01-28-2022, 09:50 PM   #26
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
And that's for a pair!
Old 01-29-2022, 08:10 AM   #27
ZDan
ZDan's Avatar
Drives: '23 BRZ
Look great, work great, 12 lb. lighter, $$$. 20+ track days on them, fair amount of heat-checking but look to be good for ~8-10 more before new rotor rings?
timurrrr (01-29-2022)
Old 01-29-2022, 12:15 PM   #28
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Any obvious thermal performance difference vs OEM? Vs Centric Premium? Photos?
Any "clicks" when street driving?
Weight new rims with brembo. Alastor Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-19-2019 11:52 AM
*SOLD* Shorai Light Weight Battery Kit FRS BRZ 86 Kinetic Custom Machine Lighter Race hirollaz Audio/Visual, Electronics, Infotainment, NAV 5 07-12-2017 05:56 PM
Weight Reduction vs. Weight Distribution (for track use not for drag..etc) glamcem Tracking / Autocross / HPDE / Drifting 21 07-01-2014 11:38 AM
Rotor Weight ender2664 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 05-14-2013 05:14 AM
Weight reduction in the front only KevinBRZ Scion FR-S / Toyota 86 GT86 General Forum 16 04-12-2013 12:25 AM
