Old 06-23-2020, 08:03 PM   #1
pallen
pallen's Avatar
Drives: 2017 Toyota 86
Stock replacement HU with Carplay/Android Auto?
So, I'm seeing a lot of threads about Aus units being imported and installed.
Are there no US market stock replacement head units that preserve backup camera functionality, steering wheel controls, USB jack and add Carplay/Android Auto? I dont care about DVD compatibility and can live with not using the stock mic, but I would hate to give up HD Radio (though I would for Android Auto/Carplay)
Is there a list of known options and I missed it? Or can we start one?
pallen is offline   Reply With Quote
Old 06-23-2020, 09:05 PM   #2
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
Plenty of US models keep everything. The reason people import is so they don't have to use a filler kit for the radio opening. A standard double-din works just fine, but the stock opening is bit bigger at 200mm. That's all.
I myself have a regular old US market Pioneer. Has everything on your list.
sharpsicle is offline   Reply With Quote
Old 06-23-2020, 09:49 PM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
There are a lot of aftermarket stereos even custom Frankenstein tablet/stereo ones.
As said before you'll need an install kit. But that's is not a huge issue unless you are super anal about oem replacements
Old 06-23-2020, 11:21 PM   #4
pallen
pallen's Avatar
Ah - ok, that was the part I was missing. Its 200mm vs double-din. That makes sense now. Thanks for the clarification!
Old 06-25-2020, 12:42 PM   #5
bryan
bryan's Avatar
Drives: Lots of Toyotas
Is the OEM USB port compatible with Android Auto? (i.e. Does the OEM USB port transfer data and not just power?)
Planning to install a new Pioneer HU with Android Auto and want to know if the OEM USB port needs to be swapped out in order to utilize the feature.
bryan is offline   Reply With Quote
Old 06-25-2020, 12:46 PM   #6
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Yes, you just need the right adapter.
But honestly it’s in a terrible position for that. I put a second port in place of the 12v socket by the cup holders and that’s much better.
Old 06-25-2020, 02:01 PM   #7
bryan
bryan's Avatar
Thanks, really good to know.
You're right, the 12v socket by the cup holders is probably a better place, since there's literally no other place to put a phone.
The Following User Says Thank You to bryan For This Useful Post:
Yoshoobaroo (06-25-2020)
Old 06-25-2020, 04:58 PM   #8
pallen
pallen's Avatar
So, who has US models they like? I'm looking for most stock like, not something that will stick out too obviously as aftermarket.
I found this to just add carplay/android auto to stock, which would be great, but I feel like for the price, I could replace the whole thing with something better.
https://www.beatsonicusa.com/toyotac...droidauto.html
Are there any similar options that arent $500?
The Following User Says Thank You to pallen For This Useful Post:
Myriad (07-14-2020)
Old 06-25-2020, 06:51 PM   #9
Yoshoobaroo
TRACKBREAD
My Sony was ~$400 all said and done.
Originally Posted by Yoshoobaroo View Post
New headunit time! I got tired of debugging the Android headunit as often as it needed it. Queue a Sony XAV-AX5000 with Carplay/AA. I can highly recommend this unit. I paired it with the JDM radio filler panels (Google "brz av escutcheon" to find them) as every other dash kit I've found available looks like crap.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Griever423 (08-07-2020)
Old 06-25-2020, 07:37 PM   #10
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Do you have any pictures to share of the second outlet?
Old 06-25-2020, 07:42 PM   #11
Yoshoobaroo
TRACKBREAD
It’s a generic marine type panel mount USB extension, it dropped right in to the 12V hole.
https://www.amazon.com/ICESPRING-Fem.../dp/B01NAMU8KY
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
albert (08-25-2020), dragoontwo (06-25-2020)
Old 06-25-2020, 08:56 PM   #12
dragoontwo
dragoontwo's Avatar
Neat! I may look into stealing this.
The Following User Says Thank You to dragoontwo For This Useful Post:
Old 06-25-2020, 10:18 PM   #13
pallen
pallen's Avatar
That looks as good as I could imagine for a less than 100% stock fit. I'll be on the lookout for those. I would be perfectly happy with that.
How is the sound/power compared to stock?
Old 06-25-2020, 10:50 PM   #14
Yoshoobaroo
TRACKBREAD
Great. Sound is significantly better. UI is clean and processing power is more than enough such that it never hangs up. Bluetooth APTX and AAC support so even Bluetooth sounds great.
Pioneer AVH-ZL5150 - New LHD 200mm Head Unit w/ CarPlay and Android Auto! JBezugs Electronics | Audio | NAV | Infotainment 193 04-20-2023 09:40 AM
2020 gets new HU w/ Android auto, carplay RZNT4R Electronics | Audio | NAV | Infotainment 72 09-18-2020 12:09 PM
Android based stereo vs. stereo w/ Android auto redlined600 Electronics | Audio | NAV | Infotainment 12 02-24-2019 02:53 AM
FS: Double-Din Sony XAVAX100 Digital Multimedia Receiver (Android Auto/Apple Carplay) rubbercow Audio/Visual, Electronics, Infotainment, NAV 4 08-21-2018 01:41 PM
Android Auto im2lazy789 Electronics | Audio | NAV | Infotainment 3 12-06-2014 01:25 AM
