Old 06-20-2020, 08:59 PM   #1
pimmorg
Drives: 2013 frs w/ supercharger
FRS lost substantial power and exhaust quieter?
Hi all,
I was driving today and noticed my supercharged frs had a huge lack of power and later that day i noticed a significantly quiter/different exhaust tone on accerleration. It is so odd. I went under the car today to check for header leaks/exhuast leaks and couldnt find any.
Any ideas on what might cause this???
-c38 supercharger
-JDL UEL catted headers
-custom catback with muflers and resonator
pimmorg is offline   Reply With Quote
Old 06-20-2020, 10:22 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Sounds like the catalyst could be coming apart. Check and make sure it's not lodged in your exhaust somewhere! This could cause SERIOUS damage
The Following 5 Users Say Thank You to DarkPira7e For This Useful Post:
alphasaur (06-21-2020), humfrz (06-21-2020), Lantanafrs2 (06-22-2020), solidsnake11 (06-21-2020), Spuds (06-22-2020)
Old 06-20-2020, 11:12 PM   #3
pimmorg
That's what i was thinking. Ill go ahead and do this ASAP.
DO you think its ok to just rip out the cat and run it that way? Or should i invest in a new set of headers?
Old 06-21-2020, 10:17 AM   #4
DarkPira7e
DarkPira7e's Avatar
How old are the headers? I'd try to get a replacement through warranty. If there's not something forcing you to use chatted headers, I'd get a catless style and just have a cat in the frontpipe
Old 06-21-2020, 08:55 PM   #5
solidsnake11
Drives: brz
Works great on track. Shhh
solidsnake11 is offline   Reply With Quote
Old 06-22-2020, 12:34 PM   #6
pimmorg
Abosolutely nothing holding me back from catless. Bought the headers used on a great deal... now i think i know why it was a good deal.
Old 06-22-2020, 01:17 PM   #7
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Are you still making boost? Is it a boost leak?
BigTuna is offline   Reply With Quote
Old 06-22-2020, 01:57 PM   #8
pimmorg
I dont have a boost gauge but it feels like it makes boost still. Way underpowered all around though.
Old 06-22-2020, 04:19 PM   #9
pimmorg
Just talked to my tuner and the boost is actually way low. Only 3-4 lbs at peak. Hot intake temperatures too which may be a combination of headers and driving in 110 plus degrees.
The Following User Says Thank You to pimmorg For This Useful Post:
Spuds (06-22-2020)
Old 06-22-2020, 04:44 PM   #10
DarkPira7e
DarkPira7e's Avatar
This may be great news. Now I'd be spray testing every hose clamp on your air intake to see where it's leaking, you shouldn't be down that much, High temps or not, the amount of boost won't change, just its potency as it gets heat soaked
Spuds (06-22-2020)
Old 06-22-2020, 04:46 PM   #11
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
At the risk of stating the obvious, it sounds like something is wrong with the supercharger then? Belt slipping? Maybe some sort of down stream leak?
How old is the supercharger?
Old 06-23-2020, 01:31 PM   #12
pimmorg
SUpercharger is 2.5 yrs old. still under warranty.
I just went into exhuast and found issue. Primary cat exploded and was completely jam packed into the secondary cat. Im surprised the car even turned on lol. I ripped out both cats and the car seems perfect now (just a bit loud).
Thanks everyone!
The Following 2 Users Say Thank You to pimmorg For This Useful Post:
DarkPira7e (06-24-2020), Lonewolf (06-23-2020)
quieter exhaust after stage 2 tune jslack Engine, Exhaust, Transmission 12 05-22-2018 03:04 PM
Muffler Delete Lost POwer????? mr.brz1234 Engine, Exhaust, Transmission 16 09-21-2017 04:50 PM
WTT: Invidia N1 for Quieter Exhaust (SC LOCAL ONLY) JW843 Want-To-Buy Requests 2 03-14-2016 03:39 PM
Lost power in 1st gear and a bit of 2nd bear89103 Engine, Exhaust, Transmission 6 07-28-2013 04:32 AM
