Old 05-26-2020, 01:49 AM   #1
1234eher
Drives: 2014 FRS
2014 FRS with 56K kms, Odd transmission issue.
I'm hearing a faint sort of whining sound during cold starts,
When the clutch is pressed in, the noise goes away, when I take my foot off, it comes back.
After a quick drive, the noise goes away. quick restart, the noise is not there.
It comes and goes from day to day, the car is out of warranty period.
Shifts gears without an issue, no odd noises
1234eher is offline   Reply With Quote
Old 05-26-2020, 01:52 AM   #2
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Throwout bearing.
2017 Series.Yellow
2013 Whiteout
VINwiki - Changing Automotive History
dhuang is offline   Reply With Quote
Old 05-26-2020, 01:58 AM   #3
1234eher
Drives: 2014 FRS
Originally Posted by dhuang View Post
Throwout bearing.
Looked into that, quite possibly it.
Would you say this is a beginning stage?
how urgently should this be addressed?
Whats the costs involved?
Thank you for your reply!
Old 05-26-2020, 02:05 AM   #4
dhuang
dhuang's Avatar
I replaced the clutch in my '13 FR-S around ~63k miles because the TOB is doing what you are describing. Apparently the grease in the earlier TOB will stop doing its job, which is why you are hearing it screech. Unaddressed, the TOB could fail and leave you stranded.
The revised '17+ TOB (with the white dot) is the updated part and should remedy this issue. The part itself is around $30... the labor to replace it is equivalent to a clutch job unfortunately.
2017 Series.Yellow
2013 Whiteout
Old 05-26-2020, 03:02 AM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
Yeah, cheap part .. to get to which one needs to drop gearbox.
So hint1: always worth to change out cheap-ish TOB too, whenever you do clutch related or any work related to engine out/gearbox off, so as to replacement last longer.
hint2: for twins worth getting updated TOB revision part number, which supposed to have improved lubrication, supposed to last longer. (IIRC toyota SU003-07349, subaru 30502AA150)
Old 05-26-2020, 09:23 PM   #6
1234eher
Drives: 2014 FRS
here is a video, its hard to hear because it is soo subtle, but pretty much as described, a faint whining noise during cold starts goes away when the clutch is pressed in, also goes away after warms up or some driving. Thank you for your replies
Automatic Transmission TCU Issue aa_chow Issues | Warranty | Recalls / TSB 10 08-06-2019 11:53 AM
Automatic Transmission issue- dealer is not recognizing the issue, please help! Arrex Issues | Warranty | Recalls / TSB 36 06-03-2019 04:15 AM
Automatic Transmission Issue or ECU? OpteronO3 Issues | Warranty | Recalls / TSB 8 09-15-2015 12:04 AM
Transmission issue P.S.A.... 5AD86D Issues | Warranty | Recalls / TSB 10 06-22-2015 10:19 PM
Transmission issue oppiee Issues | Warranty | Recalls / TSB 12 05-13-2015 04:11 AM
