Old 04-18-2020, 02:24 PM   #1
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
My13-16 vs MY17+ Manual Transmission Differences
I searched, but searching for this topic seems especially difficult.
Are there any differences between model year manual transmissions? I might be in the market for something with less miles in the future, and I wanted to know if I need to be looking for something to match my 2013 transmission or if I could and should use a newer one.
Old 04-18-2020, 02:41 PM   #2
Ashikabi
Ashikabi's Avatar
I think the gearing changed but that might have been the final drive
Sent from my ONEPLUS A5010 using Tapatalk
Old 04-18-2020, 02:47 PM   #3
Irace86.2.0
I thought the same. I believe the final drive is changed, but not the gearing, yet I didn't know if they tweaked anything like they did with the engine.
Old 04-18-2020, 02:56 PM   #4
Irace86.2.0
https://www.ft86club.com/forums/atta...0&d=1528438014
I found this link, and it appears just 6th gear was strengthened. Seems odd, no?
Old 04-18-2020, 04:24 PM   #5
PulsarBeeerz
Drives: JRSC BRZ SOLD
Oddish that they chose 6th over 4th which has had more failures.
PulsarBeeerz is offline   Reply With Quote
Old 04-18-2020, 04:33 PM   #6
Irace86.2.0
That's what I was thinking, and why was it even necessary on a 5hp gain?
Old 04-19-2020, 03:52 PM   #7
I bet it's good for a half MPG highway as well as for marketing.
humfrz (04-20-2020), Irace86.2.0 (04-19-2020), jcw99 (04-29-2020)
Old 04-20-2020, 05:23 AM   #8
LancePower
Drives: 2020 BRZ tS
Never underestimate a good shot peening.
LancePower is offline   Reply With Quote
The Following User Says Thank You to LancePower For This Useful Post:
RuyGuy2 (04-20-2020)
Old 04-20-2020, 02:26 PM   #9
Yes, very important when you get over 130 mph.
Old 04-29-2020, 06:59 AM   #10
falcon_wizard
Drives: BRZ 2013
Has anyone successfully installed a MY17 6MT on a MY13-16 ?
falcon_wizard is offline   Reply With Quote
Old 04-29-2020, 07:32 AM   #11
Ashikabi
Ashikabi's Avatar
It seems like it should work. You should try it and report back
The Following 2 Users Say Thank You to Ashikabi For This Useful Post:
DarkPira7e (04-29-2020), Ultramaroon (04-29-2020)
Old 04-29-2020, 10:19 PM   #12
Rabrooks
Rabrooks's Avatar
Drives: 2020 Subaru BRZ
I installed a 2020 mt in my 13 frs auto. The only real difference I can see is the crankshaft sensor and the reluctor plate are different. Since I used 13 computers, I sayed with the 13 reluctor plate and sensor. Works fine
Rabrooks is offline   Reply With Quote
Old 04-29-2020, 10:56 PM   #13
Ashikabi
Ashikabi's Avatar
Is this plate accessible outside the transmission or does it have to be cracked open?
Old 04-29-2020, 11:37 PM   #14
Rabrooks
Rabrooks's Avatar
Its outside the transmission. Its sandwiched between the flywheel and the back of the crank. Remove the flywheel and it falls off.
Also, the reluctor plate/wheel is the same for the manual and the auto for the same years.
The Following User Says Thank You to Rabrooks For This Useful Post:
Ashikabi (04-30-2020)
Differences between auto and manual engine redlined600 Engine, Exhaust, Transmission 38 06-21-2023 11:35 PM
MY13-16 vs MY17+ AT Bluegrass Engine, Exhaust, Transmission 4 01-30-2019 08:50 PM
Air Filter for MY17 Manual mitsurugi_78 Engine, Exhaust, Transmission 10 02-28-2017 02:56 PM
DashCommand PRO Clusters MY13&MY17 NEW! Trap63 DIY (Do-It-Yourself) Guides 2 09-02-2016 03:34 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
