Old 02-23-2020, 12:08 PM   #1
fminicooper
Drives: FRS Hot Lava
Help Needed. OFT v2 with E85. At race track
I am at Eagle Cannyon race truck. My buddy broke his car so I am sharing mine with him.
Problem I am running E85 and low in fuel.
Can I mix E85 with 110 race gas, and run E85 tune? The blend will be 70% E85 and 30% 110. Seems make sense for me but any comment is welcome.
Sent from my SM-G892A using Tapatalk
fminicooper is offline   Reply With Quote
Old 02-23-2020, 02:14 PM   #2
DarkSunrise
DarkSunrise's Avatar
Should be fine. All that should happen is you will run a little rich until the ECU compensates by dialing back the fuel trims. Ignition timing should be fine since 110 has a higher effective octane than e85.
That said, I've never actually tried it so take that with a huge grain of salt. If you've got your OFT with you, I would datalog and keep an eye on fuel trims and knock.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
fminicooper (02-23-2020)
Old 02-23-2020, 10:19 PM   #3
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
The octane gives you the power benefit, but the Equivalence ratio won't be right.
It will help keep knock away, but you still need to burn more ethanol per unit air than gasoline. Mixing to a lower ethanol percentage will make the car run richer
EndlessAzure is offline   Reply With Quote
The Following 2 Users Say Thank You to EndlessAzure For This Useful Post:
fminicooper (02-24-2020), Lantanafrs2 (02-24-2020)
Old 02-24-2020, 04:16 PM   #4
fminicooper
If the car runs richer, Will ECU compensate the mix?
Old 02-24-2020, 05:53 PM   #5
EndlessAzure
Wheels for Brains
I can't say how good the compensation will be, or how much it can trim based on Measured AFR only. Don't have a lot of experience there.
Old 03-04-2020, 01:05 AM   #6
jflogerzi
jflogerzi's Avatar
After giving this thought its not a good idea. The tune is looking for e85 and even though the octane is very high, the tune is setup to to burn more fuel. This if you add race gas you got the octane number but you will need way less fuel to do so and the car will run like shit and super rich. So I hope in hind sight you did not push the car in that state. Yes the ECU can adjust but your fuel trims would be super out of wack
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
fminicooper (03-04-2020)
Old 03-04-2020, 02:13 PM   #7
CSG Mike
CSG Mike's Avatar
110 leaded? No; you will destroy your O2 sensor.
Old 03-04-2020, 02:36 PM   #8
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
should reflash to a 91/93 tune and run that with your 110. or better yet get actual 91/93
i would never fuck with E with mixtures and Off the shelf tunes. unless it has the mighty flex fuel.
Clutch Dog is offline   Reply With Quote
The Following User Says Thank You to Clutch Dog For This Useful Post:
Old 03-05-2020, 12:17 AM   #9
Tristor
Tristor's Avatar
Wish I’d seen this thread, I was at ECR at the same event in the white BRZ #93. If you’d come asked I had my car laptop with me and we could have loaded a 93 tune. There was 93 available at the track as well.
Tristor is offline   Reply With Quote
Old 03-05-2020, 02:42 PM   #10
fminicooper
Hope I see you around next time. Normally I do HDPE in Houston. I couldn't run 93 tune since my gas tank was 3/4
I was sharing the car with a mate that broke his Mini, I was worry to run out of gas, or having fuel starvation (it happened to me at MSR CCW with half tank).
My idea was trying to add a cuple of gallon to be sure we have enought for both. Not brillant good idea as I see.
Finally the rain in the afternoon changed plans.
I was with the Hot Lava #735
Engine Tune Needed for Track Day? Faulkner Engine, Exhaust, Transmission 21 11-21-2018 06:08 PM
Race Pads needed Maz NY / NJ / CT / PA 3 08-09-2014 03:23 PM
race/track car fastfrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 01-14-2013 08:26 AM
No Race Track Seats in Race Car Drivers Every Day Cars..!! JohnnyNight Cosmetic Modification (Interior/Exterior/Lighting) 24 10-16-2012 04:42 PM
Track Race circuit aloretoc Southeast 3 08-08-2012 11:55 AM
