Old 07-21-2012, 03:11 AM   #1
sw20kosh
Drives: 2013 Black FR-S
DIY: Black Housing Tail Lights
Hello,
***UPDATE: Housings are still intact - Silicone sealant worked perfectly
***UPDATE: No condensation/fogging at all after rain, fog and wash with pressurized water stream!
Here is a simple guide on how to black out your tail light housings.
It is not for a feint of heart as dremel'ing (cutting) up your tail light is some serious business. Hopefully it pays off in the end.
This is a 5-7 hr job depending on how good you are with a dremel and how comfortable you are with cutting up tail lights. I was very nervous and took things really slow especially on the first light. You also need to let the new sealant set over night so this is a long process.
You need:
1. screw driver
2. wrenches or metric sockets (deep sockets)
3. dremel with a cutting tool
4. paint (i used semi gloss black spray paint)
5. tint (optional - for those who want to make the red a darker red and to retain some functionality of the turn signals)
6. painters tape
7. sealant adhesive
(used some of Darrendriven's pics for the removal of tail lights - Darren let me know if you don't want me doing that for this guide and I will get my own pics)
1. Pop the plastic rivets out on either side of the trunk near the tail lights and fold the carpet back
2. Using a small tool (like a pick, or even a nail) you can lift the plastic catch inside of the zip tie. Pull the harness out and remove that plastic piece from the stud.
3. Remove 4 nuts from the studs. They are 8 mm or smaller (def not 10 mm)
4. After cleaning the lights up with mineral spirits and towel, take your dremel and cut this piece off of the lights.
5. It will look like this. You need to do this in order to get to the housing underneath it.
see above
6. Start cutting around the housing. Cut the black plastic but never cut the clear plastic. It is really hard to describe where to cut so you have to look at it and see/imagine where the housing is fused with the clear lense. Cut "behind" where they are fused - so that when you are done cutting the two pieces fall apart and the clear lens has a border of black plastic. It is probably best to just look at the pics.
7. More cutting
8. More
9. And more
10. Tada!!! The two halves separate and the chrome garbage falls out
12. Mask off the side marker (Looks like it is glued in so I didn't want to risk breaking something by prying it out)
13. Optional: mask off the turn signal area where the yellow bulb sits. You may want to keep this chrome so that it stays max reflective. I, however, sprayed Lense Tint in there AFTER I painted the housing black.
(you can see that area is lighter than the rest - still retaining some semblance of reflectivity)
14. Paint the chrome bezel now. I used 3 coats with at least 20 mins in between coats. Here is what it looks like after painting with Black paint. Let it dry for a few hours.
15. Install the bezel back into the housing when paint is dry.
16. Before installing the bezel I decided I wanted the red pieces to be darker so I sprayed them with a layer of Lens Tint.
17. Install the lense and apply the silicone sealant to the interface between the two halves. Let it sit overnight.
Final result as it sits today:
Cheerz
The Following 36 Users Say Thank You to sw20kosh For This Useful Post:
ATL BRZ (07-21-2012), AZOOZ_95 (05-28-2013), Azzaboynt (07-21-2012), baldolera (08-24-2012), Ben Stef (01-24-2013), Bonburner (08-19-2012), BRianZ (08-09-2012), BRZranger (07-24-2012), chanomatik (11-18-2012), cobrabyte (07-21-2012), Dadhawk (07-21-2012), drei (07-23-2012), GaN-MaN (02-04-2013), GuerillaRacing (11-21-2012), Guff (07-22-2012), idreamofdrifting (03-17-2013), JoeHK (10-10-2014), JollyJON (07-21-2012), kevinnivek8877 (07-22-2012), Kostamojen (05-03-2014), LivingLegend (07-21-2012), Lonewolf (07-21-2012), Longhorn248 (07-21-2012), mezdup (07-21-2012), MmmHamSandwich (07-22-2012), normancw (07-21-2012), ROJ (11-18-2012), RRnold (07-23-2012), Shankenstein (01-20-2013), Slartibartfast (08-14-2012), Snoopyalien24 (07-21-2012), StevenEngage (07-21-2012), sticky (07-21-2012), W2 (07-21-2012), WingsofWar (08-14-2012), yajin (08-14-2012)
Old 07-21-2012, 03:54 AM   #2
xclusive_brett
xclusive_brett's Avatar
Drives: 08 scion xb
seems a lil scary but its gonna look awesome. mad props to you!
xclusive_brett is offline   Reply With Quote
The Following User Says Thank You to xclusive_brett For This Useful Post:
hmong337 (02-23-2014)
Old 07-21-2012, 04:03 AM   #3
StevenEngage
StevenEngage's Avatar
Drives: 1995 Nissan Sentra
ON THE CAR!!!!!!! lol
StevenEngage is offline   Reply With Quote
The Following User Says Thank You to StevenEngage For This Useful Post:
F3dzo (07-21-2012)
Old 07-21-2012, 06:26 AM   #4
karma003
auto-crosser/drifter
karma003's Avatar
Drives: 2013 scion FR-S black M/T
This is what I've been looking for. Thanx a million cant wait to see
karma003 is offline   Reply With Quote
Old 07-21-2012, 06:39 AM   #5
RZ86
RZ86's Avatar
Drives: 2012 Toyota GT 86 Manual
awesome!!! considering my tails are cracked, and if toyota decides they won't replace them, I'll be doing this.
Current: '12 Toyota GT 86 Pearl White Manual
Previous: '96 Toyota Supra SZ-R
RZ86 is offline   Reply With Quote
Old 07-21-2012, 07:48 AM   #6
RWD-boxer
RWD-boxer's Avatar
Drives: Black
On car
RWD-boxer is offline   Reply With Quote
Old 07-21-2012, 08:48 AM   #7
Moshpit37
FR-S Owner!
Moshpit37's Avatar
Drives: 2013 FR-S Ultramarine 6AT
Looks good. Not a fan of taking a dremel to my tail lights but thanks for the how-to for those that are willing to do so.
Frances - 2013 Scion FR-S in Ultramarine
Owner's Journal
Moshpit37 is offline   Reply With Quote
Old 07-21-2012, 10:48 AM   #8
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Pic #8 looks pretty scary. Looks like the plastic got really boogered up on that side. How did you get it sealed good with the silicone with gaps that big? I want to do this but I'm nervous about getting them sealed good afterwards. Everything else I'm comfortable with.
Old 07-21-2012, 11:06 AM   #9
bullitt@uamotorsports
Drives: 1500hp 450zTT
Do you have a close up on the seal from the clear lens to the housing? Is it ultrasonic sealed? did you try baking them? What made you go straight to cutting the housing?
thanks,
Mike
bullitt@uamotorsports is offline   Reply With Quote
The Following User Says Thank You to bullitt@uamotorsports For This Useful Post:
Lee358 (07-21-2012)
Old 07-21-2012, 12:24 PM   #10
Frenchy86
Frenchy86's Avatar
Drives: 86 GTS White - TRD Addons
Cant wait for pics!
Frenchy86 is offline   Reply With Quote
Old 07-21-2012, 12:42 PM   #11
LivingLegend
Drives: 1994 Toyota Tercel
Thats what it should look like off the line! Great job!
LivingLegend is offline   Reply With Quote
Old 07-21-2012, 12:43 PM   #12
Lonewolf
Lonewolf's Avatar
Drives: Moped
You are awesome! I would be too chickensh__ to do this stuff to my taillights, but it looks significantly better than stock
Old 07-21-2012, 12:44 PM   #13
sw20kosh
thanks,
Mike
I went straight to dremel because I know what silicone sealed lights look like. THese are not silicone sealed. I also read that the tail light plastic is flimsy and people already have cracks. Did not want to bake them.
For the big gaps I just put a ton of sealant on them. Big goops. It sealed beautifully when I looked at in the morning! I think I wont have condensation issues!!! I was very liberal with sealant.
The Following User Says Thank You to sw20kosh For This Useful Post:
Old 07-21-2012, 12:58 PM   #14
StevenEngage
Looks amazing.
Smoking or Redding BRZ/FR-S Tail Lights DarrenDriven DIY (Do-It-Yourself) Guides 596 02-20-2021 10:11 PM
Black Housing Tail Lights (FR-S) sw20kosh Cosmetic Modification (Interior/Exterior/Lighting) 20 04-13-2016 11:38 PM
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 08:38 PM
opening tail lights? JollyJON Cosmetic Modification (Interior/Exterior/Lighting) 34 07-23-2012 04:35 PM
Are you going to smoke out your tail lights? Liquidsnake Cosmetic Modification (Interior/Exterior/Lighting) 8 06-06-2012 09:02 AM
