Old 01-03-2020, 09:31 AM   #1
Cchmelir
Drives: Subaru BRZ
Clutch/misfire issues need help.
Hey guys been having trouble with my car and could really use some help on this one...
I started experiencing problems about 5,000 miles after I bought and installed an ACT clutch and lightweight flywheel. It would have problems getting into gear from a stop. Continuing to drive the car it kept getting harder and harder to get into gear from a stop and now at this point the only was I have found to get it to go into gear is holding the clutch down for about 5-6 seconds then it will slid into gear fine. I only have this issue when the car is hot, while it is cold it seems to be functioning fine. I have bleed the clutch multiple time and replaced the slave cylinder which all seemed to help for a couple days then would go back to the same issue. I took the transmission back off and decided to take a look at the clutch, pressure plate, and flywheel and all seem to look fine.
And now for the interesting bit...
I decided to install the stock flywheel/clutch back into the car (originally when I removes it my throw out bearing was really bad and it had trouble getting into gear if this might of messed with the clutch/pressure plate/flywheel I’m not sure) and now the engine misfires pretty bad and stalls unless I rev it at idle. It’s also throwing codes P0011 and P0021 which has to do with a timing issue?
Very confused by this and could use some help, thanks in advance!
Cchmelir is offline   Reply With Quote
Old 01-03-2020, 10:18 AM   #2
Cchmelir
Drives: Subaru BRZ
Hmm didn’t even think of that. Thank you I’ll take a apart and look at it.
Old 01-03-2020, 11:50 AM   #3
Stomachbuzz
Drives: 2013 FRS
Originally Posted by solidsnake11 View Post
You may have timed the reluctor ring wrong. There is a dowel that lines it up on the crank. Its behind the flywheel.
I was definitely thinking of a sensor on the rear of the engine that would have been bumped when doing the flywheel. My thoughts hadn't yet matured to "reluctor ring" as they are typically on the front end of the crank in my experience.
But yeah, definitely a good first thing to check here
Stomachbuzz is offline   Reply With Quote
Old 01-03-2020, 01:48 PM   #4
fika84
fika84's Avatar
You either bent reluctor ring or got it on there wrong.. It would definitely explain the timing issues and misfiring!
fika84 is offline   Reply With Quote
Old 01-05-2020, 08:34 PM   #5
Cchmelir
Drives: Subaru BRZ
The reluctor ring was put back on wrong. Thanks everyone for the help!
Old 01-05-2020, 08:54 PM   #6
I love a happy ending.
clutch/tranny issues beat1 Issues | Warranty | Recalls / TSB 8 06-26-2018 05:05 PM
Possible Clutch Issues Strife26 Engine, Exhaust, Transmission 1 05-31-2018 03:10 AM
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 04:08 PM
Clutch Adjustment Issues!! FT-86- Scion FR-S / Toyota 86 GT86 General Forum 39 05-28-2015 09:29 PM
Clutch issues Mongo Issues | Warranty | Recalls / TSB 16 04-20-2013 12:10 PM
