Old 09-28-2019, 09:16 PM   #1
neoknux_009
Drives: 2012 86 GTS
Suggestion for a failing clutch replacement
My car is at 113,000 km. Started to hear some noise when using my clutch recently. (Could just be something simpler? TOB?) Since theres a chance im going to have replace it, I figured I could upgrade it.
Im happy with the OEM feel (I have nothing to compare it to), but I was planning on getting FI. My eye is currently set on the twin screw by sprintex:
http://www.sprintex.com.au/frsbrz/
or something around that range of power. I've read around that the OEM clutch can handle small amounts of boost. I Have a modified exhaust, with the exception of the front pipe.
Any suggestions?
neoknux_009 is offline   Reply With Quote
Old 09-28-2019, 11:28 PM   #2
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Do the Exedy Stage 1 clutch kit. It is identical to OEM, but with a stiffer pressure plate. The OEM clutch should last forever with street use, but the TOB is the week link, so upgrade that to the new TOB with the white dot on it, and consider upgrading the clutch fork to a Verus forged fork. The stage 1 kit can hold 12psi with E85, which is what I have. When I replaced my TOB (see my build), I could have kept using my clutch because it had plenty of life left at 75k miles.
Old 09-29-2019, 10:41 AM   #3
HaXx
Drives: jrsc_brz
ive been told its not a matter of "if" your tob will fail, its "when." so def do that
HaXx is offline   Reply With Quote
Old 10-01-2019, 02:57 AM   #4
neoknux_009
Drives: 2012 86 GTS
Sounds good. Do you have a link to that?
Sent from my LGM-V300S using Tapatalk
Old 10-01-2019, 07:51 PM   #5
Amputechture
Drives: 2014 BRZ
I second an Exedy stage 1. It feels like the stocker but about 10 percent stiffer. Just enough to feel different, and know it actually does feel stiffer not just placebo effect. I am in the 250 WTQ neighborhood and it holds fine...I can take off in second/its just as quiet as stock/great driveability. PTuning at one point said they were pushing almost 300 WTQ on their shop car with it.
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
Amputechture is offline   Reply With Quote
Old 10-01-2019, 10:54 PM   #6
neoknux_009
Drives: 2012 86 GTS
Something like this?
<https://automotivesuperstore.com.au/exedy-fjk-6926hd?gclid=EAIaIQobChMIvtW3iMn85AIVjA4rCh1tagLnE AQYASABEgJlz_D_BwE>
Old 10-04-2019, 09:08 PM   #7
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
We would definitely recommend the Exedy Stage 1. Its a great clutch for the money, and has great pedal feel.
WORKS is offline   Reply With Quote
DIY Clutch Replacement Supermassive DIY (Do-It-Yourself) Guides 217 08-27-2023 12:35 PM
Clutch and TOB Replacement - Calgary Deorio CANADA 1 03-19-2018 02:01 PM
Clutch replacement pinetree Engine, Exhaust, Transmission 21 05-03-2017 08:48 AM
Clutch replacement Thatguyjeremy Engine, Exhaust, Transmission 0 02-28-2015 04:22 AM
Clutch/flywheel replacement? bucket BRZ First-Gen (2012+) — General Topics 1 11-19-2012 12:25 PM
